Author Topic: Dave's power supply mods.  (Read 42550 times)
Online firewalker
  • Country: gr
« on: January 06, 2012, 10:26:59 pm »
Post here you mods/ideas for Dave's design.
Alexander.
Offline Blue
  • Fighting for peace is like fucking for virginity
Re: Dave's power supply mods.
« Reply #1 on: January 07, 2012, 04:49:06 am »
Higher output voltage. E.g. 18V out...
Offline don.r
« Reply #2 on: January 07, 2012, 04:57:46 am »
Higher outputs would entail losing the resolution from the MCU. You may need to step up to 16bit converters. I always like extra fixed outputs like +/- 5V and +/- 12V along with the variable. Maybe with a fixed or switch selectable current limit. Easily done with 78XX/79XX parts.
Shippers: for the love of Pete and all that is holy, STOP USING UPS INTERNATIONAL!
Offline PeteInTexas
« Reply #3 on: January 07, 2012, 05:04:07 am »
Voltage and current presets.  I find that I actually only use a handful of voltages that correspond with common battery combinations- 1.5, 3.0, 6.0, 9.0 and so it is annoying to have to keep turning a 10 turn pot.  With the 12-bit DAC, I can imagine it will be similarly annoying with the rotary encoder.
It would really be great to just go to the voltage you want.  A 16-key pad mod would work using the 4 encoder pins plus the 4 pins from the 4 switches.  That still leaves too much twiddling for my tastes.
Unfortunately, the 4 encoders are not going into ADC pins so a resistor matrix cannot be used for preset switches.  They still can give 16 values for the software so it is possible to portion that out between voltage and current presets.  If the 4 switches can be similarly put into only two pins, one of the saved pins can be used to toggle between the presets and the rotary encoders.  The best of both worlds!
Offline PeteInTexas
« Reply #4 on: January 07, 2012, 05:39:43 am »
If preset switches ain't your bag, you can multiplex the four switches into 2 pins and use the 2 saved pins to toggle between 'coarse' and 'fine' encoder steps for voltage and current respectively.
Offline Bored@Work
« Reply #5 on: January 07, 2012, 05:59:15 am »
Ehm, one would do that by applying a dynamic-speed encoder profile. If you turn the encoder fast you do larger voltage or current steps (coarse). If you turn the encoder slowly you do fine steps.
Offline ndictu
  • Country: sk
« Reply #6 on: January 07, 2012, 06:15:18 am »
That's a great idea, and you just need a bit more code to do that so it'll be easy.
I kind of lost track of the discussion in the main thread, anyone knows what Dave plans on using for the code? It would be best on github/other VCS, so that everyone can easily submit their modifications and they will get merged to the "official" version.
Also, few ideas:
- use the serial link to connect multiple supplies together, using one as a master control for the others
- with isolated USB link you can do all kinds of stuff: log all the values, measure power consumption, automatically sweep over the voltage range and take measurements after some settle period etc...
- using a bigger uC and duplicating most of the supply circuitry you can transform it into a dual output supply. But I would probably rather build two of these.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #7 on: January 07, 2012, 06:32:03 am »
Dave has said that there is one thing he isn't telling us about the design yet. But that could be anything ;)
One possibility is that he is using an I2C expander IC, and using that to drive a standard LCD and key switches. I think a lower power version built into an Arduino shield could potentially be a good seller via Sparkfun, Adafruit etc.
Fancy things like battery charging, preset profiles and so on are all just software and can be left to the community. Such is the benefit of Open Source. Dave mentioned in the video the potential for an opto-isolated RS232 control and logging, which is easy to connect to USB via a cheap external interface.
Offline Bored@Work
« Reply #8 on: January 07, 2012, 07:09:23 am »
I had the impression it is more about the enclosure. And I seem to remember that in some older video he was thinking about a certain kind of enclosure for some projects.
Offline PeteInTexas
« Reply #9 on: January 07, 2012, 07:19:27 am »
This relies too much on ones coffee in take to finally get to the desired value.  I was thinking in the coarse mode each step cycles through the desired set of presets.  So for my 4 voltages, 3 twiddles at the most- 1 to flip to coarse mode, 2 to get to the desired voltage (you can go backwards).
Offline PeteInTexas
« Reply #10 on: January 07, 2012, 07:38:29 am »
Also, few ideas:
Good ideas but I make a distinction between a mod and a rework.  You are asking for a rework.
Offline Bored@Work
« Reply #11 on: January 07, 2012, 07:46:42 am »
Are you able to operate a computer mouse under the influence of coffee? If yes, you should be able to operate this, too. Because dynamic profiles are the norm for mouse operations since ages.
Offline PeteInTexas
« Reply #12 on: January 07, 2012, 07:51:29 am »
It took me a long time to perfect my mouse setting.  :-\
Offline Short Circuit
« Reply #13 on: January 07, 2012, 08:44:39 am »
Nonsense, if implemented correctly, that works marvelous. Course/fine switches on the other hand are a pain.
Always in the wrong mode, so twist, oops backtwist, toggle, twist again, toggle, fine twist.
I have a PSU that is operated like this and it sucks.
Offline PeteInTexas
« Reply #14 on: January 07, 2012, 09:06:24 am »
I'm guessing you harboring similar disdain for oscilloscopes?
Offline Rerouter
« Reply #15 on: January 07, 2012, 09:39:53 am »
For higher Voltage
(and this is only as a higher voltage modification 30.72V)
2 x http://search.digikey.com/us/en/products/MC33172N/497-7409-5-ND/1038900 op amps are pin compatible with u3 and u12
a few gain resistor changes;
2K in parrellel with R29
2K in parrellel with R31 (for a gain of 15)
10K in parrellel with R35
82K to replace R34 (for a maximum input voltage reading of approx 35.6V in, yeah not a pretty number, still working)
and for the mosfet, like a 82K resistor tieing its gate to ground, to divide input voltage by 2 (about 18V max), so its safe from 0 to 30.72V out,
For a keypad / more free pins
Hook up the keypad / existing buttons to a resistive ladder / matrix and in software make use of the adc function of the pin some of the buttons are currently on
For higher current
being how the LT3080 only requires 20mohm between regulators one could drill additional holes into the heatsink and mount regulators hooked up in parrellel, even with mod wire it would roughly be enough,
Offline shebu18
« Reply #16 on: January 09, 2012, 12:34:51 am »
This one would be nice for a dual powersupply. A LT3080 or a L338 that supports negative voltage and a bigger micro, and one more from everythgin plus some other parts.
The biggest problem vould be the box for the PSU.
Offline naimis
« Reply #17 on: January 09, 2012, 03:31:12 am »
mains inputs? Or am I being altogether too obvious?  ;D
Offline shebu18
« Reply #18 on: January 09, 2012, 04:00:41 am »
After rectifing, filtering and filtering again. I think you get arround 17V, even 14 will be ok.
Offline caroper
    • Take your PIC
« Reply #19 on: January 09, 2012, 08:10:21 am »
What I have in mind is to use 2 of Dave's Boards (or something based on his design) but keep them isolated and floating so that they could be connected in Series for grater voltage or a -V_0_V+ Supply or paralleled for a larger current output. They would have to be in close tolerance but I think Dave's design has taken that into account.  I would leave the MCU on the board for the sake of reading the Encoder and driving isolated communications via SPI or TTL Serial, but not worry to much about adding any advanced functions to it. Possibly not even a display at this stage as you could use a DMM to set the Current limit and Measure the Output Voltage.
Later I would add a separate control board, with a larger processor, to take over the display and control input functions, with software to add tracking and other optional capability's such as computer control, voltage sweeps, stepped patterns etc. for bench testing of devices.
As part of the CPU board I would include a relay control to automatically configure the outputs into Independent / Serial tracking / Parallel Tracking configurations. Because it has to be isolated from the 2 power channels and independently powered it could also provide fixed outputs of 3V3. 5V and possibly 9/12V if it is driving relays. thus providing additional common supply voltages and freeing up the 2 main channels for more productive tasks.
If i were to change the current design at all it would be to simplify it rather than add features.
Even with only 10bit resolution on ADC and DAC you could control 0->1024mA in steps of 1mA and 0->20.48V in steps of 20mV, which I think would be more than adequate for most hobby bench supplies and indeed exceed the measurement capability's of most hobbyist DMM's, so I would be inclined to use PWM and on chip ADC of the MCU rather than increase the cost and complexity with the external devices. For the same reason I would argue that the inclusion of the uCurrent is also an unnecessary expense. If I were designing something that had low voltage and current requirements, such as MCU devices that draw down to the uA range in sleep mode and nA normally, I would not be wasting 10's of watts of power by testing them on a bench PSU like this one. For those applications a precision PSU of 0->6V @ 0->10mA with very fine resolution would be a good investment.
Offline EEVblog
« Reply #20 on: January 09, 2012, 08:33:22 am »
They don't actually add a huge lot to the overall cost when you add it all up. It's not like the component cost suddenly halves by taking out those components.
This is a linear supply, it uses the same current as the device under test + some the power for the circuitry.
So a circuit taking say 1mA at 3.3V only takes 1mA from the input voltage as well. In this case the PSU circuit power dominates. I don't know what that is yet, but maybe another 20mA or so.
For those applications a precision PSU of 0->6V @ 0->10mA with very fine resolution would be a good investment.[/size]
That's what this supply is. A small precision 0-10V 0-2A supply with fine resolution.
0-10mA capability only would be a waste of space IMO and very niche, 0-100mA would be better but still very limiting, 0-1A makes it a very usable supply for general circuits.
Dave.
Offline caroper
    • Take your PIC
« Reply #21 on: January 09, 2012, 10:08:46 am »
I did actually intend 100mA the 10 was a typo, but point taken.  I was thinking of the voltage drop across the regulator as wasting power, but at only a few mA it is not dissipating much power at all.
I would still like to see 12->15 volts as the upper limit, but if they can be run in series it gives 20V for charging battery's etc and 10<-0->10 for driving op-amps in split rail mode so probably covers most bases.
My other problem with the external ADC/DAC is that you had to abandon through hole for them, not really the cost factor. But as you have said, it is for  precision with fine resolution so a valid compromise.
You may have to offer the KIT with those parts already mounted or you could lose a large potential market though.
EDIT:Spelling
« Last Edit: January 09, 2012, 10:47:23 am by caroper »
Offline EEVblog
« Reply #22 on: January 09, 2012, 11:08:28 am »
The ADC and DAC are both DIP parts, available in 10bit and 12 bit versions.
The current sense amps are the ones that are SMD.
They are only SO8, pretty trivial to solder. If I was to get just them assembled, then I might as well get the whole PCB assembled, as the cost difference wouldn't be much. Then you might as well go all SMD to lower the cost, and so on it goes...
Dave.
« Last Edit: January 09, 2012, 11:10:18 am by EEVblog »
Offline IanB
« Reply #23 on: January 09, 2012, 01:35:52 pm »
I really have no problem with SMD in a kit. It's not like soldering through hole components is actually easy. Sometimes through hole devices can be damned hard and annoying!
Offline EEVblog
« Reply #24 on: January 09, 2012, 01:48:50 pm »
Yeah, but most people don't see it that way, SMD scares them.
And SMD parts are a real PITA to kit up for and handle and sort etc, and people lose them, or can't read which cap is what etc.
That is why I don't do the uCurrent as a kit any more.
Dave.
Offline PeterG
« Reply #25 on: January 09, 2012, 03:33:00 pm »
Is there a need for a 'Basic' version of this kit, with just the board and parts?
Even a board without the micro but with marked pins for a micro to be connected not even a case. This would make it more flexible for those who want to make there own custom psu's. In my case, a Keypad and maybe a 4x20 rgb lcd all running of an Arduino Mega1280 board.
Just an idea.
Regards
Testing one two three...
Offline EEVblog
« Reply #26 on: January 09, 2012, 03:47:07 pm »
Yes, I expect some just to buy it for that.
Although the board is custom designed for my case, mounting holes mean it can be mounted in any bigger case on standoffs.
Dave.
Online firewalker
  • Country: gr
« Reply #27 on: January 10, 2012, 10:47:21 am »
I made a quick lookup at DigiKey for another linear voltage regulator with down to zero capability and... Didn't found one!
I thought there would be more than LT308x.
Alexander.
Offline JimmyM
« Reply #28 on: January 11, 2012, 07:14:16 am »
I was thinking that if an additional opamp (call it Ux) were placed between the opamp U3A and the LT3080. The output of U3A could go into the non-inverting input of Ux and the inverting input of Ux was connected to a voltage divider at the very end of the output. The output of Ux would then be connected to the input of the LT3080 where U3A was connected. Any voltage drops caused by current sensing, etc would be compensated for. Am I wrong in how this would work? This could also give a kelvin sense capability (at least for the V+ wire)
Would this be worth looking into since the LT3080/3085 does not have an external voltage sense connection. Also, the LT3085 is capable of 3 Amps which would amplify voltage drops caused by any i resistance between the output of the LT3085 (or multiple LT3080s)
Online firewalker
  • Country: gr
« Reply #29 on: January 11, 2012, 07:34:38 am »
I think you mean LT3083. LT3085 is 500 mA.
Alexander.
Offline JimmyM
« Reply #30 on: January 11, 2012, 10:01:09 am »
Alexander.
yes. Right. Sorry.
Offline EEVblog
« Reply #31 on: January 11, 2012, 11:14:48 am »
I think there are a couple of others from memory in some form, but that's what makes the LT308x special, unless you want to roll your own, or use negative supplies to compensate etc.
Dave.
alm
  • Guest
« Reply #32 on: January 11, 2012, 05:17:36 pm »
I'm quite sure that Dave wouldn't have picked the LT3080 if it didn't have a significant advantage over the common parts. An experienced desigs engineer like Dave will avoid specialist, singe-sourced parts if possible. If the circuit would have worked just as well with an LM317, this would be the superior choice, due to the availability it's much easier and cheaper to source, so much less likely to cause supply issues. The LM317 won't go down to 0V however without adding extra complexity, hence the exotic LT3080.
Offline siliconmix
  • Country: wales
« Reply #33 on: January 21, 2012, 08:17:31 am »
whay would you want to go down to zero ? ???
Offline IanB
« Reply #34 on: January 21, 2012, 08:23:30 am »
For instance if you wanted to check the low battery function with a single AA cell you would want to go down to 0.6 or 0.7 V. Since an LM317 bottoms out at 1.25 V it would be unsuitable for this application.
Offline siliconmix
  • Country: wales
« Reply #35 on: January 21, 2012, 09:01:09 am »
oops just watched the vid
Offline jpelczar
  • Country: kr
« Reply #36 on: January 21, 2012, 11:16:39 pm »
Another idea after watching Makerbot episode: how about providing a connector for the ATX PSU ? There are lots for unused PSUs lying around. This would allow for cool feature: power on/off by tact switch ;)
Offline mobbarley
« Reply #37 on: January 22, 2012, 12:00:18 am »
A bit bored today.. Do I win the title of the first mod?
PS: what have I missed?
Offline mobbarley
« Reply #38 on: January 22, 2012, 03:25:06 pm »
eagerly awaiting part 8 with details of the pcb / case so that I know if this will fit.....  ;)
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #39 on: January 25, 2012, 06:39:39 am »
I have already created the necessary footprints for the max parts and for the lm3080 and copied the schematic to Eagle, but I'm using an atmega644p instead and the front panel with the rotary encoders, buttons and display will be included in a separated board.
Offline Rerouter
« Reply #40 on: January 28, 2012, 03:34:13 pm »
Was just reviewing part 3 of the video and picked up on the fact that the constant current source only works down to 0.8V, but with daves external one, seemed to go down to 22mV,
it would seem with a fet with a 400mV threshold, and driven at the 2.048V reference would capable of handling down to the last 8 bits or 20mV, while it would sink 27mA under the highest voltage, i felt i would just raise the suggestion,
perhaps using another op amp, one could invert the gain of Vset and have it level out would be the solution to that,
also i realise there is little need to get that low, but at a guess atleast one of us must be interested in that capability,
Offline JimmyM
« Reply #41 on: January 29, 2012, 12:28:40 am »
Keeeeep talking. I like what I'm hearing.
Offline george graves
« Reply #42 on: January 29, 2012, 01:31:49 am »
I hope there are some pre-set voltages.  Seems a waist to have a micro in there if it's not going to do the work for you.
Also - wouldn't mind a bigger screen, and big readable fonts.  Not that my eye sight is bad, it just makes it easier to read out of the corner of your eye, or at a quick glance.
Oh and a cool case - it's gotta have a cool looking case.  I wish there was a generic version of something like this available:
A keypad would be cool - but I'm not sure how useful it would be.
Or - I might make something out of wood and stain it - this guy used an old hard drive for the top and bottom.
« Last Edit: January 29, 2012, 06:23:15 am by george graves »
Offline Rerouter
« Reply #43 on: January 29, 2012, 01:43:42 am »
the 4 buttons will be left to us to chose there purpose,
also are there any downsides, (oscillations, offsets, etc) from using mosfets to switch op amp gains,
as it would be nice, wanting higher voltage ranges, to switch down the gain as i fall below 10V and regain the original accuracy,
Offline PA3BNX
  • Trying to learn better programming and designing !
« Reply #44 on: January 29, 2012, 06:26:02 am »
Hello Every Body out there,
I have a question for Dave and his new designed powersupply.
Will it get a so called foldback current mechanism in software.
I mean if I short the power supply for longer as lets say three seconds
Will it switch the Current down to zero mA and the Voltage also to zero Volts?
So that I have to reset it before the Voltage comes up again ?
Greetings,
Lodewijk
Credo:
Home brew projects:
Build/Design  with minimum hardware
and maximal software.
Offline Rerouter
« Reply #45 on: January 29, 2012, 07:50:42 am »
once again, i would think that would be something you might have to go enable, just because some people will want foldback and some will want it to hold, also the device itself will foldback at 1.2A, in thermal protection mode,
Online ejeffrey
« Reply #46 on: January 29, 2012, 08:13:13 am »
I am sure you could implement that, but foldback current limiting is not normally wanted in a lab supply and what is normally meant by it is not actually what you have described.
The normal purpose of foldback current limiting is to protect a fixed voltage linear power supply in case of a short circuit.  The problem is that when a load exceeds the current limit, the voltage will start to drop, but this increases the power dissipation in the pass transistor.  In the ultimate limit, when you have short circuited the output, the pass transistor(s) are dissipating more than 100% of the supply rating.  Bipolar transistors also have second breakdown which further limits their safe operating area.  Foldback current limiting uses a separate analog feedback loop to reduce the current limit and keep within the transistor SOA when the output voltage is below the setpoint.  Generally once the short is removed the supply will recover naturally -- it doesn't require a hard reset.  Of course, if the short circuit is caused by a crowbar circuit, it won't reset until the power is removed.
A software defined limit with a 3 second delay is not nearly fast enough to provide protection for the majority of circuits that need foldback current limiting.  That might help if your thermal limit is an undersized heatsink, but more often you have to deal with the package juction->case rating or second breakdown.  These time constants are quite fast, 3 seconds is much too long.
In any case, by design a bench supply must not be susceptible to such overloads.  The supply has to be able to survive being programmed to the lowest possible voltage and the highest possible current.  The transistor doesn't care whether the set point is 10 volts and drops to 1 volt due to the current limit, or whether the setpoint is 1 volt.
In any case, the LT3080 has built in thermal protection.  If you do manage to overload it, it will shut off to protect itself.  However, this would be a sign of a design error, or use of the supply outside its design parameters (i.e., too high ambient temperature).
If you want to protect the device under test rather than the supply, that would normally be considered overcurrent protection, and then you would generally design it to shut off the supply until reset.  There are not that many situations where you need overvoltage / overcurrent protection, and again, usually 3 seconds is way to long -- if you are powering a very delicate transducer or something, normally you would want to shut off the supply within microseconds.
Offline Rerouter
« Reply #47 on: January 29, 2012, 08:19:41 am »
or in those cases, you would set the maximum current just above expected current of the device, so that it holds there, and will fall to near 0V if a bad short was made
Offline amspire
« Reply #48 on: January 29, 2012, 09:48:48 am »
I don't think foldback current limiting has any place in a lab power supply.
If you set the current to 1A limit, you want it to limit to 1A, and not an unknown current that you haven't specified.
In using a power supply, I am using it regularly as a current source, and also in testing a new circuit or a faulty circuit, I want to be able to set the voltage and slowly wind up the current limit. Last thing I want is foldback decreasing the current as I am trying to increase it.
Foldback has a place in some fixed output voltage supplies where the regulators cannot maintain full current at 0V, but I would never build a variable lab supply that cannot maintain full current at 0V.
Richard.
« Reply #49 on: January 30, 2012, 12:02:17 am »
I think it is pretty good as a low power PSU with a really accurate output voltage setting ability. If you wanted a higher rating then you would not need the resolution, and a higher current rating with lower resolution would be perfect. It is a precision supply, good enough to use as a 4 digit reference voltage, or a 3 digit current source. Would be good to build in a small case and have a companion ( same software and interfacing but coarser steps) lookalike that does 0-40V at 0 - 5A, possibly using a multitapped transformer to reduce dissipation in the regulator stage. You could even build them into a larger case if you made the precision one a floating unit, though them your interfaces would need to be opto isolated if you were going to have remote setting ability. a 2/4 port USB hub and 2 USB to RS 232 converters and a set of opto isolators would do that, then a single USB socket on the back will do. The extra USB ports could then be front panel mounted for convenience - extra points to connect a USB scope that is still isolated from the power supply rails.
Offline PA3BNX
« Reply #50 on: January 30, 2012, 06:03:00 am »
Hello EveryBody,
My goal for foldback was simply when something unattended was running
and going bad that it switches off..
So no smoke in the device under test while away ?
I assume  that the Power Supply it self can with stand
the shortage.
If I put a a load with a big capacitor on the output of the power supply
then it should not foldback.
That's what the 3 second delay should be for.
It would be nice if you could see at what time the error function did occur.
Greetings,
Lodewijk
Credo:
Home brew projects:
Offline Rerouter
« Reply #51 on: January 30, 2012, 06:28:01 pm »
that would all be possible through rolling your own code for it, say mapping one button to foldback/monitor,
Offline Rerouter
« Reply #52 on: February 02, 2012, 07:32:50 pm »
well, after playing around with the design to handle a higher voltage range (30.72 - 10mV), this is a section that i feel need a second set of eyes on,
http://i.imgur.com/RTuhq.jpg
the current source is replaced with an error amp fet, driven at ~1mV, and the capacitor was to prevent oscilations at low loads, though i feel it may be an incorrect value,
the main output gain is stepped up to 15, and by pulling the fet on the gain down, it swaps back to ~10.24V, although 100K's would be more accurate, its getting into the noise for the op amp i think, and may be wrong on it,
the actual op amp model can be ignored, i havent updated it since the rev A board was released, and will need to be a rail to rail if not already,
other than that, i flipped the voltage setting portion around to try and tidy it up, and hoping for some constructive input,
« Last Edit: February 02, 2012, 09:10:56 pm by Rerouter »
Offline Rerouter
« Reply #53 on: February 02, 2012, 09:43:09 pm »
And now the compliment sense line(s) http://i.imgur.com/S4pCJ.jpg
the fet once again switches between a gain of 5, and of 15, but my primary concern is, with the input clamped through 20K, even worse case, with the fet left off, would the 1.2mA passed by the diode clamp actually interfere with the reference in any measurable level? (30V/25K*5K =6V, 24V/20K = 1.2mA)
the reason why i want to clamp to the reference is, the op amp feeding the adc can possibly pass more current than its internal clamps can handle, and so want to minimise the risk,
« Last Edit: February 02, 2012, 09:47:16 pm by Rerouter »
Offline amspire
« Reply #54 on: February 03, 2012, 12:33:09 am »
Rerouter,
You have some ideas that can work, but you might be over complicating things.
First though, if you use a single LT3080, then if you want to output to go to over 30V, then you will have to reduce the current to about 250mA. Alternatively, you parallel 4 LT3080's at the cost to a slightly degraded voltage regulation due resistors you have to add to the LT3080 outputs.
Which way were you thinking of going?
Now Dave had some very particular design restrictions, that meant he absolutely had to be able to run his design from a single supply. 30V+ output sounds like you have a transformer, and once you have a transformer, getting a low current negative supply only costs some cheap diodes and capacitors (even if the transformer is just a single winding) and perhaps a 79L05 regulator. It would be nuts if you can have a negative supply, to not use it. You get much better regulation even at 0V out, the current source fed from the negative rail can sink down to 0V without any problem, you can use easy-to-get LM317's instead of LT3080, since you can offset the control voltage by -1.25V. A rail to rail opamp trying to work at 0 V does not work as well as a standard opamp with a negative rail working at 0 volts.
I haven't looked at the specs for the A/D. Does it need to be driven from a low impedance source, or can you add a series resistor to the op-amp to limit any overvoltage current?
Richard.
Offline Rerouter
« Reply #55 on: February 03, 2012, 05:50:23 pm »
was thinking of a switching pre-regulator, biased to run approximately 5V above the output of the LT3080, so that the full 1.4A would be always available, and simply use an LC filter to cut out anything above 1KHz, though that will be slightly new to me (datasheets one is 20V)
30V+ output sounds like you have a transformer, It would be nuts if you can have a negative supply, to not use it.
i have a dual 35-0-35 transformer (68W), it would help with the current source, due to the voltage limit, and the op amps, but short of the current limit, i was thinking of ways to modify Dave's kit with minimal impact, and with options that might help others who don't have access to transformers, or not willing to buy them (laptop plugpacks spit out 24-30V)
it can have 1K without any noticeable offset going by the datasheet, so i guess i could loose the clamp.
suggestions for higher quality DAC / ADC? as i was planning to write up a function to measure low resistances, (2 sense lines, accurate voltage applied and current measured with ucurrent) but the current ones are far too off to manage more than relative changes.
Offline jgbena
« Reply #56 on: February 04, 2012, 04:32:33 am »
Alexander.
I already saw Higher voltage, but what about 0-9 Volts, and 0-3amps instead of 1?  would that also be just a matter of changing software code and losing some resolution in the voltage and current step values?
Offline Rerouter
« Reply #57 on: February 04, 2012, 09:00:46 am »
jgbenga, the LT3080 cannot supply more than 1.4A, you would need to use its big brother the LT3083, to get 3A, being how you are only aiming at such a low voltage is would almost be a direct swap in,
Offline kiyotewolf
« Reply #58 on: February 04, 2012, 06:19:16 pm »
I'd love to have it have a screen saver mode, where the LCD on bottom line, spouts Dave Jones quotes.
Also, a piezo beeper, so it can play little chirps, or warnings, or even, tunes?
A way to pick colors you want on the screen, so you can change it around later.
~Paul
Offline Rerouter
« Reply #59 on: February 04, 2012, 06:29:59 pm »
the colours can be picked, so far all 3 colour channels of the lcd are wired to the micro, so pwm could be implemented, as for the screen saver thing, that would be something you might have to write in yourself, as most people want a power supply to maintain its display whether its been on 30 minutes of 100 hours,
as for the buzzer, that would probably be something you would need to mod in, for a simple buzzer, an NPN driver for a buzzer off the I/O chips,
for actual tones / alarms probably better to hook in something else running on i2c to accomplish that, as the micro will be doing a fair bit of correction if you hook it on to an active load, and you probably wouldnt want to chew up its cycles with producing a tune,
Online ejeffrey
« Reply #60 on: February 04, 2012, 09:09:13 pm »
Are you by any chance designing hand-held instruments for agilent?!
Offline Rutger
« Reply #61 on: February 05, 2012, 10:51:05 am »
Dave, I was looking at the different options for the DAC, because I was looking at the dual version of your power supply (eg with a negative output as well) and came across the following 4 channel 12 bit DAC:
MCP4728-E/UN  at $ 1.44 / 100 with build in voltage reference (optional).
I know you didn't want surface mount parts but with the Maxim 4080 and the voltage ref chip you have chosen that option is already gone.
The advantage of having the extra 2 channels is that you can add/drive another power supply from the same DAC. And you can save on the cost of the parts, maybe you eliminate the external voltage ref chip.
Rutger
Offline caroper
    • Take your PIC
« Reply #62 on: February 05, 2012, 11:12:18 am »
... or even, tunes?
~Paul
Who needs Overload protection when you PSU can play "Smoke on the Water, Fire in the Sky" :)
Joking aside, that is actually a good idea, not so much the tunes, but a beep to confirm a setting or a short alarm if CC  Mode is entered or an error condition occurs.
Cheers
Chris
« Last Edit: February 05, 2012, 11:14:49 am by caroper »
Offline kiyotewolf
« Reply #63 on: February 08, 2012, 03:52:29 pm »
Yeah, since the whole thing is open source, (right??), then I was thinking of modding in the little things like the tunes.. (the EEVBlog theme video end diddy, .. when it shuts off..), and the display doing EEVBlog quotes..  (as it boots, "Don't turn it on, take it apart!")
I really like having little favorite themes of colors for the RGB LCD, in case you've got mood LED lighting in your lab.. .. or for other fun reasons.  (Make it play smooth jazz chip tunes while doing little glowing of reds and oranges, like a miniature fireplace.. while powering a ... <insert thing to be powered here> )
~Paul
I was fascinated watching Dave modify the code right on the screen, and how he was able to send out serial data, twiddling the bits all by himself.
Offline EEVblog
« Reply #64 on: February 08, 2012, 04:01:47 pm »
Which of course would have been much harder to do if I followed the advice of the "software professionals" and used a for loop instead of my "shit" code that isn't good enough for production ::)  :P
Dave.
Offline jgbena
« Reply #65 on: February 09, 2012, 06:55:24 am »
Thanks Rerouter, ill give that a look!
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #66 on: February 09, 2012, 01:30:46 pm »
Here is my take/interpretation of Daves power supply, the pcb's have been ordered and the parts are already in Portugal.
I have maintained Dave's credit in the silkscreen and this is will be a public project in the portuguese LusoRobótica forum, it uses the smd version in the dac and the adc and also an atmega644 instead of the 328p used by Dave, it is still a beta version and I plan to shrink it a bit/a lot and make some more changes to the layout.
« Reply #67 on: February 09, 2012, 01:44:15 pm »
Nice work!- Now many extra pins does the 644 give you over the 328?  Are you programming it as a "sanguino?"
Looks great!
Offline sacherjj
« Reply #68 on: February 09, 2012, 03:36:17 pm »
I like the break out of the sense and + separately.  Allows no burden validation of current, without the uCurrent.  (Not sure if you built that in as well.)
I'm thinking about a simpler 328 based PSU, with using the onboard ADC and PWM.  I'm currently working on a 328 based 40 V and 4 A Constant Current Sink first, but imagine the ADC and PWM experience with that will help with that.  But since I only have one decent lab PSU right now, I'll probably get this kit as well if it isn't too terribly expensive.
Although, I hate not having the mains to the inside of the box, due to parasitic power draws or separate unplugging or power switching.  But, I might think differently if it was 220v vs 110v.
Offline electrode
« Reply #69 on: February 09, 2012, 03:50:15 pm »
Wow, that looks pretty nice. Good choice of microcontroller too - 12 extra pins (answering george's question) and fully Arduino compatible.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #70 on: February 09, 2012, 05:08:01 pm »
Thanks, I will share all the files when I'am sure that there are no errors, and yes the uCurrent is also present in this power supply.
The atmega644p as said by electrode as 12 extra pins, there will be an extra board that will serve as the front panel, for now the only displays that I have are two like this:
http://www.ebay.com/itm/0-96-128X64-OLED-LED-Display-Module-PCB-Adpater-/160556409041?pt=LH_DefaultDomain_0&hash=item2561e860d1
They are pretty tiny but can be read from pretty far and I will make a large font, and I have left access to the i2c and its possible to use any 8 bits parallel display using the SPI interface to drive some shift-registers, so it can be pretty flexible, one friend of mine wants to have one small bench supply and wants to learn how to use Eagle, so probably he will design a front panel to use with regular 16x2 char displays so I can teach in with a real project and I will make one for the small oLed.
The programming is done using AvrStudio and avr-gcc but its very easy to port to Arduino, and as the design I will put everything in my Google Code page.
If some one is interested here is my blog where I still only have some programming tutorials for avr:
http://hekilledmywire.wordpress.com/
Offline Zad
« Reply #71 on: February 10, 2012, 03:35:53 pm »
If you are using SMD ICs, why not use 1206/0805 passives too? If you can solder a QFP or SOIC, you can sure as hell solder an 0805!
Offline Rerouter
« Reply #72 on: February 10, 2012, 05:36:04 pm »
because a lot of hobbyists aren't keen to solder SMD's unless they really have to, and SOIC's are about as basic as SMD IC packages get,
Dave made this thinking any man with a soldering iron of no notable quality could make it himself, (or herself?) without much experience, as a kit
Offline electrode
« Reply #73 on: February 10, 2012, 05:38:55 pm »
I think Zad's comment was directed at senso...
I only just got into 0805s last year. Easiest way to save board space ($$$) with footprints that "even Stevie Wonder could solder". :)
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #74 on: February 11, 2012, 07:09:17 am »
I used the SOIC footprints for the ADC and DAC's because I already have then, the MAXIM parts only exist in soic or smaller, and the atmega644 in a 40 PDIP would be huge, the next iteration of the board will probably have almost all the components in SMD, and this will be first smd's that I solder, I already have some flux syringe and an JBC soldering iron with a chisel tip, wish me luck.
Offline electrode
« Reply #75 on: February 11, 2012, 10:26:53 am »
A good tip for if you don't have the gear or experience with SMD stuff is to make your pads longer. That way you can drag the excess solder back and the bridged pins will naturally separate beautifully. One of the EEVBlog vids did this.
Offline sacherjj
« Reply #76 on: February 11, 2012, 12:58:10 pm »
I found the cheap hot air iron to make life great with SMD.  Add some GOOD tweezers.  With that, I found it almost painless to do 0402.  Squirt on solder paste.  Add some paste flux.  Use tweezers to place component close.  Use hot air iron to melt solder paste and watch the 0402 align itself with the pads.  Pretty cool.  But if you are designing the board, use bigger components!  :)
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #77 on: February 11, 2012, 01:23:37 pm »
At home I have my soldering iron, flux, some fine non magnetic tweezers, fine solder and solder wick, but if everything fails in the university I can ask to use an IR soldering oven, hot air station and lots of Weller soldering stations, as I have bought the pcb's from Itead I will try first in the non E-tested boards.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #78 on: March 06, 2012, 02:21:22 am »
And the first pcb's finally arrived from China, 3 weeks for manufacture and shipping via slow boat, doesn't seems too bad for me, especially due to the price that I paid for them.
The silkscreen took me more time to clean than to lay out the entire pcb, and even then it has some errors/extra text that I didnt noticed.
Here are some not that good photos:
« Reply #79 on: March 06, 2012, 09:55:22 am »
Looks good.  Looks like you might have a break in the ground plane - at the ground pin of ICSP header?
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #80 on: March 06, 2012, 01:04:58 pm »
It is grounded in the top ground plane, so it is in fact grounded, not a very good ground, I usually add vias to connect top and bottom ground planes.
Its funny that only the board in the photos as all the vias tented, all the others have some tented and others are not, kinda like random..
I also soldered my first SMD and it was pretty easy  :o
Put some flux in the pads, IC on top, hold with tweezers and a tiny amount of solder in the tip is enough for all the IC, really fast, I'm for sure converted!
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #81 on: March 06, 2012, 01:11:43 pm »
Does the back and forth wander on the header holes have a purpose?  I dont know much about PCB design, just curious.
« Reply #82 on: March 06, 2012, 01:16:18 pm »
Ah!  I see now.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #83 on: March 06, 2012, 01:56:13 pm »
They are from the Sparkfun library, they call it Lock, they are off-set by 5 mills if I'm not mistaken and their purpose is that you push the headers in the holes and due to the offsets the headers get locked in placed and aligned so they are easier to solder and you dont end with crooked headers, they are really helpful when assembling the pcbs.
I dont know if Dave sees this topic, but if you are there, are you willing to share your actual code for the uSupply?
Offline EEVblog
« Reply #84 on: March 06, 2012, 02:20:04 pm »
Here is whatever is on my machine at present.
No correspondence will be entered into  :P
Dave.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #85 on: March 07, 2012, 02:43:52 pm »
Thats pretty simple for now, but well its just a power supply...
My personal version as a graphic display so I will add some current plots and who knows what more.
First board is almost complete, forgot to order some of the components and ordered the MAX4080 in the wrong package  ::)
Offline electrode
« Reply #86 on: March 07, 2012, 02:51:02 pm »
Looks really nice. The header locations look convenient too.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #87 on: March 07, 2012, 09:14:23 pm »
One sanity check please, the uCurrent is only activated when the mosfet is turned on, and that only happens when 3.3v(high signal) is given to the 2n3904 transistor, I'm right or is it the other way around?
And sorry for not doing the homework, but what is the current threshold where I can safely enable it and not fry the MAX op-amp?
I dont know about how you will be distributing your code, but I will use a google code repository, so any-one that wants to take a sneak peek can go there, I will also offer pre-compiled hex files ready to program the atmega.
Is any one willing to try one board, I have 9, all of them e-tested and eye tested and seem to be fine, so far the only error is the 3.3v regulator must be inserted backwards ( swapped Vin with Vout  :-[ ), for some reason I used the wrong part and even with the datasheet open in front of me I didn't notice that.
I hope to have all soldered this week and at least some code doing an hello world.
Offline EEVblog
« Reply #88 on: March 07, 2012, 10:44:04 pm »
FYI, I'm currently doing Rev 3, some major changes in store!
That's what happens when you leave a project for so long, you always get other ideas...
I think it's for the better though.
Dave.
Offline electrode
« Reply #89 on: March 07, 2012, 10:46:31 pm »
Major == SMD?
Offline McMonster
    • McMonster's blog
« Reply #90 on: March 07, 2012, 11:04:33 pm »
My guess is reducing BOM or going to full SMD.
Offline EEVblog
« Reply #91 on: March 07, 2012, 11:04:52 pm »
Major == SMD?
SMD is part of it, the through hole kit just wasn't really going to be workable.
I'm removing some stuff and adding some other stuff!
Dave.
Offline EEVblog
« Reply #92 on: March 07, 2012, 11:09:25 pm »
Both, plus more.
Revising designs is half the fun ;D
Dave.
Offline McMonster
    • McMonster's blog
« Reply #93 on: March 08, 2012, 12:39:56 am »
Both, plus more.
Dave.
If revision 3 can make coffee and order pizza then I'm getting at least two.
Offline mtkaalund
« Reply #94 on: March 08, 2012, 02:49:19 am »
Would it not be easier to get a girl friend that can do tha... your right, if rev 3 can make coffee and order pizza Im also getting two ;)
"Keep buggering on" -- Winston Churchill
VIR => V = I*R, neat ;)
Offline markus_b
« Reply #95 on: March 08, 2012, 02:56:19 am »
I've privately toyed with a variant based on a xMega. Enough ports for everything and has 12bit AD and DA on board. Reduces the BOM an awful lot. You can program these babys with Arduino too, if you want.
The other extensions I feel useful is input voltage up to 35 Volts and current up to 3 amps (3 3080 in parallel).
Markus
A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible.
Offline scrat
« Reply #96 on: March 08, 2012, 08:43:42 am »
Could a remote output voltage sensing and/or an external analog input reference be useful?
I see them as little mods, just adding one or two opamps, and using one ADC spare channel (at least in an early revision) and the uC ADC for the reference. Choosing between internal and remote sensing is usually one of the features of a precision PSU (although it could just be an hardware ORing), while the external reference could allow one to use their PSU for testing some controller (an example? A DC motor controller).
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
Offline tom66
  • Electronic Engineer & Hobbyist
« Reply #97 on: March 08, 2012, 09:00:55 am »
If the 3080s become expensive, maybe move to a power Darlington transistor or a P-channel MOSFET with a different driver circuit? Disadvantage - no current sense or temperature sense on die, but first current sense is done by the 317T and temperature sense could be done with an external thermistor and NPN to pull the drive signal low as an emergency cut off.
Opened up my Tagasaki power supply I got a while ago. 0-35V 0-3A. Quite interesting construction - the circuit is very similar to Dave's but no micro of course. Just two single op-amp packages, I think they were similar to 741's, and a few passive carbon resistors. Some 10W resistors x 3 for current sense. And a TL431 for voltage reference. What I found really clever though was how they were choosing taps on the transformer to reduce power dissipation in the 3 x 2N3055's (on a massive heatsink.) They used some kind of SCR devices I think but I never quite figured out how they got them to fire - I'm almost certain they weren't using any logic, probably just biasing the gate somehow so it fired when the output voltage was past a certain point...? The transformer in the power supply was easily the heaviest part, and the power supply is only capable of 105W output max.
Nowadays with modern laptop SMPS's going spare you can easily find a 20V DC power supply so there's no need to use a big bulky transformer. You could even get the laptop SMPS to follow the output by a couple of volts to significantly reduce power dissipation. There's probably a way to tap into the feedback to do this. I've done it before with an ATX supply but only increased voltage (12V -> 26V) not decreased it.
« Last Edit: March 08, 2012, 09:02:59 am by tom66 »
« Reply #98 on: March 08, 2012, 11:59:49 am »
I guess I'm starting to worry about the price!  (not too much - it looks like this kit is going to be a must-have, and a great bang for the buck!)
Will SMD increase the cost?  Decrease it?  I'd assume that you'd be doing a lot less labor with SMD as you wouldn't have to sort out all the parts and put them into a bag.
Offline EEVblog
« Reply #99 on: March 08, 2012, 12:26:49 pm »
Yes, SMD will be cheaper and less hassle for all involved, albeit at the expense of losing the satisfaction of having soldered it yourself for some people.
Dave.
Offline Zad
« Reply #100 on: March 08, 2012, 12:40:39 pm »
In this weeks' The Amp Hour, Dave points out that the regulator chip is now available in a switched mode equivalent.
Just sayin'....
Offline EEVblog
« Reply #101 on: March 08, 2012, 05:07:37 pm »
Close, but no cigar.
I think I'll shoot a new video tomorrow revealing all.
Rev 3 is coming along nicely and I'm quite pleased with this version. I've eliminated some chips, lowered some costs, increased some functionality, and improved the build at the same time.
Dave.
Offline dougg
« Reply #102 on: March 08, 2012, 06:20:58 pm »
Just tried to hack up a USB power supply from a 5 volt, 2 amp switched mode wall slug. With USB D+ and D- floating it didn't work on two different tablets (HP and RIM). Then I followed Dave's power supply schematic which puts 2 volts on both with separate resistor dividers. That did not work either. The appropraite reference to look up is "USB dedicated charger". Seems that the USB folks standardized shorting D+ and D- together circa 2010. When I did that, it worked.
Offline EEVblog
« Reply #103 on: March 08, 2012, 06:47:30 pm »
The iPhone/Pad/Pod is apparently different and requires those voltages.
Dave.
Online Monkeh
« Reply #104 on: March 09, 2012, 12:22:11 am »
Dave.
Yes, Apple aren't big on this whole standards thing.
Offline sacherjj
« Reply #105 on: March 09, 2012, 01:05:26 am »
I thought the D+ D- tie was a change that allowed 1 A through USB for charging, rather than just 500 mA.  If those are not shorted, you are only allowed to pull 500 mA.
Offline mtkaalund
« Reply #106 on: March 09, 2012, 01:19:06 am »
I believe that the specification for the USB standard, says that 500mA is the maximum allowed current through an USB port. But correct me if I am wrong :D
Offline Hideki
  • Country: no
« Reply #107 on: March 09, 2012, 03:08:13 am »
500 mA was correct for a long time, but as time went by various useful things were added to the specification.
See http://www.usb.org/developers/devclass_docs for the Battery Charging Specification documents.
Online Monkeh
« Reply #108 on: March 09, 2012, 03:29:09 am »
500mA is the maximum current a USB 2.0 port can supply to a device, unless it complies with the USB Battery Charging Specification. Shorting D+ and D- is required to indicate a dedicated charging port, which can supply up to 5A.
USB 3.0 includes support for up to 900mA at reduced voltages (making allowance for cheap, nasty cables, basically).
Offline dougg
« Reply #109 on: March 09, 2012, 03:34:31 am »
"The great thing about standards are that there are so many to pick from." You were correct but as one standard supersedes another you are probably not correct now. I am familiar with SCSI standards and recent USB-3 external disks should be using UASP rather than the (dreadful) mass storage class (block mode). I'm still looking for the first example in a real product.
Offline EEVblog
« Reply #110 on: March 13, 2012, 09:35:07 pm »
Part 11 is rendering now, the biggest and most rambling episode yet, at 1:15min!  :-[
The true original purpose of the PSU will be revealed, along with the substantial changes.
Damn, 1:15min, I must be insane. Now I'm thinking if there is somehow a way to split it?...
Dave.
Offline markus_b
« Reply #111 on: March 13, 2012, 10:08:54 pm »
Dave, just keep it like it is. People always can fast-forward !
Markus
Online firewalker
  • Country: gr
« Reply #112 on: March 14, 2012, 12:07:58 am »
I am guessing 4xNiMh batteries and a boost convert.
Alexander.
Offline Tooms
« Reply #113 on: March 14, 2012, 03:52:13 am »
Dave.
love them as they are, so dont split it.
Tooms
Offline sacherjj
« Reply #114 on: March 14, 2012, 07:33:07 am »
Am I the only one that checked about a dozen times today, each time when I got back to my desk, for a new 1:15 monster video on YouTube?
Offline Noize
« Reply #115 on: March 14, 2012, 09:18:10 am »
No  :)
Offline PeterG
« Reply #116 on: March 14, 2012, 11:55:13 am »
Its getting on  for midday. I am thinking something may have gone horribly wrong with the video causing delays. :(
Regards
Offline IanB
« Reply #117 on: March 14, 2012, 12:49:45 pm »
Yup, it's been hours and it hasn't appeared yet. I think Dave broke YouTube  8)
Online BravoV
« Reply #118 on: March 14, 2012, 12:59:46 pm »
Nah .. after waking up this morning, Dave decided to scap and redo new version again, and going to re-shoot the vid ...
....j/k. :D
Seriously, I think he hasn't upload it yet and probably he was rendering it overnight.
Offline EEVblog
« Reply #119 on: March 14, 2012, 01:45:48 pm »
I decided to try splitting into two, a hardware/case part, and the schematic part.
Plus I had to baby sit Sagan for half the day!
Dave.
Offline mtkaalund
« Reply #120 on: March 14, 2012, 08:18:47 pm »
Dave.
When can we expect the schematic part? I was looking forward to see it, but i like the system design aspect of this video.
Sagan, an electronic engineer in the making?
Offline EEVblog
« Reply #121 on: March 14, 2012, 09:12:46 pm »
It STILL doesn't have Bluetooth!!?
It's got a socket with SPI interface, plug in anything you want!
Dave.
Online firewalker
  • Country: gr
Offline PeterG
« Reply #123 on: March 15, 2012, 09:03:55 am »
To my thinking, Bluetooth makes more sense than Ethernet. I think Ethernet defeats the purpose of being battery powered and portable.
I would have liked to see the accuracy increase rather than decrease. It would be great to have 1mV and 1mA accuracy but i feel that is outside the scope of this project for now.
But thats just my 2 cents.
Regards
Offline McMonster
    • McMonster's blog
« Reply #124 on: March 15, 2012, 09:23:39 am »
Regards
I agree, it'd be nice to figure out a way to either plug a Bluetooth or Ethernet module there.
Offline markus_b
« Reply #125 on: March 15, 2012, 09:33:17 am »
The Bluetooth module is easy, you can use the Arduino-compatible serial connector to connect  it. A Bluetooth module needs Gnd, 3.3V, RX and TX. These are all there.
Markus
Offline McMonster
    • McMonster's blog
« Reply #126 on: March 15, 2012, 11:28:08 am »
My thought was "something that fits there without some hacking or bodgy wires". The socket would be most likely placed so it aligns to the hole in the case and there's probably no direct replacement BT module that would match the socket pins. So we're either mount the module somewhere else and do some wiring or design a custom daughter board that can be plugged nicely, fit's the space and is mounted securely for moving the whole unit. Not that someone would play american football with the PSU, but if it's portable then the construction must be prepared for thing you don't do with most of the bench equipment. Or at least it must be built like old school bench hardware, I'm pretty sure I can airdrop my Wavetek without a chute and it'll survive. :P
Offline sacherjj
« Reply #127 on: March 15, 2012, 12:15:56 pm »
I'm betting there would be space to have an adapter board, with pins and headers.
