The limitation is probably due to the choice of the value of the inductor. Higher voltage means that the current in the inductor will rise quicker - the regulator IC must be able to react fast enough to control that current, i.e. turn-off. The value of the inductor has probably been chosen to optimise other operating parameters - allowing for a high voltage input would be a compromise too far. You would have to reverse-engineer the schematic know for sure.
