Tesla and free energy-to my knowledge he has not worked on the free energy,he simply wanted to make wireless transfer of energy regardless of the distance-During this research he encountered a lots of different problems but it is also solved it an unusual way ,such as low coupling transformer.
Even I know that this is a bad idea and I am not an electrical engineer ,but with a bit of thinking and obvious assumptions that this transformer needs to hold a vast quantities of electrical power resulting in a huge magnetic field then loosely coupling is not such a bad idea plus standing waves which obviously is not useful for energy transfer but they may be useful for changing the spacetime or the environment thus creating a favorable environment for the transfer of energy therefore the whole idea may not be so crazy or impossible.
so combining what is seemingly useless and what is proven from the classical science as useless can give interesting results which can only be proven if we build something like that.
further
During his research I do not know when, maybe before, maybe later of wireless energy transfer he might have found something ,something that does not belong to the classical calculations.
Now I'll try to explain and I warn you I am not a specialist in this but I hope you will see the same anomalies.
as I've written before about the car-input equally output minus losses so generally input and output are not that important and therefore we should pay more attention on the resistance whatever form was mechanical or electrical.
so car has a certain resistance and every second we use a certain amount of energy to beat resistance and logical would be to reduce the resistance on the the lowest possible level right,what we did and lower can not be
Now we leave the resistance of the environment as it is,Now we take The typical truck which is fifty times heavier than the usual cars so a bit of computation which says the mass, we have increased fifty times but energy consumption is increased only four times I mean even this is nothing unusual only few more axles.
But what is unusual is increase of potential kinetic energy,I mean it is not that unusual this is what we can expect
but if I take that kinetic energy and try to cancel resistance Then it gets interesting with the increase of mass and velocity says it would be possible to completely cancel resistance and even go below that which is bloody very strange.
generally speaking if we have a mechanism for the return of that energy more mass more speed and resistance is droping.
Now the question is whether this rule applies to electricity?
Then I remembered him maybe he's not so crazy because it speaks on mass very similar to what I noticed.generally if the system is bigger then it is better.
17.40min
Well you judge for yourself boys
