I would like to use 555 as
monostable to make a timer of 1 hour. I used very high values of capacitors and resistors such as: 20 Mohm and 1000 uF.
The output of 555 was always
HIGH and it is not able to be
LOW.
I googled and I found that there is a leakage current of capacitor and I have some questions:
1. Is this leakage current due to the nature of electrolytic capacitors? Or the capacitor discharge through the 555? In other words, What causes leakage? The capacitor itself or the 555?
I also found the solution of this issue, The following circuit was very helpful. It allows me to make a timer of 1.5 hours or even more.
2. Would you tell me how this circuit works? I know how monostable operation work but I don't understand the function of the transistor and how can it prevent the leakage current and how the capacitor is charged and discharged.
3. If the leakage current is due to 555 , Can I exploit it and use a capacitor only without the transistor and the resistor?One terminal of the capacitor would be connected to the ground and the other terminal would be connected to both pins 2 and 6.
The capacitor would be discharged through the 555 because it takes the leakage current from the capacitor. It would be charged again by a bush button.
Thank you very much,
