Hello, I have a problem deriving the formula which would descripe the relationship between Vin and output frequency on xr2206.
The datasheet says that f =1/RC, where C mean the timing capacity and R means the resistance between pins 3 and 12. Therefore I derived that f = dVin/3RC, where dVin means the voltage difference across resistor with given resistance R and C mean timing capacity.
Nevertheless the datasheet also says that f = 320000I/C.
Certainly both formulae cannot be correct therefore... where is the mistake
Thanks
