Robertson screws are far superior to Philips.
https://en.wikipedia.org/wiki/List_of_screw_drives#Robertson
No slippage and the screw stays firmly on the screwdriver at almost any angle.
Unfortunately, they are virtually unknown outside Canada.
The Robertson screw has a different set of compromises, is all. Screwhead must be fairly deep. The bit gets seized/stuck in screw with significant torque (say you are removing a lot of high torque screws.. you may have to tap/wiggle each screw to get them off the bit, similar to a hex head). The angle between the driver and screw must be straight. And the screwhead impression must be in a particular set of sizes.
One of the greatest advantages of Phillips is that you can drive a Phillips head screw with the wrong Phillips head bit. They overlap to a large degree. With one or two Phillips head bits, you can do nearly anything. If you have the wrong size Robertson head, you are SOL. I don't see Roberson as doing anything that hex or torx doesn't accomplish better. (A Robertson "allen key", for instance, would need a room to make at least a 90 degree arc to be useful, compared to a hex head). Also with a phillips, you can also drive a screw at a slight angle between the screw and driver.
And it's known in the USA, just fine. I'm curious if it is actually the most common type of screw in Canada.
I think the self-holding to the screwdriver is a good feature of Robertson. Makes things less clumsy. If you want to take off a screw that's stuck, I just tap the screwdriver on something.
Robertson is great because of the taper. This means that regardless of tolerances, every screw has a tight fit with the screwdriver. The screwdriver must be straight with the screw; but why would you want to drive it crooked?
There are No. 1, 2, 3 Robertson sizes... same as Philips.
Torx or Allen are not tapered. Obviously, to accommodate manufacturing tolerances, there must be some slack between the screw and the driver. So these are not self-holding like Robertson. In part due to the slack, Allen heads are prone to stripping. Torx does not strip, but it still suffers the non-self-holding malaise.
Robertson doesn't strip like Allen, but it strips more easily than Torx.
Philips is tapered too, like Robertson. However, the taper of Philips is more pronounced, so Philips will cam-out with too much torque. Robertson won't easily cam out, so you don't need to push hard on the end of the screwdriver to get a reasonable amount of torque.
Cam-out for mass production is obsolete. Torque-limited screwdrivers exist now; the cam-out doesn't need to be built into the screw head.
With Philips, it's easy to end-up with busted up screw heads because you cammed out, then you need to go over them with a file to be aesthetically pleasing...
Robertson is common in home construction type stuff. Electrical terminals/connections are going to be slotted or Philips. Automotive is Torx, Allen, or external hex (same as USA).
Robertson is my favorite of all. I think it has the
right set of compromises. Looks easy to manufacture.
