1990's audio was generally made in the far East, so Japan, Hong Kong, or around there, and often used Japanese made components. Thus the common diode was the ISS1 diode, and yes these are part of a whole range of ISS numbered diodes, including zener and other diodes, all in the same glass package with a band. Thus you will have to reverse engineer the circuit to see what the actual use of the component was, as they can vary greatly while looking identical, and only the reel had the part number on the auto insertion machine that made the equipment in question.
What make and model, you can perhaps find a service manual for it online, and this tells you what they used where, often with PCB diagrams as well showing you the location of the component on a grid, that was part of the parts list.
