The IRFZ24 Mosfet can conduct 17A if you keep it cool or conduct 12A when it heats so that its case becomes 70 degrees C, when its gate to source voltage is 10V or more.
I think your NTC temperature sensor is not sensitive enough to cause Vgs to go to 10V or more. Try changing the 10k pot to a 100k pot.
