One sanity check please, the uCurrent is only activated when the mosfet is turned on, and that only happens when 3.3v(high signal) is given to the 2n3904 transistor, I'm right or is it the other way around?
And sorry for not doing the homework, but what is the current threshold where I can safely enable it and not fry the MAX op-amp?
I dont know about how you will be distributing your code, but I will use a google code repository, so any-one that wants to take a sneak peek can go there, I will also offer pre-compiled hex files ready to program the atmega.
Is any one willing to try one board, I have 9, all of them e-tested and eye tested and seem to be fine, so far the only error is the 3.3v regulator must be inserted backwards ( swapped Vin with Vout
), for some reason I used the wrong part and even with the datasheet open in front of me I didn't notice that.
I hope to have all soldered this week and at least some code doing an hello world.
