Author Topic: EEVblog #1016 - Crude Multimeter Overload Testing  (Read 6164 times)
Online EEVblogTopic starter
« on: August 15, 2017, 11:41:40 pm »
Dave tests the Uni-T UT-513 5000V high voltage insulation resistance tester with the PIntek 15kV HVP-15HF HV oscilloscope scope to see if it's suitable for crude multimeter overload testing, with some spectacular results on the ANENG AN8008
http://www.triotest.com.au/store/high-voltage-probes/662-pintek-hvp-15hf-high-voltage-probe-15kv-50mhz-x1000.html
Offline Brumby
Re: EEVblog #1016 - Crude Multimeter Overload Testing
« Reply #1 on: August 16, 2017, 02:11:45 am »
What do you mean no protection ....
It's the open air GDT approach:
(Great shot, BTW)
« Reply #2 on: August 16, 2017, 02:20:06 am »
It works, I'll give it that!
Offline G7PSK
  • It is hot until proved not.
« Reply #3 on: August 16, 2017, 08:17:34 am »
It's time to get a couple of microwave transformers and put them in series, that should let the smoke out of any meter.
Offline hayatepilot
« Reply #4 on: August 16, 2017, 01:53:27 pm »
That evil laughter at the beginning is hilarious!  :-DD
Someone needs to meme that.  ;D
Offline Brumby
« Reply #5 on: August 16, 2017, 04:54:32 pm »
Not a bad effort - but I think he still has a way to go to compete with the likes of Vincent Price
Offline tecman
« Reply #6 on: August 16, 2017, 05:20:55 pm »
After Dave's prior "endorsement" of the AN8008 I bought one.  Not for the bench, but for kicking around the house, and using it at the car, etc.  I have to say for the price it is tought to beat.  Pretty solid, reasonably accurate, etc.
Now Dave has crushed my enthusiasm for the cheap, little boy.  I might have to put a fitting on it so I can purge it with SF6 for measuring those kilo-volts.
paul
Offline PA0PBZ
« Reply #7 on: August 16, 2017, 07:38:06 pm »
What the *** is the deal with the axis labeling on the scope? 3.96KV, 34.95966ms... Really?  :palm:
Offline Neilm
« Reply #8 on: August 16, 2017, 07:41:10 pm »
Dave - no IR tester that is any good will switch in the voltage - it would stress the insulation especially older types of insulation. IIRC, a ramp rate of 3kV/s to 5kV/s is recommeded by manufacturers.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Online thm_w
  • Non-expert
« Reply #9 on: August 16, 2017, 10:34:30 pm »
If you want to apply the voltage relatively instantaneously, put a knife switch or even a GDT in series with the insulation tester.
GDT on-state voltage is ~20V so not much will drop across that.
There is also the long wooden stick connection method..
« Reply #10 on: August 16, 2017, 10:37:33 pm »
Another one triggered  ;D
Offline ocw
« Reply #11 on: August 18, 2017, 08:34:44 pm »
The UT512 and UT513 are meant for a non-lethal current output of 1.8 mA maximum.  My UT512's actual "2.5 kV" output was measured as being 2,803 volts.  I used it for testing some of my 16 uF 5,000 volt capacitors.  It was fine for that.  However, after the test the capacitor was still charged with short term high current capability.  My first shorting stick safety test produced a loud POP.  I went to a resistor discharge after that.
« Reply #12 on: August 18, 2017, 09:02:47 pm »
Neon sign transformers, though they do not give a great bang Andy style, but will arc over pretty much any meter. Arcs over CRT bases nicely though, and gives a good light show in the tube as well.
Just thinking, what will happen if I use one, an appropriate diode rectifier and that 100n 10kV silver mica capacitor I have knocking around, and find some switch that might survive 10kVswitching a few times without detonation.
