Author Topic: EEVblog #1030 - $20 DIY Bench Power Supply!  (Read 21939 times)
Offline ChrisLX200
Re: EEVblog #1030 - $20 DIY Bench Power Supply!
« Reply #100 on: November 13, 2017, 05:53:38 am »
This may be a dumb question but.. when I checked the output of my DPS5015 there was 30mV ripple (@  68Hz), that's with 15v nominal output and 2A. I tried placing a 470uf/63v capacitor across the output and the ripple disappeared to something negligable. Tried a 100uF and the ripple was only reduced to 25mV. Would it be OK to run it with the 470uF cap or is it going to burn my circuits when the power is switched off? I assume the stored charge has to go somewhere :)
(in the photo below the display refresh on the electronic load is slow, it actually reads 14.9?V and 2.00A)
Offline Kleinstein
« Reply #101 on: November 13, 2017, 06:50:48 am »
A 470 µF is rather large, but not unusually large for a power supply of that power range. I would not expect the current limiting of this supply to be very fast either, so the extra charge from the 470 µF would not change that much. If at all the extra cap makes a difference on a short or on load transients, not during turn off.
A 68 kHz ripple frequency would be rather low for the switched mode supply. The load looks like an electronic load. If either the load or the supply is not really stable with difficult load, there is a chance the 68 kHz is due to the supply and load not working well together. There are chances that the load is the culprit.
The following users thanked this post: ChrisLX200
Offline ChrisLX200
« Reply #102 on: November 13, 2017, 08:02:23 am »
Thanks! I'll try using a 50w power resistor as the load and see what happens, it whould be OK for a few minutes without overheating.
edit: result was the sme ripple frequency, larger ripple (35mV) and way reduced effect of the 470uF cap (down to about 20mV, so less than half reduction). The PSU output was 5A and lower voltage  because the resistor is only 1 Ohm.
Offline Fungus
« Reply #103 on: November 13, 2017, 08:51:41 am »
...way reduced effect of the 470uF cap (down to about 20mV, so less than half reduction). The PSU output was 5A
Not surprising the capacitor was too small with a 5A load. 5A will drain the capacitor in no time when the voltage dips.
Offline ChrisLX200
« Reply #104 on: November 13, 2017, 09:21:01 am »
I guess so. I will stay with the 470uF though, if I really need a 5A output I won't be reaching for this device :)
Offline emax
« Reply #105 on: November 16, 2017, 05:06:39 am »
Hm, I ask myself, whether it wouldn't be possible to "abuse" such a module as an electronic load?
I have to discharge LiIon batteries from rc airplanes from time to time. If I'd attach these batteries on the input side of the module (as a source) - shouldn't it be possible to adjust the discharging - current on the output-side for a controlled discharging of the batteries? Burning the power shouldn't be a big issue, any piece of constantan, an old toaster or whatever should do.
This is maybe a weird idea, but in absence of a real electronic load, wouldn't t this be an alternative?
Offline ChrisLX200
« Reply #106 on: November 16, 2017, 06:21:06 am »
Even if you could it would make little sense when you can buy an item like this: http://www.ebay.co.uk/itm/Constant-Current-Electronic-Load-9-99A-60W-1-30V-Battery-Capacity-Tester-F7/322461010090?epid=934297847&hash=item4b142c88aa:g:hE0AAOSw5cNYQBqA  for little money and is designed for the job. I have one of these and it works well.
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #107 on: December 02, 2017, 07:59:16 pm »
In one of the threads on these modules (here) around nine months to a year ago, I think the OP had figured out how to make the modules externally programmable.
Anyway, at some point the OP of that thread discoverd some glitch in the device which suddenly caused the voltage to become uncontrolled, and I think caused some kind of problem. I don't think this was in the standard use case, so it likely does not matter to viewers just looking for a power supply.
Also, this was a while ago so its entirely likely that whatever the glitch was the manufacturer may have fixed it.
I will try to find the exact link. This was when I was looking for a good power supply so I may have even bookmarked it.
what's wrong ? the products was damaged? please contact me by email 1749808660@qq.com, I can help you
So, if this glitch was fixed, these supplies may also be a good base for a project to build a programmable CV/CC supply.
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #108 on: December 02, 2017, 08:00:17 pm »
thank you for your help , that is our youtube channel. and this is our official store https://rdtech.aliexpress.com/store/923042
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #109 on: December 02, 2017, 08:20:41 pm »
I already have a bench top supply based on their DPH3205 buck-boost module. The power source is a Cosel 12V/13A switcher.
good work and nice device
but you should pay attention that the cables should be far way from the capacitor on the power board, because at high voltage and high current , the capacitor can generate interference to affect cable to make display white and blur..
and you can wrap some isolated layer on the cables.
now we have new products DPH5005, are you interesting this ?
https://www.aliexpress.com/store/product/RD-DPH5005-Buck-boost-converter-Constant-Voltage-current-Programmable-digital-control-Power-Supply-color-LCD-voltmeter/923042_32840324731.html?spm=2114.12010608.0.0.2c41b07bqrupYS
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #110 on: December 02, 2017, 08:23:35 pm »
Offline vladovg
  • Country: at
« Reply #111 on: December 07, 2017, 08:10:31 am »
I did not like the cheap plastic look so i came up with this.
The following users thanked this post: thm_w, 001
Offline Brumby
« Reply #112 on: December 07, 2017, 01:29:19 pm »
Very neat - except for the four mounting screws for each module.  If you can't hide them, then they need to be a little more "industrial", IMHO.  Maybe a small, knurled head?
But aside from that minor quibble, it is certainly appealing.
All it is missing is an earth terminal - and dual tracking capability.
Offline ez24
  • L.D.A.
« Reply #113 on: December 07, 2017, 02:56:02 pm »
Very nice
YouTube and Website Electronic Resources ------>  http://www.eevblog.com/forum/other-blog-specific/a/msg1341166/#msg1341166
Offline Dismounted
« Reply #114 on: December 07, 2017, 04:04:54 pm »
I also just finished building a little enclosure around two DPS5005 modules. :D
Offline ez24
  • L.D.A.
« Reply #115 on: December 07, 2017, 04:10:29 pm »
Another nice job  :-+  Wish I could do the same.  Be proud
Offline Brumby
« Reply #116 on: December 07, 2017, 06:08:58 pm »
HAH!!  I have that same case ... and my vision is almost identical.
It's just waiting for a couple of those modules.
Offline Dismounted
« Reply #117 on: December 07, 2017, 10:25:08 pm »
Nice! What do you plan on using to provide the input power? I've currently got two ThinkPad laptop chargers in there.
Offline Brumby
« Reply #118 on: December 07, 2017, 11:15:56 pm »
Haven't planned that far ahead yet.  Will be going through my box of transformers to see what I might have that will fit.  If not, then it's onto the other boxes of stuff....
Offline ocw
« Reply #119 on: December 30, 2017, 03:43:14 am »
Having purchased several of the low cost power supply modules and with a bunch of extra thumbwheel switches, I thought that I'd make my own version.
Attached is a picture of the voltage regulator/metering circuit which I just constructed.  I used a LT3080 1.1 amp regulator for my first try.  I might also build a 3 amp LT3083 version.  The display shows the voltage in red and the current in blue.  The side switch changes the voltage display between measuring the output and input voltages.
It doesn't have current limiting but does make it easier to change the desired voltage.  It's somewhat a combination of old and more recent technology.  It is just a spare time project to test the IC.
Offline ez24
  • L.D.A.
« Reply #120 on: December 30, 2017, 05:45:45 am »
Nice job.  How did you mount in the case?  I have some of these meters.  I assume it is a 5 wire meter, 4 digit.  Do you use one or two power supplies?  I am trying to figure out the advantages of using one or two supplies.
Here is the meter I have (has wiring diagram)
https://www.aliexpress.com/item/Digital-4-Bit-DC-200V-0-10A-Voltmeter-Ammeter-Red-Blue-LED-Dual-Display-Built-in/32586815094.html
Here is one buck I bougnt. Real crappy, at 12v @ 3a it has 2vpp ripple and a loud singing noise
https://www.aliexpress.com/item/300W-20A-DC-DC-Buck-Converter-Step-Down-Module-Constant-Current-LED-Driver-Power-Step-Down/32841643698.html
Here is the buck I am going to use (my scope crapped out just as I saw little ripple so no measurement) :
https://www.aliexpress.com/item/DC-CC-9A-300W-Step-Down-Buck-Converter-5-40V-To-1-2-35V-Power-module/32824805142.html
Testing is a real pain in the butt so I ordered this (not received yet):
https://www.aliexpress.com/item/8-in-1-150W-Digital-battery-capacity-tester-voltmeter-adjustable-constant-current-electronic-load-charger-usb/32830145151.html
thanks
Offline ocw
« Reply #121 on: December 30, 2017, 06:58:25 am »
How did you mount in the case? ...  Do you use one or two power supplies?
With the LT3080 regulator that I used rated for a maximum input/output voltage of 36 volts, I thought that I could live with the minor limitation of using the similar 33V 3A meters that a lot of people have on eBay:
https://www.ebay.com/itm/Dual-Display-4-Bit-Voltage-Current-Meter-DC-0-33V-1A-3A-Voltmeter-Ammeter/282275457510?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
The trimmer resistor on those is used to calibrate the current reading.  I used a Bud CU-793 enclosure.  I used relatively primitive methods to cut rectangular holes for the meter and thumbwheel switches.  Since I already have a bunch of regulated and unregulated supplies, I made it to be used with any single supply.
The voltage and current reading accuracy is mostly a function of the meter.  I'm more concerned on how closely the output voltage to a precision meter compares to the setting on the thumbwheel switches.  They select a single resistor which sets the output voltage.  I generally used 0.1% resistors, sometimes paralleling the resistors to get the precise value desired.  For example, I added a selected 100M ohm resistor in parallel with a 806k resistor to better achieve the desired 800k value.  I have not yet completed the verification of that accuracy.
The following users thanked this post: ez24
Offline ocw
« Reply #122 on: December 30, 2017, 09:13:23 am »
I just completed my verification on how well the LT3080's output voltage matched that chosen by the thumbwheel resistor selection.  A typical output reading was under 0.3% off of the thumbwheel value.  I suspect that the few outside of that range were due to my compromise made on the resistor value choice (such as using a 604k resistor when a 600k resistor was desired).
Attached is the accuracy data using my Agilent 34401A as the reference.  The economy meter used had good accuracy as well.  For the tenth of a volt accuracies, I calculated how far the increase in voltage compared with the voltage produced with the thumbwheel set for 10.0 volts.  And with 32 volts input and the LT3080 set for a 1.0 volt, the output voltage was about 6.7% high.  However, with an input voltage of 10 volts with that setting, the 1.0 volt output was just 0.03% low.
« Last Edit: December 30, 2017, 10:24:53 am by ocw »
Offline analogo
  • Country: at
« Reply #123 on: December 31, 2017, 12:39:55 am »
4) Yes, there is noise and ripple on the outputs, but nothing that an LC filter can't cure.
Moin German_EE, how much noise and ripple have you experienced?
With which model?
Offline pelrun
« Reply #124 on: February 17, 2018, 05:46:11 pm »
I've got a basic Sigrok driver written for these devices that I'll be submitting upstream shortly, but I've hit a minor sticking point.
The protocol has a MODEL register (0x0B) that identifies which device is connected, but the documentation doesn't provide any information about what each device actually has here. My DPH5005 returns 5205, so it's not a perfect mapping to the model number (although that may be just due to a name collision with the DPS5005.) I tried asking the company directly and hit a language barrier.
If anyone with a comms-enabled device other than the DPH5005 is in a position to read out the value from their unit and post it it'd be much appreciated.
(alternatively I could just write off-scale high values for V and I and read back the clamped values, but that's hardly elegant...)
Edit: I got in touch with the guy who translated the protocol doc into English and he confirmed that the register matches the model number for all units *except* the DPH5005, so I'm all set.
« Last Edit: February 18, 2018, 02:58:45 pm by pelrun »
