Hello all,
Long time lurker, first time poster. Looking to dip myself back into electronics as a hobby and I want to get started with some simple ones, like building a bench PSU and doing some simple audio stuff (headphone amp, desktop amp, modifying old car radio for aux in and pre-amp out).
From reading various posts here I know I can get by with a DMM and I've got one of your basic $15 cheapies, but I'd like to get a working scope.
I've read the following threads:
https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-dso/https://www.eevblog.com/forum/testgear/hantek-6022be-will-it-work-for-me/Given what I'd like to use it for, would this piece of gear be a good fit for my limited needs? From reading other threads I know that the main consensus is to save your duckets and purchase a Rigol or comparable Siglent, Owon, etc for ~$300 but at this time I simply cannot justify spending that much on a hobby all in one shot.
I also happen to have a JDR 3500 CRO that I purchased for $15 that I know needs some repair, and I've downloaded the manual for it and 2 other fellow clones (Tenma 72-330, Hung Chang OS-635). Need to get some probes for it then tear it apart to fix. Perhaps getting off my rear and repairing this unit would be a better use of money?
The only high frequency use I would use the scope for would be to fix the Metcal RFG-30 power supply I recently purchased. I've always wanted a nice Metcal iron, and ebay deals for working used Metcal stuff almost always mushrooms near the end of the auction. Using a scope to verify its outputting 13.56Mhz is probably the only high frequency use that I'd use it for.
Well, enough rambling, and I appreciate the advice.
Thanks.
