Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Would you buy a Stepper Motor without a Data Sheet?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Would you buy a Stepper Motor without a Data Sheet? (Read 2609 times)
ukee1593
Contributor
on:
July 10, 2013, 02:04:48 am »
So I'm looking at buying some stepper motors for some miscellaneous projects (powering a robot, or a small PCB CNC) and have found a few on Ebay. The only problem is one that I found doesn't have a datasheet available.
I'm looking for decent power in a small size.
Here is the one with a data sheet:
http://www.ebay.com.au/itm/Sanyo-2-Phase-42MM-Square-Step-Stepper-Motors-103H5208-Haunted-House-Props-NEW-/290941313226?pt=LH_DefaultDomain_0&hash=item43bd7420ca
Here is the one which I cannot find a data sheet on:
http://www.ebay.com.au/itm/Sanyo-1-1-Amp-Stepper-Motors-200-Step-DIY-CNC-Router-103-775-7241-1-8-Degree-NEW-/300930708333?pt=LH_DefaultDomain_0&hash=item4610de336d
The thought of dealing with a stepper motor without a datasheet scares me a little. I know it is possible (as lots of people pull these out of old printers and use them for projects) but it would be nice to be able to read off the datasheet to make it easier to drive the motor. (and no, I don't have access to any old printers unfortunately)
Also, I'm not even sure which stepper is more powerful ... I'd assume that the first one (the one with the data sheet) is actually less powerful but I don't know for sure?
Any suggestions?
Last Edit: July 10, 2013, 02:58:23 am by ukee1593
Logged
michaelym
Regular Contributor
Re: Would you buy a Stepper Motor without a Data Sheet?
Reply #1 on:
July 10, 2013, 09:38:48 am »
The info on the item page on eBay, is basically what you get on a stepper motor datasheet.
Look at some on Digi-key on you will see what i am talking about.
What you need to look at, is the driver IC datasheet
Logged
ukee1593
Contributor
Reply #2 on:
July 10, 2013, 11:28:01 am »
Thanks for replying ...
The first listing (which included a datasheet) is brilliant ... It gives me all the specs of the motor and everything.
But the second one:
http://www.ebay.com/itm/Sanyo-1-1-Amp-Stepper-Motors-200-Step-DIY-CNC-Router-103-775-7241-1-8-Degree-NEW-/300930708333?pt=LH_DefaultDomain_0&hash=item4610de336d
tells me almost nothing. From what I can see it gives the step angle, and the current ... but is that the unipolar current, or the bipolar current? Heck the weight isn't even displayed (but I think it is about 1.2 pound from the shipping details).
As for the drivers, I took a look at the drivers suggested for other stepper, but I was planning on designing my own driver as a bit of a challenge/project!
As I said before, I'm still not sure which stepper is more powerful. If the 1.1 amp is the bipolar rating then it will be more powerful, but if its the unipolar rating then it will be less powerful AFAIK.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
