Author Topic: Is my power-adapter universal?  (Read 1426 times)
Offline paxmeesTopic starter
  • Country: ee
« on: January 11, 2017, 07:14:49 pm »
I have an item(Roland sc-D70) with 100 V marking on it. Id like to use it on 230 V line.
So I opened it and found:
Poweradapter on separate board. (KPC 1694V-0)
  • It has fuse T2AL250V.
  • Cap 400V.
  • Heatsinked 3-leged thingi
    K2003
    -08
Can i asume its safe to use or is there something more i should look?
Marking KPC 1694V-0 seems to be more universally used, what is it?
Offline CJay
Re: Is my power-adapter universal?
« Reply #1 on: January 11, 2017, 09:03:46 pm »
I'd expect it to have a range like 100-240V rather than a single voltage if it was universal.
Offline neil t
« Reply #2 on: January 11, 2017, 09:56:15 pm »
I wouldn't assume anything, a quick check on google reveals only that it seems to be used by a number of different company's  ie Samsung and the like but found no specs or any info relating to voltages.
Online wraper
  • Country: lv
« Reply #3 on: January 11, 2017, 10:45:39 pm »
As it is marked 100V, most likely, it accepts 100V only. No other useful information provided in the post.
