Author Topic: eevBLAB #8 - New Tektronix AGO3000 Oscilloscope  (Read 40751 times)
Online EEVblogTopic starter
« on: March 31, 2015, 09:26:03 am »
Dave talks about Tektronix's new unreleased AGO3000 Gravity Compensated Oscilloscope with a high precision TCXO timebase with 2G tip-over gravity compensation.
Datasheet: http://info.tek.com/rs/tektronix/images/AGO3000_Gravity-Compensated-Oscilloscope_DataSheet.pdf
Preliminary product launch page: http://info.tek.com/ago3000-scope.html
Offline leppie
Re: eevBLAB #8 - New Tektronix AGO3000 Oscilloscope
« Reply #1 on: March 31, 2015, 09:58:51 am »
I saw no glitches in this video.  Fingers crossed, it is fixed.
The video is using the Sony Gravity Compensation post-processing filter to cater for northern hemisphere viewers.
Offline trevwhite
« Reply #2 on: March 31, 2015, 10:18:31 am »
What is the Agilent counter you use in the video?
« Reply #3 on: March 31, 2015, 10:22:18 am »
53131A
Offline German_EE
« Reply #4 on: March 31, 2015, 10:36:18 am »
I have a ten-digit counter in my workshop that has a TXCO, I also have a 10 MHz source that is locked to the 77,5 KHz DCF77 signal. Yes, I have seen variations of +/- 0.5 mHz depending on the orientation of the TXCO but I have also seen variations due to the following:
Ambient temperature
Humidity levels
Mains supply
Time of day
Vibration
Internal equipment fans
Magnetic and RF fields from other equipment
I wonder how the engineers in Tektronix compensate for these other variations, some of which cause 10x as much effect as gravity?
Warren Buffett
Offline kcs
« Reply #5 on: March 31, 2015, 10:36:50 am »
I got my post deleted without any explanation. Nice!
Offline rolycat
« Reply #6 on: March 31, 2015, 10:41:04 am »
Did you really need an explanation, given its content?
Subtlety is a good thing.
Offline kcs
« Reply #7 on: March 31, 2015, 10:52:20 am »
Actually, yes. "Given its content" here are a few non exhaustive reasons:
 - Could be wrong
 - #2 not affected
 - Inevitable
Offline daqq
  • Country: sk
    • My site
« Reply #8 on: March 31, 2015, 11:23:20 am »
The next stage is quite obvious: Relativistic effects compensated oscilloscope - you choose your frame of reference, enter your speed, the speed of the measured system, any additional gravitational fields in place and you're in!
Offline DavidDLC
« Reply #9 on: March 31, 2015, 12:22:09 pm »
Dave mentioned:
The only difference between the AGO and the MDO is the gravity compensation.
He forgot to mention a maybe huge difference on the price as well  :-BROKE
Offline rolycat
« Reply #10 on: March 31, 2015, 12:27:07 pm »
Brilliant  :-+ :-+ :-+
Cutting-edge innovation like this is just what Tek needs to recover its market share. I just wish they had added POM compensation as well - a lot of my gear seems to suffer from that dependency.
Offline electr_peter
  • Country: lt
« Reply #11 on: March 31, 2015, 12:42:04 pm »
It will be interesting to see how much range of Tektronix instruments get this upgrade in the future. 4000 series is likely the next candidate.
Offline Noize
« Reply #12 on: March 31, 2015, 01:05:07 pm »
How many years will you be able keep doing this? lol
Offline mux
« Reply #13 on: March 31, 2015, 01:15:16 pm »
If you really go into the fundamentals, it's possible to make incredibly well-compensated (better than 0.1ppb) MEMS oscillator ICs. I am not sure if they are produced at all outside of research purposes, but I could see devices like that (which have an oscillator which is incredibly closely coupled to a thermal sensing element, gravitational sensing element, feedback loop, etc. etc. all the compensation guts on one IC) eventually being produced for this kind of market. If the frequency stability craze continues a company like Rigol might very well have enough production volume to warrant something custom (but fundamentally cheap) like that.
Online grumpydoc
« Reply #14 on: March 31, 2015, 01:20:33 pm »
It's a bit out of my price league, but do you have to send them the GPS co-ordinates of where it will be used so that they can fine-tune for local gravity variations.
Will this affect the resale value as, obviously, if you move it the compensation will be out!
  • Country: lt
« Reply #15 on: March 31, 2015, 01:30:07 pm »
Varying gravity field is taken into account, of course, so it won't affect compensation. Such instruments could be sold and used in any part of the world (with respect to ITAR regulations, etc.) - TekTronix knows what they are doing.
Offline KedasProbe
« Reply #16 on: March 31, 2015, 02:02:44 pm »
 :-DD
They will call it the Einstein Scopes   8)
Maybe they should work first on their voltage resolution  ;D
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
Offline arjengerstel
« Reply #17 on: March 31, 2015, 02:04:18 pm »
Sorry Dave, this one is not for you. It works for the Northern Hemisphere only. Using this baby on the Southern Hemisphere will only result in a double error. Maybe next year Tek will issue a probe that compensates?
Offline Fungus
« Reply #18 on: March 31, 2015, 02:15:11 pm »
Gee, I wonder why....   :-//
Offline Neganur
« Reply #19 on: March 31, 2015, 02:25:17 pm »
Some of the top analogue scopes had, in addition to trace rotation adjustment, trace gravitation adjustments. Glad to see DSOs are finally catching up ;)
Offline JoeO
  • I admit to being deplorable
« Reply #20 on: March 31, 2015, 02:51:22 pm »
If only this scope decoded Morse Code, it would be perfect.
Hams are always left out.
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline Relaxe
  • Keepin' it civilized
« Reply #21 on: March 31, 2015, 02:53:12 pm »
Ok, I totally understand the real intention of this video.
However, about the orientation of that frequency generator... is it a true thing? Or is it... well... a "cunning" subterfuge?
Offline ultranalog
  • Audio Nerd - not an audiophool
    • It's only audio
« Reply #22 on: March 31, 2015, 02:54:32 pm »
Of course there will be a real price hike for the AGO upgrade, given that they have to fly to within .1 parsec of a black hole event horizon to calibrate the thing over a useful range of gravity values.
playing around with near DC (20 kHz) for fun and profit
Offline Fungus
« Reply #23 on: March 31, 2015, 02:56:17 pm »
What do you mean? The datasheet is on the tek.com website...
Offline Trey
« Reply #24 on: March 31, 2015, 03:17:58 pm »
For applications where the timebase is SO critical, why not just use an external frequency reference (e.g., disciplined rubidium, cesium)? It seems that one might well need precision on the source side and other instruments too.
A problem well-understood is a problem half-solved.
The most important tool in your toolbox is your brain.
KC3BSY
