Thanks TIMB!
I wanted to see your low transistor count, regulator circuit, once you mentioned it in another thread (ping pong anyone ?).
I've been curious about it, ever since.
Oh ok Timbs low transistor count circuit, sorry my mistake doh lol.
Don't worry, it is an easy mistake to make.
I'm VERY impressed with his circuit. Very neat!
From a quick look, despite the fact it is still "zener" based, it actually uses the combined gain of a darlington transistor AND another, plus an interesting configuration, so that it will actually close the loop (i.e. really regulate the voltage), to a fair extent (some non-linearities, obviously). It even seems to have a built in current limit.
Because of its clever implementation, it is using a zener of about 6.25V, which gives really good voltage accuracy (especially as regards temperature stability, as that voltage, usually gives the smallest change per deg C, because of the semi-conductor physics of the device, because of zener/avalanche mode stuff and voltage).
I presume the resistance added to the smoothing capacitor, across the zener, is to increase its ESR (virtually), to improve the stability of the power supply.
Because it limits the heating effects in the zener and transistor which drives the darlington, as they have relatively little current in them, and the pot/trimmer allows most of that error to be "tuned/calibrated" out. The voltage accuracy and stability over time, should be good. Especially for a zener based, circuit.
At the moment, the circuit seems to be designed for around 500mA's or so, output current. Since it seems to be limited at around the 650mA mark.
(Obviously) it could use higher spec parts (especially the main output darlington), to achieve higher output currents. It may even be possible to configure it to use more than one output darlington (to share the heat dissipation), with some thought to the circuit, such as suitably valued emitter resistors, of very approximately 200 milliohms.
