Author Topic: Z80 single board memory bank switching  (Read 44143 times)
Offline grumpydoc
Re: Z80 single board memory bank switching
« Reply #50 on: November 24, 2013, 09:07:27 am »
The 74LS138 does not have tri-state outputs, inactive outputs are just at logic 1 so you don't need to worry about pull-up resistors.
Offline netdudeuk
« Reply #51 on: November 24, 2013, 09:49:51 am »
Great thanks.
« Last Edit: November 24, 2013, 09:58:36 am by netdudeuk »
Offline netdudeuk
Re: Simple Z80 memory interfacing pt 3
« Reply #52 on: July 09, 2017, 10:57:36 am »
OK, so the previous two examples are fine for micro-controller projects but the OP was interested in CP/M. For that you need RAM at low addresses because the TPA (i.e where programs are loaded) starts at 0x0100. Also you really need 64k of RAM if at all possible.
This all provides a bit of a problem, how do we have ROM at address 0 for the initial cold reset and RAM at address 0 when running CP/M?  I should point out BTW that for the moment I'm thinking of CP/M 2.2 and below - CP/M 3.0 supported bank switching but it wasn't around the last time I built a machine to run CP/M so I need to go and have a look at how it works.
We need to introduce some ability to switch one bank between ROM & RAM - the following (totally from memory so untested) circuit should do the trick
We now have two 32kx8 SRAM chips plus some additional gating with half a 74LS74 and a couple more OR gates. On reset the flip flop is cleared so the output will be low, this allows the chip select signal to pass to the EPROM. If a "1" is written to the flip-flop then the chip select will pass to the SRAM.
So, after a reset code in the ROM will run - as part of its initialisation it needs to copy some code up into addresses above 0x8000 and then jump to that code - the flip flop can then be switched to allow the whole 64k to be RAM.
I haven't shown how the clock input to the flip-flop is generated, so that can be considered an exercise for the reader :) but it needs to be the result of combining a decoded I/O address and the processor WR signal. I'll try to find time for some posts covering I/O interfacing in the next day or two.
Hope these posts have been helpful.
Hi
Regarding the reset for the flip flop.  Assuming that this is also connected to the processor reset pin, will the flip flop outputs always have settled before the processor is ready to read from memory for the first time ?
I guess the related question is can you also be sure that the flip flop will always have changed state fast enough for the first memory access after the bank switch request ?
I'm using a Z84C0010PEG clocked at 4MHz.
Thanks
Offline grumpydoc
« Reply #53 on: July 11, 2017, 09:44:45 pm »
Hi
Thanks
There is plenty of time because reset going low will drive Q high (and \$ \overline{Q}\$ low). For a "normal" reset one holds \$ \overline{RESET}\$ low for at least 3 t-states which, at 750ns with a 4MHZ clock is rather longer than the propagation delay in a 74LS74. Even if one uses the "warm" reset feature (holding \$ \overline{RESET}\$ low just at the rising edge of T1 in an M1 cycle there are three clock cycles before the next read.
Offline netdudeuk
« Reply #54 on: July 12, 2017, 06:22:43 am »
Thanks
