Author Topic: EEVblog #1030 - $20 DIY Bench Power Supply!  (Read 48997 times)
Online EEVblogTopic starter
« on: October 05, 2017, 08:57:22 pm »
Dave looks at the spectacularly cheap $20 DPS series CC/CV modules from RD Tech.
How to make a 30V 3A bench power supply with 1mA resolution constant current limiting and multi function display using junk bin parts.
The DPS3003 30V 3A module in particular.
RDtech Youtube channel: https://www.youtube.com/channel/UCy73jJ5-ZqhPzT7wJ6KTIaw
Aliexpress Store: https://rdtech.aliexpress.com/store/923042
The following users thanked this post: fvdpol, jonovid
Offline cdev
Re: EEVblog #1030 - $20 DIY Bench Power Supply!
« Reply #1 on: October 05, 2017, 09:21:32 pm »
In one of the threads on these modules (here) around nine months to a year ago, I think the OP had figured out how to make the modules externally programmable.
Anyway, at some point the OP of that thread discoverd some glitch in the device which suddenly caused the voltage to become uncontrolled, and I think caused some kind of problem. I don't think this was in the standard use case, so it likely does not matter to viewers just looking for a power supply.
Also, this was a while ago so its entirely likely that whatever the glitch was the manufacturer may have fixed it.
I will try to find the exact link. This was when I was looking for a good power supply so I may have even bookmarked it.
So, if this glitch was fixed, these supplies may also be a good base for a project to build a programmable CV/CC supply.
« Last Edit: October 05, 2017, 09:39:56 pm by cdev »
Offline cezar
« Reply #2 on: October 05, 2017, 10:00:24 pm »
Those are being made by RD TECH. They also have their own YT channel
https://www.youtube.com/channel/UCy73jJ5-ZqhPzT7wJ6KTIaw/videos
Offline ManuelMcLure
  • WW1FA
« Reply #3 on: October 05, 2017, 10:20:44 pm »
I already have a bench top supply based on their DPH3205 buck-boost module. The power source is a Cosel 12V/13A switcher.
The following users thanked this post: jonovid
Offline jamiec
« Reply #4 on: October 05, 2017, 10:36:48 pm »
I made one of these myself a couple of weeks ago and absolutely love it.
Would recommend to anyone, wanting a small PSU.
Here is a photo of my build:
« Last Edit: October 05, 2017, 10:38:25 pm by jamiec »
Offline jaromir
  • Country: sk
« Reply #5 on: October 05, 2017, 10:40:03 pm »
That overshoot when relased from CC into resistor to CV with no load at 10V (last test) was only slight - perhaps it's because the module can't deliver more than 11something volts.
I wonder what the overshoot looks like when set to 5V, for example - whether it jumps to maximal input voltage too.
Offline boffin
Offline ez24
  • L.D.A.
« Reply #7 on: October 05, 2017, 11:55:42 pm »
This Aliexpress seller (RD) has a chart of the specs and links for different models.  Scroll down to see the chart.
https://www.aliexpress.com/item/R/32762131242.html
Edit: corrected link
« Last Edit: October 08, 2017, 11:41:48 pm by ez24 »
The following users thanked this post: kripton2035
Offline cdev
« Reply #8 on: October 06, 2017, 12:02:26 am »
Perfect thing for me to do with my 12v power supply from that era.. Which looks a lot like yours, boffin
That is, if I can figure out how to open its damn box!
Offline Rabid Badger
« Reply #9 on: October 06, 2017, 01:04:48 am »
I built my bench PSU around the DPS3012.  I got a 36V 10A open frame power supply for $12 on eBay and put it in an old salvaged housing with a couple fans out of an old server.  Total out of pocket was $37 and it has handled some pretty stout sustained loads.
The following users thanked this post: thm_w, edavid, jonovid
Offline ziggyfish
« Reply #10 on: October 06, 2017, 01:36:42 am »
With the experience of the EEVBlog community, why isn't there an open hardware solution with a version of this?
The software side would be pretty straightforward (could do it with my eyes closed).
Offline s8548a
  • Country: in
Offline nixfu
« Reply #12 on: October 06, 2017, 02:03:02 am »
So are these step down only?  So if I want 20v I will need to input 25v or so?
« Reply #13 on: October 06, 2017, 02:32:14 am »
There is a buck-boost version. Search for DPH3205.
Offline crazyguy
« Reply #14 on: October 06, 2017, 02:44:08 am »
read the comparison chart posted in #7
Offline n3vti
« Reply #15 on: October 06, 2017, 03:06:29 am »
I love these!
So, I could in theory, make it into a mains plug in by building an unregulated power supply to supply the requirement for these modules? I think I have the parts to make a 36 volt (heavily filtered) DC at about 2-3 Amps.
Offline ziggyfish
« Reply #16 on: October 06, 2017, 05:00:38 am »
It is there already.
https://www.eevblog.com/forum/projects/diy-programmable-dual-channel-bench-psu-0-50v3a/
from their Crowd Funding page:
Next Manufacturing Run
As some of you have noticed, we’ve stopped taking new orders for the EEZ H24005. Because we intentionally didn’t include a large margin in our pricing, the cost of the current manufacturing run is essentially the price paid for each unit and there essentially won’t be any left over to sell outside of those already purchased. Parts have already been ordered and deposits already paid to our manufacturers, so we can no longer accommdate new orders in the current batch. However, we’ve been discussing making a second batch, so please subscribe to project updates if you’d like to be informed if/when a next batch becomes available.
I wonder when or if they are making more.
Offline plazma
    • Homepage
« Reply #17 on: October 06, 2017, 06:16:33 am »
There are new communication versions. You can control it via opto-isolated USB.
I have bought 4 of these modules:
https://www.aliexpress.com/item/RD-DPS5005-Communication-Function-Constant-Voltage-current-Step-down-Power-Supply-module-buck-Voltage-converter-LCD/1000004290003.html
IMHO this is the best bang for the buck version. The largest current with the compact design. Next model got a large external PCB.
This is the firs unit I built. It got a internal battery pack (75.8Wh, 11.4V, protection PCB with balancing). I can power it via a Dell laptop PSU or the internal battery pack. Size is only 10x10x5cm.
Offline plazma
    • Homepage
« Reply #18 on: October 06, 2017, 06:22:39 am »
The biggest flaw with these modules is the low side current measurement. You have to be careful if using these in parallel and /or using a non-floating DC PSU for power input. The return current may go the wrong path and skew the modules current measurement.
The ripple was surprisingly low in the DPS5005 module. This is measured with 12V input and 5v 5A output.
Offline sasa
  • Hobbyist in electronic
« Reply #19 on: October 06, 2017, 06:28:47 am »
What kind of LCD is used?
I'm aware small OLEDs are extremely cheap on alibaba or similar sites, however this also may be some cheap TFT color LCD.
The 30+ years professional desktop software designer and software engineer
Offline plazma
    • Homepage
« Reply #20 on: October 06, 2017, 06:29:16 am »
Alternative firmware with simplified GUI and WLAN module support:
https://johan.kanflo.com/category/dps5005/
Offline plazma
    • Homepage
« Reply #21 on: October 06, 2017, 06:31:48 am »
The srceen is LCD not OLED.
Offline Red Squirrel
« Reply #22 on: October 06, 2017, 07:33:37 am »
I'd be curious to see a test at it's rated current output.  >:D
These look pretty nifty though, might get one or two.  I need to build myself a variable bench supply anyway, still using an old ATX power supply with it's fixed voltage rails.
Offline Rolo
« Reply #23 on: October 06, 2017, 07:43:02 am »
Going to build one, as second PSU next to my trusty Delta Elekronika. What do you think, will noise/ripple figures be better if the module is powered by a classic transformer , bridge rectifier and big cap? Or is it not worth the weight and size increase of the unit?
« Last Edit: October 06, 2017, 07:44:41 am by Rolo »
Offline HKJ
    • Tests
« Reply #24 on: October 06, 2017, 07:46:38 am »
I have tested two of them with a lot of different input and output voltages:
http://lygte-info.dk/review/Power%20DPH3205%20UK.html
http://lygte-info.dk/review/Power%20DPS5015%20UK.html
