Hello! First post here. As a learning experience, I've decided to build a current and voltage adjustable power supply. I know many others have done so :-)
My requirements aren't as strict as Dave's in his power supply series (starting at eevblog #221), in that minimum voltage isn't a critical issue.
I have designed the following in TI Tina (similar to LTSpice), and it checks out in the simulator. Don't get hung on the component selection (especially since I'm using theoretical op amps!). What I am looking for are comments on the overall design. As I said, plenty to learn here. I will add protection circuitry (but will need to read up on that - please feel free to comment on the how and why, too!)
The idea is to control current and voltage from a microcontroller, where 0-1V will adjust current from 0 to 1A (notwithstanding the LM317/1117 or whatever other regulator's physical limitations), and 0-1V from another pin to adjust voltage from ~1.25V to 5V. I could easily change the voltage and current ranges in software using the same divider and sense resistor.
Anyway, thanks for any suggestions! See attached image.
