The first will have a larger current rating, while the small flat ones are low rated, and also require a specific board pad layout, traces to and from that are a specified width and a specified solder amount to get the trip rating within the specs. The others are wire ended, so that you have basically the first fuse with no shaped metal to make it SMD, just the 2 wire leads and a conformal coat for extra protection and the ability to survive a pick and place machine grippers.
