It is called burden voltage, as the current is measured across a resistor shunt it drops some voltage, and thus your measured current, different multimeters and different ranges on the same multimeter use different resistor values, some using larger values to use cheaper measuring techniques, and some very low such as daves uCurrent, where reducing this effect was the designed purpose,
