Hello guys. Not perfect but will suffice. Finally painted for the first time the appliance and it looks much better now, although i could not completely flatten protruding rusted layers on the back edge of washing machine's lid:
Here is what was a big rusty surface:
Here is the gap between lid and panel after removing rust at the bottom which i was affraid to do because of a need to disassemble panel, which i did in the end thanks to one of member's suggestion in this thread:
I have question as why most surface came out matte and least came out glossy? You can see transition in the middle:
I shot a video as well so you can observe:
Is it because of number of sprays i did i.e layers? I did according to instructions printed on the back of spray can telling to apply thin layer after thin layer and let paint dry instead of applying just a thick layer.
By the way, this INDESIT washing machine served well for over 5+ years and is strong as
russian tank T50 because this is model T50 as you can notice in the above pictures. Coincidence?
