Author Topic: World's Simplest Soft Latching Power Switch Circuit (modification)  (Read 3344 times)
Offline demat95Topic starter
Hi guys, my name is Mateo and I am from Argentina... I am kinda embarrassed to ask this question, specially for being in my 4th year of electronic engineering grade career lol.
Here is my question, I want to make dave´s soft latching switch circuit, but use an N-channel mosfet instead of a P-channel. I can´t get it to work on my protobard. I am using an IRF510 mosfet. Any hints? Where should I connect the Gate to? I connected the load between VCC and Drain, and Source straight to Ground..
Thanks!
Offline T4P
  • Country: sg
    • T4P
Re: World's Simplest Soft Latching Power Switch Circuit (modification)
« Reply #1 on: June 19, 2012, 06:37:52 am »
Thanks!
You MUST use a P-channel, in any other case it's alright to ask questions here, nobody's gonna chide you for not knowing!  :-[
Offline Psi
« Reply #2 on: June 19, 2012, 08:36:09 am »
You could use a N-channel, but you'd be switching ground on/off, which is a bad idea.
So yeah, as DaveXRQ said, It needs to be a P-channel
« Last Edit: June 19, 2012, 08:38:34 am by Psi »
Offline djeans
  • Country: tr
« Reply #3 on: September 16, 2013, 03:01:00 pm »
quiet old topic, but still not really answered?
you could use the output to drive your n-mosfet. Then it should work, if you have UGS(th) max as output voltage. or?
peace!
