Author Topic: Dave's 1000 th video episode count down - How to celebrate it ?  (Read 13281 times)
Offline ez24Topic starter
  • L.D.A.
« on: November 03, 2015, 09:20:17 pm »
1000th Youtube video episode count down  -  How to celebrate ?
As of today (Nov 3, 2015), Dave has uploaded 992 Youtube videos.  8 to go
https://www.youtube.com/user/EEVblog/about
Personally I will have a beer and give a toast to Dave  :-+
For fun look at his #1
https://youtu.be/AUwbtG6z6pI?list=PL5Qevr-CpW_yZZjYspehnFc-QRKQMCKHB
and No 3  (rap dance and holding up his fingers)
I would love to see Dave hold up 1,000 fingers for the 1,000th show and give another rap dance.  Maybe fireworks?  A cake with 1,000 candles ?
What ideas do you have for him for his 1,000 celebration video ?   Hope he sees this before the 1,000th Youtube video  :-//
« Last Edit: November 03, 2015, 11:26:32 pm by ez24 »
Online Ian.M
Re: Dave's 1000 th video episode count down - How to celebrate it ?
« Reply #1 on: November 03, 2015, 09:42:52 pm »
10x10x10 LED cube?
  • L.D.A.
« Reply #2 on: November 03, 2015, 11:15:29 pm »
Don't forget it comes up at #1002 since #666 and #741 never got made.
I don't think counting non EEVBlog videos in the numerical sequence should be allowed. The reason for the second channel as far as I can recall was they were not considered either worthy or of sufficient interest for official EEVBlog numbering.
Anyway the 1000th video has to be a retrospective compilation of the highlights up to that point.
I am going by what Youtube says ie  1000th Youtube video.  Dave's numbering system is too wacky to use.  So this is not a EEVBlog number but a YT number.
Offline crispy_tofu
« Reply #3 on: November 03, 2015, 11:23:13 pm »
:-DD
Offline EEVblog
« Reply #4 on: November 04, 2015, 03:19:53 am »
Had no idea!
Offline pickle9000
« Reply #5 on: November 04, 2015, 03:48:18 am »
Retrospective, what's going to happen next, a cake with a thousand candles, and a hamster named Tricky Dick.
Offline Galenbo
« Reply #6 on: November 04, 2015, 08:05:08 am »
Maybe, with 1000th, 1024th is meant to be gonna celebrated :-)
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline Fungus
« Reply #7 on: November 04, 2015, 10:09:46 am »
10x10x10 LED cube?
Get Dave II to solder it...  :popcorn:
Offline crispy_tofu
« Reply #8 on: November 04, 2015, 10:15:25 am »
10x10x10 LED cube?
But they need to make the pick-and-place machine...  ;)
Offline daqq
  • Country: sk
    • My site
« Reply #9 on: November 04, 2015, 10:31:23 am »
Tear down your favorite multimeter? Explode a 1000 ohm resistor? Discharge a 1000uF cap bank @ high voltage (1000V ideally) into something? 1000 LED blinking at 1000 Hz?
Offline EEVblog
« Reply #10 on: November 04, 2015, 12:09:53 pm »
I like the blowing up idea, haven't done that in a long time.
Good excuse to get a decent high speed camera, the Sony RX100 Mk4
« Last Edit: November 04, 2015, 12:19:52 pm by EEVblog »
Offline SteveyG
  • Soldering Equipment Guru
« Reply #11 on: November 04, 2015, 12:55:14 pm »
10x10x10 LED cube?
They did - Sagan
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Online Ian.M
« Reply #12 on: November 04, 2015, 01:52:53 pm »
With properly designed assembly jugs, and using SMT LEDs soldered between hard brass wires in 10x10 grids with the wire planes separated by the length of the LED, it should go pretty quickly.  Treat it as a multiplexed 10x100 display and drive it off a string of 14 TPIC6A595 chips with 10 of the outputs acting as level shifters for the 10 anode drivers.   Built on veroboard of course!   Control it with whatever MCU board Dave's been mailbagged that is interesting enough to be worth installing the toolchain.
Offline Fungus
« Reply #13 on: November 04, 2015, 02:46:31 pm »
"jugs"?  :-DD
I've only made a 4x4 cube bit it was almost impossible to get 16 slightly misaligned LED legs inserted into veroboard. 10x10? Never going to happen.
(I believe they use foam at the bottom of LED cubes for this reason...)
Offline Fungus
« Reply #14 on: November 04, 2015, 02:48:17 pm »
I think Dave should put 1000 9V batteries in series and connect it to things. You can clip them together like this:
 :popcorn:
Offline zapta
« Reply #15 on: November 04, 2015, 03:17:42 pm »
#1000?  Still waiting #666 and #741.
Online Ian.M
« Reply #16 on: November 04, 2015, 03:25:44 pm »
"jugs"?  :-DD
Big jugs are always good.   Whenever you can get away with it, stick BRA 0xDD somewhere in your code!  However in this case s/jugs/jugs/
No problem - you've got 10 separate vertical 10x10 planes to fit and if built on a jig the spacing will be pretty accurate.   Each only has 10 wires to solder to the veroboard at the bottom of the cube.
Solder the 10 common anode wires straight across all the planes at the back of the cube, then add 10 vertical wires with a right angle bend at the tip to clear the horizontal wires, staircase fashion to connect them down to the veroboard.
100 wires of ribbon cable with the ends fanned out to the individual cathode column pads + 10 heavier wires for the common anodes soldered trackside to go off to the driver board
Offline Fungus
Online Ian.M
« Reply #18 on: November 04, 2015, 03:56:23 pm »
AAGH!!  s/jugs/jigs/
Have you sought professional help?
Yes, but they ran away screaming.
  • L.D.A.
« Reply #19 on: November 04, 2015, 04:57:13 pm »
I should have said Number 1000  not #1000  -  again this is the 1000th video uploaded to Youtube NOT #1000 per Dave's numbering system.  Some of his videos have no numbers and he uses two numbering systems when he does use a number.
What gave me the idea was him holding up his fingers in his early videos.
  • L.D.A.
« Reply #20 on: November 04, 2015, 05:11:18 pm »
Really celebrate and get this high speed camera, free shipping :
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=1063304&gclid=Cj0KEQiA0-GxBRDWsePx0pPtp4sBEiQACuTLNmo7p_PJi9Eh6gFzyRAd72jzDGgWn31N9RV3PXmSJi8aAgYm8P8HAQ&is=REG&A=details&Q=
It would bring your videos to a new high level and your bank account to a new low.
If you are serious about blowing things up, I suggest you start a new post asking for ideas on what to blow up.  Some members have imaginative brains (not PIC).
Online Ian.M
« Reply #21 on: November 04, 2015, 05:26:25 pm »
 :popcorn:
That's a bit pricey.  Might be useful for high CAT multimeter testing though!
What about something simpler and more ergonomic?  A 1000V DC BOFH style cattle prod.  Take 336 CR2032 cells and stack them in a 21mm ID plastic tube. Easiest to tape them in 1" tall stacks of 8 so they don't flip as you slide them in.  It will be just over 1m long.    (336 cells so we dont end up under-voltage  8) )
http://www.aliexpress.com/item/Free-Shipping-300pcs-Lot-CR2032-3V-Alkaline-Cell-Battery-Button-Battery-Coin-Battery-For-Watches/937032129.html
  • L.D.A.
« Reply #22 on: November 04, 2015, 05:40:18 pm »
Do you use this around your house for control ?  :-DD
Online Ian.M
« Reply #23 on: November 04, 2015, 05:42:57 pm »
No, because however much I prod it, the house never budges.
Offline Fungus
« Reply #24 on: November 04, 2015, 05:43:59 pm »
 :popcorn:
I guess 1000 of them is quite  a lot...but it would be soooo worth it.
Here's a video with 'only' 78:
