Author Topic: #39 pic kits  (Read 11614 times)
Offline invent
#39 pic kits
« on: September 10, 2010, 01:37:31 am »
I wanted to purchase the pickit2. Should I purchase the "pickit2 starter kit" or "pickit2 debug express". I have used microchip products with third parties programmers in the past.  I thought the debugging functions would be helpful. Can I also debug with the “pickit2 starter kit"? Any advice on which to pick.
Thanks,
Offline migsantiago
    • MigSantiago's Web Site
Re: #39 pic kits
« Reply #1 on: September 10, 2010, 02:07:02 am »
Hello
You can debug most of the PICs with just the Pickit2 programmer and no boards else...
http://www.microchipdirect.com/productsearch.aspx?Keywords=PG164120
Some old pics require an ICD header and a special connector, so it's up to you if you just buy the programmer or the whole kit.
In order to know if you'll require the whole kit, check the programmable-debuggable pics in this list:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en027813
The pickit2 main page:
http://www.microchip.com/pickit2
I only have the programmer and have never required any board else.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: #39 pic kits
« Reply #2 on: September 10, 2010, 02:29:19 am »
I bought the pickit2 on it's own and have been quite happy with it, I've never got round to using the debugger, as i understood it, it was just a better than nothing logic analyser ? but of course useful if you have nothing else although i prefer to use a scope where i can.
Bear in mind that whatever you buy straight off microchip will come out much more expensive than they show, my pickit2 started as listed at £17.5 and ended up at £37 delivered after VAT, handling charges and shipping, to be honest to advertise something for £17.5 knowing they will put another 5 on it for handling (that there is no exemption for anyway) is not very nice but who can argue with a big corporation.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline migsantiago
Re: #39 pic kits
« Reply #3 on: September 10, 2010, 03:05:05 am »
I bought my Pickit2 from mexico.newark.com and at the end I payed 47.15USD.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #4 on: September 10, 2010, 03:12:58 am »
I would think ordering stuff in bulk direct from microchip becomes much cheaper but one offs are not cheap, it's cheaper and faster to get pics from farnell/RS than microchip unless your buying thousands
Offline ElektroQuark
    • ElektroQuark
Re: #39 pic kits
« Reply #5 on: September 10, 2010, 05:40:10 am »
Yeah, I have been recently buying some Microchip development items and the quote was significantly cheaper from farnell than Microchip itself.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #6 on: September 10, 2010, 10:01:22 pm »
it's because at least for the UK they do not hold stock so I think they send it straight from asia, else they are just ripping us off
Offline scrat
Re: #39 pic kits
« Reply #7 on: September 10, 2010, 10:56:27 pm »
I think a debugger is much more than a logic analyser. It allows you to instantly see how variables and internal registers are set, without the need to put them on an output pin (which in some cases can be impossible), or to see if a piece of code gets executed or not. For example, this way I easily found some errors in peripheral libraries, and now I usually take a look at all the registers involved, if something seems not right. Of course, you can't use it in some cases (especially when working with converters or controllers), but I think it is still useful.
I own a homemade clone of the MPLAB ICD2 (the debugger from Microchip), and it works quite well with MPLAB (even if breakpoints management isn't so good). It is easy to find on the net schematics, layout and firmware to make a clone, and it will cost much less than the original (the major cost comes from a PIC18F4550 and a PIC18F877A, but I received them as free samples).
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #8 on: September 10, 2010, 11:01:28 pm »
I think your talking about the junebug ? by blue room electronics, that seems to be a good replacement for the pickit2
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: #39 pic kits
« Reply #9 on: September 12, 2010, 03:03:57 am »
Hello
how to do the real debugging with pk2? coz so far what i know it only capable of simulated debugging in MPLAB ???
if something can select, how cant it be intelligent? if something is intelligent, how cant it exist?
The Future is Now, Breaking the GHz Barrier... (Lecroy DDA5005 5GHz 20GS/s XXL)
Offline migsantiago
Re: #39 pic kits
« Reply #10 on: September 12, 2010, 09:57:32 am »
Hello
Just enable the debugging tool as Pickit2 in the Debug menu.
The step by step functions, breakpoints, watches, inspectors and everything else you use in the MPLAB SIM tool, are now replaced with the real time data the Pickit2 collects. Simple.  ;D
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #11 on: September 12, 2010, 04:57:08 pm »
I think the pickit2 has a built in logic analyser, to debug you probably need something else
Offline migsantiago
Re: #39 pic kits
« Reply #12 on: September 12, 2010, 11:38:43 pm »
The pickit2 has a built-in logic analyzer and a built-in debugger. You need nothing else (for most of the pics).
It also has a UART tool, Logic input/outputs and a variable power supply from 2.5V to 5V with up to 100mA output.
Offline scrat
Re: #39 pic kits
« Reply #13 on: September 13, 2010, 09:01:06 pm »
I never used a PicKit 2 until now. From what you said, it has nothing less than MPLAB ICD2, perhaps something more. Why does it cost much less?
I always thought that PicKit2 had some restricted feaures about debugging, so I didn't go so much in deep.
Offline TopherTheME
Re: #39 pic kits
« Reply #14 on: September 14, 2010, 07:00:26 am »
I wish the pickit 2 supported the PIC32 chips.  :(
The manual board power thing really ticks me off.
Don't blame me. I'm the mechanical engineer.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #15 on: September 14, 2010, 07:10:28 am »
microchip might have made some good token efforts over pickit3 being improved but I would still call them cheats and dishonest, as far as I know apart from not being kept up to date and the few extra's 3 offers there was no need for the "upgrade" is was just to drag more money out of people. Basically microsoft tactics
Offline migsantiago
Re: #39 pic kits
« Reply #16 on: September 14, 2010, 07:26:34 am »
I can program my PIC32MX420F032H and my PIC32MX440F512H just using my Pickit2. What I can't do is debug them.
There are some PIC32s out there that can be programmed with the Pickit2.
PIC32 Devices
    * PIC32MX320F032H, 320F064H
    * PIC32MX320F128H, 320F128L
    * PIC32MX340F128H, 340F128L
    * PIC32MX340F256H
    * PIC32MX340F512H
    * PIC32MX360F256L, 360F512L
    * PIC32MX420F032H
    * PIC32MX440F128L, 440F128H
    * PIC32MX440F256H
    * PIC32MX440F512H
    * PIC32MX460F256L, 460F512L
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #17 on: September 14, 2010, 04:49:19 pm »
are there open source versions of the firmware/software, it would be great if someone gave microchip the kick up the ass they deserve by rewriting the firmware for pickit 2 and 3 so that 2 supports all the later chips and 3 actually works
Offline scrat
Re: #39 pic kits
« Reply #18 on: September 14, 2010, 06:36:58 pm »
I don't know how it is for the Pickit 2/3, but for the ICD2 someone ripped up the FW (or made one equivalent, but I don't think so), take a look at here: http://www.icd2clone.com/wiki/Main_Page
Probably the same happened for Pickit2, it is a little less probable for Pickit3, since it is too recent.
Then one should also modify the PC software (even the driver?) to implement different things from the original version... Not an easy task, starting from the assembly!
Offline migsantiago
Re: #39 pic kits
« Reply #19 on: September 15, 2010, 12:03:17 am »
Yes, there are. Microchip released the firmware, electronic diagrams and Visual Studio source code for the Pickit2. It's not a secret:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1960
There are lots of Pickit2 clones around the internet. I think the Pickit2 firmware is perfect. There's no need to modify it, IMHO.
I don't know about the pickit3 source code... I've seen some A!tium files which have the inners of the pickit3, which uses a PIC24 and also include its firmware. I don't know if Microchip released it or if it's a hacked Pickit3.
« Last Edit: September 15, 2010, 12:06:35 am by migsantiago »
Offline migsantiago
Re: #39 pic kits
« Reply #20 on: September 15, 2010, 01:33:23 am »
It's a PIC24 hex. You can modify it if you know ASM and have the patience to analyze thousands of lines.
The hex can be updated via MPLAB or Pickit3 beta.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #21 on: September 15, 2010, 02:32:42 am »
so could the pickit2 be updated to support later chips ?
Offline migsantiago
Re: #39 pic kits
« Reply #22 on: September 15, 2010, 03:05:42 am »
It is constantly being updated by Microchip to do so.
But it works with a PIC18F and therefore it has its limits. That's why you can't debug a PIC32 with a PIC18.
Just buy a Pickit3, it's not that bad.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #23 on: September 15, 2010, 04:38:40 pm »
yea 2 fills my needs so far so I will wait until I need it
Offline TopherTheME
Re: #39 pic kits
« Reply #24 on: September 16, 2010, 04:22:57 am »
I own one, its ok in most respects. Its very fast and does everything I ask it to without issue. I bought mine for $35 shipped with a student discount, but if I paid full price for one I would probably be complaining more. There really isn't much room to complain if you think about it. Although its not as fully featured as the 2, it programs and debugs every modern microchip uC out there for a fraction of the cost of other manufacturer's programers *cough* atmel *cough*.
« Last Edit: September 16, 2010, 04:25:16 am by TopherTheME »
Offline migsantiago
Re: #39 pic kits
« Reply #25 on: September 16, 2010, 05:48:22 am »
Dave's reviews can be harsh and people may only listen to the bad stuff about the product.
I would also buy a Pickit3 if I needed one. For now, my pickit2 is enough for my programming-debugging tasks.
Online EEVblog
Re: #39 pic kits
« Reply #26 on: September 16, 2010, 03:45:29 pm »
I would also buy the PICkit3. My review was actually a comparison of it compared to the PICkit2 at the time (and it was a long tie ago now), i..e from the perspective of an "upgrade". At it stands it wasn't actually as bad as my ranting led many to believe, and has likely improved greatly since then.
Dave.
Offline migsantiago
Re: #39 pic kits
« Reply #27 on: September 17, 2010, 12:35:06 am »
then maybe you should do an "upgrade" video review about pickit3. we should be interested in the latest feautures/benefits of it.
Definitely. Many people only know the pickit3 thru his video.
An update video would be fair.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #28 on: September 17, 2010, 02:26:59 am »
I'd love to see a video of 3 as it stands now, I really still don't get what the new features are supposed to be. from what I can tell all microchip have done is go microsoft style and stop support for a perfectly good product and then release one that does the same thing but looks better and will get the upgrades and support that the old version could benefit from equally and still be a better product overall
Offline nathanc
Re: #39 pic kits
« Reply #29 on: September 20, 2010, 07:43:01 am »
So I'm even more confused now... should I get a pickit 2 or 3?
Offline TopherTheME
Re: #39 pic kits
« Reply #30 on: September 20, 2010, 10:20:31 am »
I would just go ahead and get the pickit3. The pickit2 is now obsolete and doesn't fully support some of the nicer chips that microchip now sells. There is nothing that the pickit2 can do that the pickit3 can't in terms of programming/debugging. Its just some of the extra features are nice to have.
Offline migsantiago
Re: #39 pic kits
« Reply #31 on: September 20, 2010, 10:48:58 am »
Yeah, the pickit3 will keep you updated with every new PIC on the market.
Offline Simon
  • Global Moderator
Re: #39 pic kits
« Reply #32 on: September 20, 2010, 04:34:26 pm »
wait until pickit4 is announced! :D use your instinct!
if it ever is it will surely be crap, they have a good product and should work to keep it so.
