Author Topic: EEVblog #1055 - How to Design a Custom LCD  (Read 4078 times)
Online EEVblog
« on: February 03, 2018, 07:19:26 am »
How to design a custom multiplexed LCD display.
Dave takes you through what is required to design your own custom LCD display and what consideration you need for manufacturing and choosing an LCD display driver.
Part 3 in the LCD Tutorial series.
The following users thanked this post: jancumps, Cliff Matthews, MT, JPortici, chriswebb
Offline chriswebb
Re: EEVblog #1055 - How to Design a Custom LCD
« Reply #1 on: February 03, 2018, 01:18:49 pm »
Loved this one, Dave! 31 minutes basically flew by watching that.
Also Looks like David did fantastic job on that spec!  Can't wait to see the result after it gets manufactured.  This video was very enlightening for someone with no product experience outside of software.
Always learning. The greatest part of life is that there will always be more to learn.
Offline Uksa007
« Reply #2 on: February 03, 2018, 03:19:43 pm »
Dave,
Any reason why you didn't opt for a small OLED?
They are only a couple of bucks include the driver (SPI and I2C available), and IMHO are bit more modern looking, better brighter etc.
https://wholesaler.alibaba.com/product-detail/4pin-0-96-white-0-96_60698607420.html?spm=a2700.7782932.1998701000.46.611080d4hPXC0x
Yellow but bigger, I'm sure you could get them in white also
https://www.alibaba.com/product-detail/2-4-inch-yellow-color-oled_60450414866.html?spm=a2700.7724838.2017115.370.39c81fc9mKqBGh
Module only, provide your own driver
https://www.alibaba.com/product-detail/2-42-2-4-inch-128x64_60730189540.html?spm=a2700.7724838.2017115.417.39c81fc9mKqBGh
Looking forward to seeing more info on the uCurrent.
Regards.
« Last Edit: February 03, 2018, 03:36:22 pm by Uksa007 »
Offline Dubbie
« Reply #3 on: February 03, 2018, 05:05:06 pm »
Uksa, this has been answered in plenty of threads. Some of the reasons are:
# Can be cheaper at volume
# Better visibility
# Lower power use
# Requires very little cycles/resources from the MCU
# Looks more professional
# Dave wanted to do a video series on custom fixed segment LCDs. I’m not aware of any other videos that cover this comprehensively. While there are hundreds covering raster LCDs
# more reasons that I am sure others will contribute.
« Last Edit: February 03, 2018, 06:26:18 pm by Dubbie »
Online Brumby
« Reply #4 on: February 03, 2018, 05:51:40 pm »
Dave,
If you checked out the situation the uSupply was designed for - you would see why minimising power consumption for everything but the load would be preferable.
Offline MasterTech
« Reply #5 on: February 03, 2018, 09:48:13 pm »
Interesting, and I also learned about the existence of Inkscape!
Offline amspire
« Reply #6 on: February 03, 2018, 10:21:40 pm »
The other package to consider is Draftsight. It is a commercial Autocad clone, but it has a free version that is extremely solid. I tried the open source CAD packages, but if you want a very solid Autocad DXF/DWG based package, Draftsight is the best free solution. All the open source alternatives I tried could never handle massive DXF files well. Also Draftsight lets you save as any Autocad file format from Autocad R12 (the DOS based 1992 version) to current.
https://www.draftsight2018.com
There does not seem to be any commercial restriction for using the free license. You just do not get the pro features (not needed).
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #7 on: February 03, 2018, 11:01:53 pm »
I don't think there's any advantage to specifying the common groups-you can just use a lookup table to get a sensible segment map .
On a complex display, chances are they won't be able to do the grouping, or may need increased gaps
Day Job: Mostly LEDs
Offline coppice
« Reply #8 on: February 04, 2018, 12:45:11 pm »
Its a pity Dave didn't say something about the tradeoffs between different mux options - their effect on voltage requirements, temperature range, viewing angle range, etc.
A number of the Chinese makers still only accept orders for displays up to 4 mux, or charge extra for 6 or 8 mux panels.
Offline Grapsus
« Reply #9 on: February 06, 2018, 08:10:33 am »
Very interesting episode. That LCD looks packed with segments ! Very curious to see if they are able to route it and how it looks in the end.
Offline thm_w
« Reply #10 on: February 06, 2018, 09:16:03 am »
Dave,
In addition to whats been said, Daves display is 54x50mm or 2.1x2.0", so the first one is far to small (I like the size but I suspect many people would not).
The larger 2.5" OLED you linked is $5 vs 1.47 (USD?), so 3.4 times the price, and isn't as tall.
Third link, can't be sure what the actual price is.
Offline james_s
« Reply #11 on: February 06, 2018, 06:24:00 pm »
Inkscape is wonderful, I've been using it for several years, works great for creating snazzy looking front panels for various projects. Print it out, laminate it, spray adhesive to attach it to the panel.
Regarding the LCD that's pretty cool, making a custom segmented LCD is not something that ever even occurred to me. I figured it would only be economical if you were making millions of something.
Offline floobydust
« Reply #12 on: January 09, 2019, 08:10:01 am »
Is there an update for the product using this LCD? Where is that PSU...
Online MT
  • Country: fo
« Reply #13 on: January 11, 2019, 07:27:09 am »
Yes wonder the same, what happened with custom LCD project!?
