I was considering buying some Litz wire for the radio shown in the picture, but I wonder how much difference it would really make, and what would be the minimum number of strands to even consider? 10 strands is relatively cheep, but 660 is starting to get pricey, and from a practical sense would I even be able to notice?
I built that radio a couple years ago with stranded and insulated phone wire. It is 15 wraps around a 24" form. I forget what the split is, maybe 11/4 or 10/5, and I think I wound the shorter coil with the diode in the opposite direction. It works well and was peaking over 24µA on a strong station. I marked 14 stations on a wooden knob that I carved. I liked this radio because it did not require a separate antenna nor a ground, and it is very directional. I was considering adding a trap on each side (single coil with air cap on the same form) to help null the stronger close-by stations. Since, I've added a couple brass posts with knurled thumb-nuts to hold a few different diodes I've collected.
What do you think?
