I'll throw my two cents worth in.
With the diagram showing that the complex impedance is 50 ohms 0.7 lagging this requires that the impedance have a positive j figure. So when we have a simple ohms law I = V/Z, then when the Z has a +J the current ends up with a -j answer, and is therefore lagging. So the correct impedance should be Z = 35 + 35.7J.
V1 = 415. V2 = -j 415 (setting the voltages)
A simple Nodal analysis then gives us the equation:
(N - V1)/4j + N/(35 + 35.7J) + (N-V2)/6j = 0
Solving for the single node gives us N = 235.28 - 168.14j
The current through the complex load is therefore:
Iz = (235.28 - 168.14j)/(35 + 35.7J) = 0.893 - 5.72J
|Iz| = 5.78
Now to do a sanity check and make sure that the load current is actually lagging by the amount we need it to be.
The angle of the node voltage N is arg(N) = -35.55 deg. The angle of the current is arg(Iz) = -81.12 deg.
arg(N) - arg(Iz) = 45.57 deg.
cos (45.57) = 0.7 and the current is lagging the voltage, so all looks good.
BTW, I'm an old fart who uses mathcad, so that's why my maths is laid out as it is.
