Author Topic: EEVblog #1063 - Weller WE1010 vs Hakko FX888D Soldering Station  (Read 15504 times)
Online EEVblog
Review of two $100 class soldering stations.
Can the new Weller WE1010 beat the venerable Hakko FX888D?
https://kit.com/EEVblog/soldering-equipment
The following users thanked this post: saturation, SeanB, boffin, Asuka
Offline ulwur
Re: EEVblog #1063 - Weller WE1010 vs Hakko FX888D Soldering Station
« Reply #1 on: March 10, 2018, 08:48:34 am »
I realize it's to late, but Dave should have included the Xytronic LF-1600 station in the comparisation. I have been using Wellers professionaly for 20 years, and I'm impressed by the Xytronic I boght last year.
Offline ulwur
« Reply #2 on: March 10, 2018, 08:51:26 am »
One more thing. I haven't used a Hakko ever, but I've noticed that the temp display seems to freeze on the set temp. I find it strange that the display wont even change 1 least sigificant digit until Dave really pushed the tip in the wet sponge.
Offline Starlord
« Reply #3 on: March 10, 2018, 09:03:59 am »
17:50 - "These aren't like 3 or 5 second irons like your JBCs, Paces, and your Metcals and all your really high end $500K irons..."
$500K soldering irons?! Surely you can't be serious!
I tried to find some of these $500K irons you spoke of, and the highest price one I can find is this $28,000 Metcal rework station:
https://www.mouser.com/ProductDetail/Metcal/APR-2100-SCS?qs=sGAEpiMZZMsgi4BqhxuE1fcBywSq7o1561GpXd7QrLmT9Ix2SPkP%252bg%3d%3d
But that doesn't really qualify as what I'd call a soldering iron.
Perhaps you meant $5K?
This Pace seems like it might be the sort of thing you would have been referring to:
https://www.tequipment.net/Pace/PRC-2000-8007-0132/Desoldering-Equipment/Rework-Stations/?v=0
Offline lem_ix
  • Country: cs
« Reply #4 on: March 10, 2018, 09:18:24 am »
He probably meant to say 500 to 1000$. This Weller will probably do well in markets Hakko doesn't have a presence in.
Offline floobydust
« Reply #5 on: March 10, 2018, 09:23:21 am »
I find Weller tips beat Hakko for wetting and I get better results with Weller soldering irons. The Hakko tips, solder is always sticking and gobbing on the tip.
The FX-888D, who puts the on-off switch on the side? Drives me nuts. Hakko sponge FAIL. The brass wool is harsh on tips and leaves a mess.
Weller auto turn off is great, but they don't offer as good a selection of tips for SMT.
Both are very good soldering stations.
Offline qu1ck
« Reply #6 on: March 10, 2018, 10:17:29 am »
Dave you should really take a look at stations that are based on t12 tips. These t18 and 900 series tips just don't cut it in terms of temperature tracking because of big thermal resistance between the tip itself and temperature sensor. They require very precise machining to manufacture (biggest reason why chinese tips suck is because they have big gaps) and therefore will never be really cheap. T12 on the other hand has the temperature sensor integrated in the tip.
There is a big family of soldering stations that everyone and their mother is producing nowadays, based on stm32 micros. They have great UI, lots of features, including sleep/position sensor for the handle, various temperature profiles for various tips etc.
Maybe you can get one of those stm32 stations, alongside with bakon 950d and original hakko and review them?
Nothing is true (as far as measurements go)
and everything is permitted (as long as you are ok with magic smoke escaping)
Offline Bud
« Reply #7 on: March 10, 2018, 10:23:54 am »
I read somewhere you should press a button to wake the Weller up from sleep, they did not say which button.
What Dave called a dicky spring stand on Weller I call it a great feature. Because it is flexible i can throw the iron into it without taking my eyes off the board and it will go right into the holder. I do not have  Hakko but have a JBC and with it i always have to look at the stand to put the iron in it since it is just a hole in the stand. With Weller spring stand i do not have to worry about the angle i grab the iron, the spring action compensates for  it.  With a solid stand i have to be careful not to snap the iron in half if i pull it in a wrong angle. Same about accidentally hitting the iron in the stand when doing something else, Weller just moves and springs back, Hakko iron may break.
Online thm_w
« Reply #8 on: March 10, 2018, 11:20:33 am »
Yeah I recommended in the other thread: http://www.eevblog.com/forum/manufacture/low-cost-iron-shootout/
But I can see why he might be reluctant to recommend for newbies as they have questionable safety and QA, unless you know what you are doing.
Offline NiHaoMike
    • Facebook Page
« Reply #9 on: March 10, 2018, 02:32:54 pm »
My FX888 (the older analog version) came with a chisel tip. Maybe when they updated it to digital, they thought that conical tips would be more useful for small SMD work?
Online Nusa
« Reply #10 on: March 10, 2018, 02:57:51 pm »
What, no teardown? I thought taking it apart was rule #1 at EEVblog? oops, guess I missed those 2 minutes near the end! Never mind.
I would be particularly amused if the WE1010 has unused pads/inputs for setpoint selection that they deliberately didn't use to avoid competing with their better models. Even if it doesn't I can see this being a great hacking opportunity, since the display hardware is clearly present.
« Last Edit: March 11, 2018, 08:33:06 am by Nusa »
Offline 1anX
« Reply #11 on: March 10, 2018, 04:06:10 pm »
Thanks Dave, it reminded me that its time to upgrade from my Hakko 926. Its done great service over the years and been maintained with numerous new parts, but figured its time to get something new. The 926's paint has turned yellow and its got dings on its case, the solder pencil holder is starting to suffer from heat rot and is falling apart.
It still holds it temp using the new series Hakko tips and will be retired to backup status. Cant really bear to part with it and binning it would just be wasteful. So I just ordered a new Hakko 888D and hope it works as reliably as my old 926. Your test shows Hakko still provides all I need from a basic solder station.
Offline Monkeh
« Reply #12 on: March 10, 2018, 04:44:55 pm »
Neither is particularly impressive, but they're both basically ancient designs. I'd say the Weller has better sensing but perhaps less mass.
Neither of them has any power delivery capability thanks to relying on mostly air as a thermal transfer medium - which is why you're always banging on about having to adjust temperature for different tasks. If you can deliver the power to maintain temperature you don't need to adjust it!
I'm hoping the ADS200 which is supposed to be coming your way (at, I admit, over twice the price - $250 class station..) will show both of those for the relics they are. An FX951 might be a good station to compare to - maybe a PS-900 or EB-2000 would be fun to throw in as well. Gets expensive buying all those, though.
Offline boffin
« Reply #13 on: March 10, 2018, 06:12:24 pm »
I think these soldering iron shootouts are awesome, thanks for the video.  I'm using a 40 yr old Weller (W-TCP-L) that's old enough to have a Bakelite case, and even with the fixed temp tips (I almost always use a 700F/370C) it works like a champ, and always has.  Lot of tips handy, but like you, I like the chisel (extra tips are a good item to bring your digikey order up to the free shipping level)
I'd like to see your review of the TS100, a lot of people say a lot of nice things about them, and I was considering it as a second iron.  However, having bought a couple of Yihua 947-III for a course I teach at work, I have to admit I'm impressed for the price ($12-20), and might just get one of those instead
(thread here for the 947-III) http://www.eevblog.com/forum/reviews/yihua-947-iii-soldering-iron-thoughts/
Boffin at play https://snafu.ca/
Offline nowlan
« Reply #14 on: March 10, 2018, 06:53:25 pm »
Just watched the video. Surprised not using/needing the silicon pads to change tips like on the 951 hakkos. Beats using pliers yes?
There is a knock off FX-951 on BangGood for $115au. Would Dave stoop to asking BG for eval units?
The authentic 888 in 230v land are double the US, which has been hard to swallow for students/hobbyist.
Offline bitwelder
« Reply #15 on: March 10, 2018, 11:25:52 pm »
Seeing the review of the UI on the Hakko reminded me of the (negative) comments from Louis Rossmann about the Hakko 861DW hot air station.
Are all Hakkos with digital interface so pathetically inefficient if not counterintuitive to operate?
Offline IanB
« Reply #16 on: March 10, 2018, 11:36:51 pm »
If I reach out my right hand the switch falls naturally under my finger. I find it the perfect place for a switch.
Offline Rolo
« Reply #17 on: March 11, 2018, 12:46:18 am »
I Live in The Netherlands, we have 230V AC Mains. The original Hakko FX888D costs € 133 here (= $163 US, $208 AU). Looks like the Weller WE1010 is going to costs € 170 over here.
« Last Edit: March 11, 2018, 12:55:25 am by Rolo »
Offline ebastler
« Reply #18 on: March 11, 2018, 12:47:21 am »
It seems that the Weller and the Hakko are really close in terms of performance. So, for me, a purchasing decision would be based on their ergonomics. Again, this looks like a tie as far as the handpieces are concerned -- but for the base stations, the Weller wins hands-down in my opinion.
What was Hakko thinking, trying to make do with only two buttons? The cost of an extra button would literally have been a cent or so! And seeing Dave holding the Hakko station in place with his other hand while he pushes those too-high-force buttons makes me cringe...
The larger display is another win for the Weller, for my taste. And, speaking of taste -- ah no, I won't go there...  ::)
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #19 on: March 11, 2018, 01:04:38 am »
I bought a Weller WTCP in 1980, for the sum of 86.250 Italian Liras including VAT. Revalued to to-day, it's about 211.00 Euros.
The quality of the station was such that it is still working, after 47 years (I sold it some years ago to a friend).
In my lab I have now two Weller WS81, that currently sell for about 300 Euros + VAT (366.00 Euros net).
They solder as well as the WTCP and the extra power (80 vs 50 W) is sometimes necessary , but in the years I've seen that:
1) The WTCP had only one problem, ( the contacts of the magnetic switch inside the handle had to be cleaned some times) and it's tips lasted for a life,
2) The WS81 had a lot of problem with short life of tips, oxidation of the tip retaining tube, oxidation of the surface of the heater touching the tip (the spare heater costs about 70 Euros),  unreliable temp setting.
Weller quality has declined but  it's prices did not.
My local distributor does not have the new low cost Weller, but it's bigger brother, the WT1010 , sell for 380 Euros + VAT-  Too expensive... (but it has the presets).
Now I 've built a T12 clone kit, that works like a charm: the handpiece is not as confortable as the Weller, but the thermal response is very good, and the cost was about 30 Euros.
No more new Wellers in my lab.
Best regards
Ciccio
Strenua Nos Exercet Inertia
Offline mdijkens
« Reply #20 on: March 11, 2018, 01:10:55 am »
I have the analog FX-888 and when seeing this video I am really happy I have the analog one.
Just turning a simple knob to change temperature; I love it!
Why didn't any of them go with a nice digital display, 2 or 3 preset buttons and a turning knob for temperature control
This is not progress
Offline ebastler
« Reply #21 on: March 11, 2018, 01:32:50 am »
Better solutions do exist, of course. My ERSA i-con has a nice, large encoder knob with integrated push-button, which works quite intuitively for temperature adjustment and menu control.
But apparently this type of interface is reserved for higher-end soldering stations for now. Come on, guys, we all know how much (i.e. little) a simple encoder costs!  >:(
Offline NANDBlog
« Reply #22 on: March 11, 2018, 02:03:05 am »
All I'm seeing here is ancient designs with terrible performance and inflated price. Weller seems to be stuck in the 80s, where switching power supply didn't exist. And arbitrary pricing.
I was quite suprized, when I first tried a Metcal station. I was looking for the temperature setting first. Didn't find it. Looked it up online, and realized, that it is one of those fixed temperature stations. And then I used it, and I realized, I never needed to change the temperature. That one setting just worked. Heats up in 5 seconds, you an change a tip in about 10 seconds, and it just does everything. First I didn't even realize what is happening, I was waiting, OK, something must be wrong with it.
It took my brain some time to realize how bad these irons are. And I ame from the WP-80 iron not this heap of crap. Or the "good quality" WRMP, which needed a new tip every time you took it out from the cabinet. It was there, because it was eating tips like no tomorrow. And the WP80's handpiece needed serious maintenance every now and then.
Seriously, forget about watt ratings and temperature settings.
Offline Bud
« Reply #23 on: March 11, 2018, 02:31:56 am »
Absolute nonsense, ability to change temperature is a must for effective work. And not in a ducky way like that Hakko, has to be either one button preset press or a dial.
Offline ebastler
« Reply #24 on: March 11, 2018, 02:37:29 am »
All I'm seeing here is ancient designs with terrible performance and inflated price. [...] I was quite suprized, when I first tried a Metcal station.
Hmm... Metcal may be good (I have not had the opportunity to try one yet), but I can't see that their pricing policy is much different from the competition. If anything, they seem to be more expensive for comparable specs?
If a soldering station had perfect regulation of the (fixed) temperature, maybe you wouldn't need to change temperature that often. You will still have to change it sometimes, for different jobs; but I understand that the Metcals offer "self-regulating" tips as Weller did in the old days.
But why would watt rating not matter?! Seems that the capabiity to supply enough power is one prerequisite for stable temperature regulation, besides a good closed-loop control?
Offline madires
  • A qualified hobbyist ;)
« Reply #25 on: March 11, 2018, 02:42:51 am »
Weller is known to be overpriced. A German shop lists the WE1010 for € 169.95.
Offline jancumps
  • New Low
« Reply #26 on: March 11, 2018, 02:50:52 am »
Watch the video again. The front panel pcb is shown.
Offline NANDBlog
« Reply #27 on: March 11, 2018, 02:54:21 am »
One simple question: Why?
Maybe, because the iron is not up to the task, eg.: keeping it's temperature above the melting point?
I'm not happy with it's pricing, the entry point seems to be 200 EUR, which is 50 EUR more than the Weller. That is the PS900, I've used the MX5000. As I understand they use the same cartridges.
Watt rating doesn't matter, you saw it in the video. The weller had higher rating yet slower heatup, and it dipped more when cooled down by water.
Yes, a metcal doesnt have any setting, as it works with the Curie point of the tip. And the heating element and the tip is integrated, so your handle basically never wears out, as it is just a fancy connector. I was also skeptical at first.
Offline ebastler
« Reply #28 on: March 11, 2018, 03:02:11 am »
What kind of conclusion is that?! "The quality of temperature control is not determined by the Watt rating alone" would be a viable statement. "Watt rating doesn't matter" is not.
This is an engineering forum. Drawing the right conclusions from observations or measurements, and then relaying those conclusions correctly, helps your credibility.  8)
Offline NANDBlog
« Reply #29 on: March 11, 2018, 03:08:58 am »
It is Saturday. I had enough precise engineering for this week, entschuldigung.
Here is a 40W metcal soldering a nut to a bolt for remorse. Not my video.
Offline ebastler
« Reply #30 on: March 11, 2018, 03:20:19 am »
Entschuldigung accepted. ;)
The screw-to-nut soldering video is nice. But hey, for those extreme situations with a large-capacity heat sink, I would argue that the performance actually becomes critically dependent on the Watt rating! Unless the manufacturerer got their closed-loop temperature control totally wrong, the iron will notice the need to supply heat, and more heat. Optimization of the control loop parameters shouldn't matter that much. Hence the time it takes to get back to soldering temperature will depend nearly entirely on the available electrical power (and on the thermal resistance between the heater and the tip).
Offline Monkeh
« Reply #31 on: March 11, 2018, 03:23:45 am »
Nope. The MX5000 (and MX500, and the old PS2E, etc etc) are 13.56MHz units. The PS and MFR units are 400kHz. They use different handpieces and tips, and the cheapest tip option uses a separate heater coil.
.. and that's the key. A Metcal with a 40W supply will deliver.. well, not 40W, as not all tips even take full power, but it will deliver it straight into the body of the tip (as will any more conventional, but still integrated heater, system). Meanwhile, these things are delivering it into a nice jacket of air between heater and tip, and then into a massive amount of exposed metal surface area around that to act as a heatsink.
Offline gearshredder
« Reply #32 on: March 11, 2018, 04:11:08 am »
+1 for Metcal. Just bought another mx-500. I'm waiting for a mx-5000 to show up for a good price.
There needs to be a heater integrated tip station review.
Offline boffin
« Reply #33 on: March 11, 2018, 04:41:05 am »
And doing that kind of joint is exactly why you own one of those 140W soldering guns.  Not delicate, but for that sort of thing its invaluable.
Offline Monkeh
« Reply #34 on: March 11, 2018, 04:42:38 am »
Yes, one of those might be able to keep up with a modern 40-60W system.
Offline djacobow
  • takin' it apart since the 70's
« Reply #35 on: March 11, 2018, 04:43:48 am »
So, the WE1010 does not seem like a meaningful upgrade over my WESD51. So, if I'm ready for a better iron and I'm willing to go up to, say $500, what's the best iron I can get at that price?
Offline NiHaoMike
    • Facebook Page
« Reply #36 on: March 11, 2018, 04:54:23 am »
I would like to see how the TS100 compares. I saw a few reviews that say it compares quite well to the cheaper soldering stations but it would be interesting to see if it would be a good budget alternative to Metcal.
I got a 260W Weller for assembling battery packs. Main downside is that it's heavy. I wonder when they'll come out with one that uses a high frequency inverter to cut down on weight and while they're at it, make it battery powered.
« Reply #37 on: March 11, 2018, 04:57:06 am »
^I was thinking about buying a TS100. If dave doesn't do it I'll make the video! lol. I kinda want that MX-5000 first though. 80w of RF power!
Offline Terry01
  • Country: scotland
« Reply #38 on: March 11, 2018, 05:37:35 am »
I got the FX-888 a few weeks ago and think it's a great wee iron! I would recommend it to anyone. In saying that I had the Katsu 852D before that which is a Hakko clone, I would recommend that too!  :wtf:  Honestly!
For anyone using the T12 Hakko clone iron get a genuine Hakko tip in your favourite flavour and see how much it improves the clone. I did and it's awesome! Well worth the extra £££
I get the problem with the 2 button control thing on the FX-888, I was a bit confused at 1st myself. After about 10 seconds I got it and have been happy operating it ever since.
Unless you have to change temp every 30 seconds the fact it takes about 5 seconds to change temp it's not a problem. Lets face it if you were having to change temp every 30 seconds with even a mind controlled temp setting it would get annoying?? It's not bad at all.
I haven't used a Weller so can't compare 1 way or the other. I just know the Hakko is a decent iron for hobby use.  8)
Sparks and Smoke means i'm nearly there! 8)
Offline Deridex
  • IMHO
« Reply #39 on: March 11, 2018, 07:04:48 am »
Sadly i'm not realy impressed by both solderingstations. I will stay with my Ersa I-Con-Pico
Offline 4CX35000
« Reply #40 on: March 11, 2018, 07:33:04 am »
With the Katsu clone and the Hakko it is possible to put a small piece of copper around the iron element and slip on the fake tip's. It improves the performance of the fake tips, but the station will need recalibrating.
At work I have two irons; a Hakko FX-888D which is my daily work horse with loads of spare bits (Most of them fake), which I use for tinning leads, connectors and so on. For the more delicate component, SMD and other PCB work I have a JBC CD-2BE which I have a small selection of different bits.
For my home use I have a Katsu and that is adequate for home use and if I need to do something fairly tasking, I can take any circuit board into work and use the Hakko or JBC.
If I didn't have access to the equipment I have at work, then I would opt for the Hakko FX-888D. It really comes down to budget and requirements, if your a student then the Katsu will be fine, but for hobbyist and pensioner then the Hakko is a good buy.
Offline timelessbeing
« Reply #41 on: March 11, 2018, 08:47:37 am »
Me too. That button interface looks maddening. And the analog one was cheaper too.
Offline NANDBlog
« Reply #42 on: March 11, 2018, 08:49:33 am »
Thanks for the clarification.
Is there a big difference in their performance?
Offline Monkeh
« Reply #43 on: March 11, 2018, 09:07:48 am »
No experience with the baby ones.
Offline eV1Te
  • Your trusted friend in science!
    • richardandersson.net
« Reply #44 on: March 11, 2018, 09:59:46 am »
I just wanted to mention a small inaccuracy in the video regarding thermocouples. You said that the thermocouple (Type K) couldn't go any higher than 250 deg.C.
This is incorrect, all Type K thermocouples are accurate up to 1350 deg.C and down to -200 deg.C (per definition/standard they are all made from the same alloy), and all good thermocouple meters should also be accurate in that range.  :-+
However the plastic insulation on the wires are probably only rated for 250-300 deg.C. But this does not matter in your case since you are only heating the tip in your experiment, and even if you would char the insulation close to the tip, it would not affect the measurement.
Type K alloy:
Positive: Chromel (90% nickel, 10 % chromium), non-magnetic, melting-point 1420 deg.C
Negative: Alumel (95% nickel, 2% aluminum, 2% manganese, and 1% silicon), magnetic, melting-point 1399 deg.C
« Last Edit: March 11, 2018, 10:05:29 am by eV1Te »
Offline eV1Te
« Reply #45 on: March 11, 2018, 10:28:16 am »
By they way, the Weller had a 60 Hz transformer and I assume that you were driving it at 110 V 50 Hz through an isolation transformer?
Could the incorrect frequency affect the transformers efficiency or possibly saturate the core when driven at its maximum load in such a way that the iron did not get it's full 70 W?
Remember that it is not recommended to run 60 Hz transformers at 50 Hz due to the 20 % higher flux in the core. For a transformer with small tolerances the 20 % higher flux would saturate the core and cause significant losses, the same as if you would increase the mains voltage by 20 %.
It would be interesting if you could measure the power-draw of each iron to see how much power they really use (65 W vs 70 W) and their respective response-time after putting the tip on the sponge!
« Last Edit: March 11, 2018, 10:34:06 am by eV1Te »
Offline NiHaoMike
    • Facebook Page
« Reply #46 on: March 11, 2018, 10:45:58 am »
He has a VFD designed just for emulating foreign mains so I assume that's what he used.
Offline Bud
« Reply #47 on: March 11, 2018, 11:09:27 am »
Good idea! I vote for this test.
Offline Terry01
  • Country: scotland
« Reply #48 on: March 11, 2018, 11:22:13 am »
I agree but the only thing on the clone iron is the black plastic ring/nut that holds the iron together on the clone tends to slacken off by itself if you put too much heat into it or use it for long periods. The genuine iron doesn't and the ring/nut is bacolite or something like that. The grey rubber grip on the clone  is easy to move too so I slide it onto the plastic nut a little which helps keeping it secure too. The extra heat that that genuine tip gives you makes the slipping ring/nut thing worse on the clone. I agree 100% that the clone is more than ample for most hobby stuff. I have seen on YouTube the copper slip trick but not used it myself. You can see the extra body in the genuine tips and i'm sure it is some sort of slip too, maybe copper like you say to use in the clone. I would love a shot of one of these irons people say are so much better than the FX-888. I find it wanting for nothing. I can hope  :)
Online Red Squirrel
« Reply #49 on: March 11, 2018, 01:42:04 pm »
I have that same Hakko which is my first "real" soldering iron. (was using a 40w fire stick before that) and the UI has always been my main complaint too.  I accidentally went into calibration mode once, did not realize, I was trying to set the temp but instead I (miss)calibrated it.  Doh!  To calibrate it I just found out the melting temp of solder and slowly brought it up until it started to melt.  I don't remember the steps I had to google it as I went along. Definitly not an intuitive UI.
Offline Towger
  • Country: ie
« Reply #50 on: March 11, 2018, 06:10:28 pm »
No it is not. The melting point of solder depends on the alloy used.  You select your tip temperature based on it.  Your tip always maintains it temperature.   This allows you to safely solder small smd parts to tabs on RF power transistors while they are still bolted on to large heatsinks.  There is no need for knobs and buttons to change.  Have a look for currie point soldering irons, they are outside the price range if this review, but are not in the 500K range :-)
« Last Edit: March 11, 2018, 06:24:34 pm by Towger »
Online EEVblog
« Reply #51 on: March 11, 2018, 06:28:35 pm »
Fluke think that you are very wrong indeed:
http://www.fluke.com/fluke/auen/accessories/temperature/80bk-a.htm?pid=55348
260C max
Online EEVblog
« Reply #52 on: March 11, 2018, 06:31:41 pm »
I get an email every week without fail from the endless people at Banggood offer stuff for review. I'll refuse because of their constant spamming.
Online EEVblog
« Reply #53 on: March 11, 2018, 06:32:52 pm »
Perhaps I just misspoke?
Online EEVblog
« Reply #54 on: March 11, 2018, 06:37:25 pm »
Show me a $100 direct tip heater station and I'll review it and compare.
Until then there are $100 class "ancient design" irons, and the more expensive direct tip heater ones, take your pick.
You can do an awful lot with a quality $100 soldering station.
Offline Towger
  • Country: ie
« Reply #55 on: March 11, 2018, 06:40:17 pm »
Dave you also said the original/old Wellers were curie point irons!!!
Offline Towger
  • Country: ie
« Reply #56 on: March 11, 2018, 06:43:26 pm »
The TS100 is now less than $50.
Offline NANDBlog
« Reply #57 on: March 11, 2018, 08:21:55 pm »
Yes, a lot of things can be done with these stations. I could do a lot with the 3000 Dollar weller station at work. But after using a direct heating tip, I realized how bad the actual performance was. And the value for the money. It is clear, that the reputable brands are not interested in a price fight, they can keep it high due to the businesses ordering their equipment without even thinking. This station is basically the same as the 20 dollar Hakko clones on Aliexpress, with better built quality. It has no extra features, and the heating element comes from the past.
I took your challenge, and I found a direct tip heating station below 100 dollars. Aoyue 2930. I dont know how well it works.
There seems to be a lot of stations using Hakko T12 tips also. I'm looking at one now, it has universal AC input, IEC input, with fuse and switch, OLED screen, knob, and metal housing, for some 50 dollar. I think (probably with a genuine cartridge) that these stations would be much better value then the WE1010. In fact I would like to hear your opinion on them.
Offline TheAmmoniacal
  • Country: no
  • Cut me some slack, I'm a biochemist!
« Reply #58 on: March 11, 2018, 08:34:31 pm »
I had the Aoyue Int3210 for a year, because I need a knob (got a bad habit of adjusting the temperature often. I adjust the temperature instead of heating the parts longer). Nothing special, but does the job.
I collect [corporate] mugs.
MTBF ~ 700.000 h
Online EEVblog
« Reply #59 on: March 11, 2018, 09:12:13 pm »
A soldering iron "stick" from a no-name company that has (from many accounts) crap firmware, and is powered from a DC laptop power supply and cable or some other random power source is hardly my idea of a quality soldering station that's worthy of being compared to proper mains soldering stations.
Online EEVblog
« Reply #60 on: March 11, 2018, 09:15:01 pm »
Ok, noted.
I can't give an opinion on something you don't link to.
The following users thanked this post: mauroh
  • Country: no
« Reply #61 on: March 11, 2018, 09:15:14 pm »
For those that want a review of the TS100, mike has one:
I also have one, it works. Not very ergonomic if you have normal-sized hands.
MTBF ~ 700.000 h
Offline NANDBlog
« Reply #62 on: March 11, 2018, 09:37:56 pm »
Ok, noted.
https://www.aliexpress.com/item/KSGER-T12-Soldering-Iron-station-STM32-OLED-DIY-Kits-Solder-Electric-Tools-Welding-Iron-Tips-Temperature/32836043839.html?spm=2114.search0104.3.41.71d36040u7OL1G&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10340_10341_10084_10083_10618_10304_10307_10302_5711211_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_5711315_10621_10620_5722413-normal#cfs,searchweb201603_25,ppcSwitch_5&algo_expid=04c0ccb3-5b5d-4198-8cee-1498c1bcc85e-5&algo_pvid=04c0ccb3-5b5d-4198-8cee-1498c1bcc85e&priceBeautifyAB=0
That is a long link...
Anyway, there seems to be dozens of stations similar to this, with different handles, front panel, power supply. Some of them is DIY kit. I linked this one, because of the 390 review, 370 of it is positive 5 star. It might be worth to do a video on these. Some of them might be actually dangerous, and miss the earthing of the case, or the tip is not earthed, unless you hack it, etc.
Offline ebastler
« Reply #63 on: March 11, 2018, 09:47:57 pm »
This may not be available for much longer: "This product leaves the range, as we want to make room for new products. We are happy to advise you if you need an alternative for this station. The spare parts will be available in future."
http://www.aoyue.eu/aoyue-int2930-digital-lead-free-soldering-station-iron-smd.html
Online EEVblog
« Reply #64 on: March 11, 2018, 10:06:06 pm »
Mike's title says it all. I don't consider the TS100 a proper bench soldering solution, so don't see a point comparing it against those.
Offline Deridex
  • IMHO
« Reply #65 on: March 11, 2018, 10:18:39 pm »
I admit, that i don't know any half decent direct tip-heating-station in that pricerange.
But i'm pretty sure that my little ersa station heats better than both stations you tested.
Online EEVblog
« Reply #66 on: March 11, 2018, 10:23:12 pm »
They were.
The tip lost it's magnetism at a set temperature opening the switch to the heating element.
They still sell them as Magnastat irons:
https://weller.de/en/Weller--Products.html?cat_id=ID521
And as the WTCPT fixed temp station.
http://www.weller-toolsus.com/MagentoShare/media/mannuals/WTCPT_OI_PL.pdf
Online EEVblog
« Reply #67 on: March 11, 2018, 10:25:38 pm »
Which one?
The Ersa WSD80 is the same price, and the i-Con is about 50% higher.
They could very well be better, but that won't matter to the direct-heating fanboys  ;D
  • Country: no
« Reply #68 on: March 11, 2018, 10:27:40 pm »
Aoyue has a soldering iron with induction heating currently on sale: http://www.aoyue.eu/aoyue-int3233-digital-lead-free-induction-soldering-station.html
Anyone tried those?
MTBF ~ 700.000 h
Offline Deridex
  • IMHO
« Reply #69 on: March 11, 2018, 10:28:15 pm »
Check out the Ersa I-Con-Pico (non ESD) or the Ersa I-Con-Nano Dave
Edit: I just noted that the Ersa I-Con-Pico got more expensive since i bought it. I payed 116€ (checked it :) ) and now the cheapest i can find in germany is about 144€. Even though it is still cheaper than the cheapest Weller WE1010 i could find in germany.
« Last Edit: March 12, 2018, 03:11:27 pm by Deridex »
Offline Towger
  • Country: ie
« Reply #70 on: March 12, 2018, 08:18:48 am »
It more than met your price point.  I would recommend a second hand Metcal MX500 for people who want a good iron.  I got one on eBay with 2 handpieces and stands for 100stg a few years back.  Picked up another base (looked never used) for 60 last year.  These are in a different league and bargains are there if you keep an eye out.
« Reply #71 on: March 12, 2018, 08:44:13 am »
Dave, a metcal can be had for 25$ each as I bought them in lots, kept a a couple at home and at work, the rest I sold off. Singles will go for $50. The wands go for $89 as a thermaltronics remake, plus tips are $18 each, original metcal tips were 80hr rated?? of course the sleep stand that will set you back $70 will increase the life a bit. So, total is about $150 or so. Not $100 but a good next step up.
Metcal ps2e-01 40w
https://www.ebay.com/itm/Qty-2-Metcal-PS2E-01-Soldering-Station-Power-Supplies/382401687783?epid=1601722732&hash=item5908eab0e7:g:M5kAAOSwcJNanzi0
wand:
https://www.amazon.com/Thermaltronics-Solder-TMT-9000S-interchangeable-MX-RM3E/dp/B00NS4F4AG/ref=sr_1_1?s=hi&ie=UTF8&qid=1520804279&sr=1-1&keywords=thermaltronics+shp
tip:
https://www.amazon.com/Thermaltronics-M7CP200-Chisel-interchangeable-STTC-136P/dp/B00NS4Q79S/ref=sr_1_1?s=hi&ie=UTF8&qid=1520804703&sr=1-1&keywords=m7cp200
« Last Edit: March 12, 2018, 08:53:24 am by gearshredder »
Offline eV1Te
« Reply #72 on: March 12, 2018, 09:18:19 am »
260C max
It's not often that one finds a subject related to electronics that "Dave Jones himself" does not already know everything about already! (I mean it as a compliment)   :-+
Just to illustrate my point: I fetched one Fluke thermocouple of the same type you had in the video (Fluke printed on the black connector), and one thermocouple that is rated to +1350 deg.C from the manufacturer (Omega USA brand). See images below:
  • Test in water to confirm their accuracy -  Both showed similar reading of 20.1 - 20.2 deg.C
  • Test with torch up to ca 1150 deg.C -  Both showed similar reading of ca 1150 deg.C (depending on how well I managed to position the torch).
  • Verification in the same water again to confirm that their accuracy had not been changed, they both showed the same temperature as they did initially.
Keep in mind that the type K alloy can not handle 1350 deg.C continuously for many hours/days depending on the atmosphere, since it might become oxidized or reduced. For continuous operation at these temperatures the two wires are often covered by a metal tube made out of Inconel or other type of superalloy (the Omega branded thermocouple in the images below is covered by such a tube, hence why you only see one rod and not two wires)
I still believe that Fluke:
  • lists the measurable range based on the temperature rating of the insulation (so that it does not melt or crack)
  • or purposely list a lower range than it can handle so that they can charge more money for other probes. (does not feel like something a serious manufacturer like Fluke would do)
There is one detail that is important to mention, there are also compensation and extension grade thermocouple wires. These consist of a different alloy with similar Seebeck coefficient close to ambient temperature, and have the purpose of being able to extend the length of the wires from a thermocouple.
They are however not intended for forming the tip/junction where the actual sensing takes place, but can in theory form a very crude thermocouple that would be somewhat accurate close to ambient temperature.
Source:
Have a master degree in metallurgy and a Ph.D. in materials science. I work at a company that, among other things, produce thermocouple cables/wires.  ;)
« Last Edit: March 12, 2018, 09:25:23 am by eV1Te »
The following users thanked this post: EEVblog
Offline Monkeh
« Reply #73 on: March 12, 2018, 09:23:44 am »
Metcal ps2e-01 40w
wand:
tip:
Second hand comparisons aren't valid. Availability is limited and hugely variable by country.
Offline cv007
« Reply #74 on: March 12, 2018, 09:25:14 am »
I have an Aoyue 2900 which has long, easily removable tips (tip+heating element I guess). There is a rubber pad included, where you just grab the tip, pull it out, take another tip, push it in. No sleeve to unthread, etc. I don't remember where I got it (probably sparkfun back when they were starting), but I don't think it was very expensive (when in doubt, I get something lower end until I know better). It has worked pretty well, but the tips are harder to find now.
Probably a feature that I think is greater than it really is, but is there any other station in this range that you can just yank the tip out and replace easily? I usually crank up the station, then when I pull the handle out I realize the tip is the wrong one (I only use maybe 2-3 different ones). Maybe unscrewing a sleeve is not so bad, but I figure messing with several hot parts for more than a few seconds will lead to burned fingers.
Offline nowlan
« Reply #75 on: March 12, 2018, 10:51:52 am »
The hakko 951 have a clip that slides the tip and colored handle out of the pencil. You then slide in the tip you want. Not tip so much, but a set of colored grippy handles, that live in their own case. Look at some reviews on YT.
« Reply #76 on: March 12, 2018, 10:54:43 am »
anyone going to bid? 1 hr left I already have plenty.
https://www.ebay.com/i/382401687783
Offline SparkyFX
« Reply #77 on: March 12, 2018, 11:42:56 am »
A coworker once killed a soldering iron by repeatedly cooling it down on the sponge (guess he wanted it to be cool before storing it). The water got soaked up and the heating element either oxidized or broke because of that, hence I only do short wipes on the sponge. I assume the difference of performance between the sponge and the test on copper is that the water can transport a lot of energy a lot faster through the aggregate state change to gas.
Usually i don´t think i would come across a case in which parts would break if soldered with e.g. a 50W iron, as the masses involved are usually low enough to not exceed limits. I don´t do plumbing with it. Higher power irons are of course useful for lowering the time to heat up when taking the iron out of the stand, which is nice in some commercial uses and in comparison tables. Otherwise while soldering you exchange the temperature critical part with the time critical part of that manual process and need to be careful anyway. So I thought pre heating is the way to go in corner cases like TO220 tabs to heatsinks, but thats where one could also easily blame lack of thermal considerations of the application if its not working without that? Of course i also got that bigger iron lying around, just in case and for tinkering around.
I recently accompanied my old ELV LS 50 with a WER 853D and the same ZD 985 desoldering iron that was tested a while ago, because... more displays, a set of tips i did not yet have and hot air. An older Weller at work does the job as well as some propane soldering irons (no PCB work, though).
Online MT
  • Country: fo
« Reply #78 on: March 12, 2018, 11:51:18 am »
Soddering jobs? There should be a all shootout for battery based soldering irons.
https://www.amazon.com/Weller-BL60MP-Soldering-Rechargeable-Lithium-Ion/dp/B00UM69TW2
« Last Edit: March 12, 2018, 11:57:23 am by MT »
Offline cv007
« Reply #79 on: March 12, 2018, 12:42:03 pm »
Thanks. It looks like the sleeves may be a nicer system as you can get extras inexpensively, and don't even need to grab the hot tip at all.  A few extra sleeves with the most used tips(cartridges?) would make the changes quick and safe.
A nice review (pretty thorough, quite long, but not too boring)
w w w.youtube.com/watch?v=YYZs_pewRd4
A bit higher in price than what I would prefer, but for some reason that is always the case it seems.  The 'user interface' is not great (including the 1970's led display from a wristwatch), but at least the tips should be available for a long time.
Maybe I need just need the iron, and make my own power supply with my own 'user interface'. My idea of a user interface is a power switch, one  2-3" diameter knob that feels like a large rheostat when turned (to set temp), 2ea (each different color) 4 digit 14 segment led's, one to show set temp, the other to show actual temp and any other info via alphanumeric capability. Maybe a push button switch if necessary. All in a nice solid simple box.
« Last Edit: March 12, 2018, 03:45:31 pm by cv007 »
Offline rbm
« Reply #80 on: March 12, 2018, 03:51:40 pm »
If the Weller WE1010 uses the same user interface design decisions as were taken in other Weller soldering stations, then at least one press of either the UP or DOWN keys on the console will wake up the iron from temperature setback.  I have both the WRS1001 and WRS1002 stations and this is typical behaviour for them.  There is no acceleration sensor in the handle to sense if the operator picks up the iron (to command the base to bring the tip back up to temperature) so shaking it or waving it in the air will accomplish nothing.
- Robert
Online Fungus
« Reply #81 on: March 12, 2018, 08:12:25 pm »
Luckily you have BOTH things then...
The wool stuff is great for removing large blobs of solder from the tip.
« Reply #82 on: March 12, 2018, 08:33:16 pm »
Please show us your proof how the soft brass is damaging the iron plating. I'm sure that the thermal cycling from wet sponges is MUCH gentler.  :palm:
and leaves a mess.
My brass cleaner leaves all the mess neatly inside the Hakko stand, where I can easily empty it out into the trash.  I poke my iron in and out, not brush it across like Dave did.
Offline onlyrgu
  • Engineer by Nature!!
« Reply #83 on: March 12, 2018, 10:45:20 pm »
I used to have hits for Halloween, But now I'm blindly love with my ES120. Dave I think a comparison video will be awesome!!
Offline Maxlor
« Reply #84 on: March 12, 2018, 11:40:46 pm »
I knew that screwdriver was fancy, I didn't know it could solder too!  ;)
Online EEVblog
« Reply #85 on: March 13, 2018, 12:39:01 am »
Yes, I've seen the insulation on mine start to melt above the max temp.
Online EEVblog
« Reply #86 on: March 13, 2018, 12:41:43 am »
Sorry but 2nd hand stuff does not count for review comparisons.
Potentially thousands of people buy stuff based on my reviews, 2nd hand doesn't cut it.
Online EEVblog
« Reply #87 on: March 13, 2018, 12:44:39 am »
It doesn't matter. It doesn't not meet my requirement of a bench soldering station.
My blog, my rules  :P
The following users thanked this post: luma
Offline NANDBlog
« Reply #88 on: March 13, 2018, 01:26:55 am »
And what do you think about the T12 that I've linked?
It actually looks quite decent IMHO.
Offline Spence
« Reply #89 on: March 13, 2018, 03:50:22 am »
I have the Weller WE1010 and been using it for about 2 mouths now and I'm not really very happy with it. Sure it works just fine but it has a few issues that I feel it really should not have.
1. It is really very slow too heat up and just as slow to recover. I also had to add +25C offset to get it to its set temp.
2. No presets?? WHY??? It would have not costed anymore to add this function to this unit.
3. Wake up from stand by!! Takes for ever if you can get it to do it, so every time you want to wake it up you have to push a button! How much would have it added for them to add switch in the pencil??
4. Ok this is a small one BUT,,,, NO back light??? In the sale photos it looks like the LCD is back lit, but it's not,, why?? at some angels with the lighting that I have I cant see the LCD because of the glare. With a back light this would not be a issue plus it would also be a indicator that the unit is on. Sure I could hack it and add a few 3mm led's but I really should not have to do that at the $115.
But with all that is does solder well and I really do like the pencil though it does get hot when used for a long time,,, because I have to keep the stand by set at 60min.
I may try a Quick just to see how they work..
Offline free_electron
    • SiliconValleyGarage
« Reply #90 on: March 13, 2018, 03:52:51 am »
Weller has the heating element in the sleeve ! That wobbly bit in the middle is just the temperature probe. The actual heater sits in the outer portion.
No chance of breaking the ceramic cartridge with weller.
that being said. The response of the iron is actually good. The hako reacts way too fast.
Here is the problem : Flux takes time to activate and it should be (almost) completely gone by the time you enter the liquid phase of the solder. Heat it too fast and not only will it evaporate too fast , it will spatter , flinging blobs of unactivated flux, and possibly tin , everywhere on the board.
There is nothing worse than having remnants of unactivated flux on the board. it will eat copper over time. People forget that unactivated flux is very corrosive stuff. Activated flux still poses problems. it can be electrically conductive (especially rosin based) , or absorb moisture and saponify (water soluble)
If the iron has too much thermal mass or too fast a response time you will spatter the flux leading to a bad joint.
The right tool for the right job. you don't solder a TQFP with a petrol stoked iron , nor do you solder a TO220 with a microtouch ... ( although you can with the right tip )
Keep in mind that this is an entry level allround soldering iron.  More advanced stations actually know what tip is inserted ( the ones with the active tips where the heating element and sensor are inside the tip and thrown away at end-of-life ) and they adapt their response time appropriately.
As for the hako. Looks like fisher-price.... Sorry. but that colour scheme is just .. wrong for a technical device. Imagine Agilent /keysight having test equipment that looks like that ... it'd look like Tektronix ...
The weller aqua blue is their 'trade dress' just like brown/yellow fluke. weller has used that color since the 60's ...
I'll stick to weller and Ersa any time. The other players are too young.
Offline Towger
  • Country: ie
« Reply #91 on: March 13, 2018, 04:37:20 am »
My blog, my rules
Have a look at the price of a real Hakko FX888D in Europe, it is far from entry level.  Maplin had them for a ripoff €224, reduced to €179 by the liquidator.  https://www.maplin.ie/p/hakko-fx-888d-70w-mains-solder-station-a86uf
€179 is $280 AUD, for that money there is plenty of other choices.
Offline IanB
« Reply #92 on: March 13, 2018, 04:37:33 am »
Manufacturers describe certain fluxes as "no-clean flux" because it is not essential to clean it off the board after soldering. Appropriately designated fluxes do no harm if left behind.
If you splatter the flux you are using too high a temperature. The flux should melt and softly bubble, not splatter or burn.
« Reply #93 on: March 13, 2018, 04:52:41 am »
Provided it is fully activated ! unactivated no-clean is just as bad as , if not worse than , regular flux ...
[/quote]
That is why the temperature on the tip should 'dip'. Look at a reflow curve. there is a time for warmup , an activation time, a ramp to liquid phase , a liquid phase and a cooldown.
The same is true for solder wire. the formulation for the powder flux in solder wire is different from the liquid fluxes out of a pen.
The flux inside hollow core wire can not come out of the wire before the solder has gone liquid !
Liquid flux is added before the solder goes liquid. The flux core comes out once the solder has gone liquid.
I see many times peple mixing fluxes. one type in the core , another type in the pen ... big nono !
You need to stick to the same manufacturer of solder and flux. And you need to use compatible liquid flux that is appropriate for the wire being used.
Offline 2N3055
  • Country: hr
« Reply #94 on: March 13, 2018, 04:57:21 am »
My blog, my rules
How about Italy ?
https://www.batterfly.com/shop/hakko_fx-888d
Offline IanB
« Reply #95 on: March 13, 2018, 05:24:57 am »
I really don't think so. Activated flux "RA" or "rosin, activated" type is quite corrosive and must be cleaned after soldering. The less active types like "RMA" or plain "R" are less corrosive and can often be left behind.
I don't have any solder wires with powder flux inside them. In every case it is gel flux, and it runs out of the wire when heated, and before the wire itself has melted. That's why high quality soldering procedures require you to cut off the used end of the solder wire before each new joint and start with a fresh cut end.
« Reply #96 on: March 13, 2018, 06:51:21 am »
with 'activated' i mean heated to the point it begins to work. The flux is 'spent' ( not necessarily fully evaporated ) if 'unused' flux remains : that is corrosive. 'used' flux ( flux that can no longer do its work, essentially the leftovers ) is not really corrosive the trouble begins when unused flux is left behind..
same thing. some companies use a gel , some it is a powder like form (Stannol brand or multicore brand)
:clap: :clap: :clap: :-+ :-+ :-+ :-+
And how many people know that one ??
The common usage is: cheapest soldering iron , cheapest solder wire , one temperature setting : maximum. And heap on the solder.... Everyone wants a soldering stations and then dials it to maximum... "because it don't heat fast enough" for their liking.
note : he is using ... a Weller... :)
« Last Edit: March 13, 2018, 06:57:40 am by free_electron »
Offline Towger
  • Country: ie
« Reply #97 on: March 13, 2018, 07:45:58 am »
Vincent,
What special soldering techniques (if any) are required to insure the reliability of automotive electronics in a zero vacuum environment?
« Reply #98 on: March 13, 2018, 03:03:13 pm »
Vincent,
None. It worked as well in space as on earth.  >:D
Online EEVblog
« Reply #99 on: March 13, 2018, 09:39:20 pm »
Careful, the Metcal fanboys will be livid. Instant heat is their lord and savior  ;D
Offline Towger
  • Country: ie
« Reply #100 on: March 14, 2018, 12:59:08 am »
This is confusing too fast with too much heat.  It is the same train of thought as 'turn up' the heat for larger/heaver jobs.  Turn it up to 11.  :blah:
Offline Towger
  • Country: ie
« Reply #101 on: March 14, 2018, 07:04:10 pm »
Rossmann's video response and rant on the price if Made in USA Pace soldering equipment.
Note: The word Metcal is not mentioned.
The following users thanked this post: 3db
Offline Psi
« Reply #102 on: March 14, 2018, 07:18:29 pm »
You don't even have to pay $100 for a 951 clone.
These china soldering stations take the same T12 tips that the hakko 951 use. With heater and tip in one.
https://www.aliexpress.com/item/138x88x38mm-Digital-Soldering-Iron-Station-Temperature-Controller-EU-Plug-Temperature-180-435-Degrees-T12-Handle/32692999653.html
So you can get one for $38 and slap a genuine Hakko T12 tip on it.
but TBH the tip that comes with it is actually not that bad, so you don't even need to do that.
(It's a large chisel tip though, so no good for ultra small SMT, fine for 0805 though)
« Last Edit: March 14, 2018, 07:25:49 pm by Psi »
Offline Sjokolade
  • Country: no
« Reply #103 on: March 15, 2018, 06:49:46 am »
Dave, did you throw away the small sponge pieces or did you follow Hakko's directions for the sponge ?
If you did not fit the small pieces your sponge won't be damp.
Edit:
After looking at the video again I see you did not lay the two small sponges in the tray, they are still attached to the main sponge  :-DD
« Last Edit: March 15, 2018, 07:02:37 am by Sjokolade »
If at first you do succeed try not to look astonished
The following users thanked this post: NiHaoMike
« Reply #104 on: March 15, 2018, 01:39:12 pm »
Wouldn't the temperature be less on the metcal in order to do the same job? hehe.  Of course you only really have 3 main temperatures to pick from but you can limit the "reaction speed" by picking tip with less mass or further from the coil.
The cost on the new soldering equipment is outrageous. That's why I buy used like from ebay and repair if I need to. But of course like dave said, It's not feasible for someone starting out. This is also a hobby for me so it doesn't really matter in the end lol.
Offline TuxKey
« Reply #105 on: March 15, 2018, 07:45:04 pm »
looks to good to be true.. i'm afraid it will burn down my house...in theory one could by this unit an use a Hakko tip for it..
But still.... would be worth a test by his lordship mr.Jones
would consider shipping in to have a good technical review of this.. What do you say Dave ???
Offline TuxKey
« Reply #106 on: March 15, 2018, 08:01:53 pm »
Hi guys,
i'm new to this forum and bin watching Dave's vids for a year or two now..
i'm a total noob when it comes to electronics, soldering and such things..i'm a IT nurd Linux/Unix sysadmin.
Currently taking sum time off..studding for my certs and all.
For a long time i wanted to get in to building my own mechanical keyboards and modding older boards.
i was all set to jump in and buy the FX-888D and the FR-301 bundle from batterfly.com for €375 did sum research watched tons of vids about both devices..
BUT THEN i saw "Louis Rossmann"  post his vid titled Soldering station technology & the lie of "SOLDERING PATRIOTISM"
So i decided to watch all vids i can get my hands on, read about both..i knew about the TS100.. Asked around downloaded the manual and found out it got hot after 40min of use. The user manual states:
 After continuous use up to 40 minutes, the handle surface temperature will reach 50°C~60°C.
Seems a bit toasty..
i read pretty much all the comments in this thread..
with my limited understanding this is what i understand..
direct tip heater station is what Louis was referring to.
Dave stated that these devices are more expensive so it's clear..
as mentioned by free_electron
So my question is two fold.
1) @dave would you consider reviewing this?
https://nl.aliexpress.com/item/110v-220V-digital-Soldering-Iron-Station-Temperature-Controller-T12-Handle/32345223517.html?spm=a2g0z.search0104.3.112.30e9607fZtqf7g&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_10342_10343_10340_10341_10696_10084_10083_10618_10304_10307_10301_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_2,ppcSwitch_3&algo_expid=ef2a252e-684e-4e91-af7f-bbbff4c0f478-15&algo_pvid=ef2a252e-684e-4e91-af7f-bbbff4c0f478&priceBeautifyAB=0
2) as a noob soldering keyboards and later getting in the repairing electronics learning everything about electronics is it worth
buying the more expensive FX-951 and buying the de-soldering gun FR-301 or should i just go with the FX-888D ????
Please help..
is the newer tech really that much better???
Someone even suggested i look at the FM-204 with the FM-2027-3 ..that's a €1022 bundle !!!! OMG that's a bit on the high side of things..
My head is spinning with info.
Offline Bud
« Reply #107 on: March 16, 2018, 02:14:27 am »
Rossman's advice is very short-sighted and only makes sense to hobbycist and mom/pop shops like his. And to me it is not about patriotism, which i myself do not give a dime for, but practicality, less headache during operation and money saving long term. It is one thing if you pull your iron out here and there and if the tip fails it is ok you can wait two weeks for another one arriving from Banggood, and it is totally different when you are on schedule to deliver products to your customers. You quickly realise that you do not want additional problems generated by your shitty tools and to have no manufacturers support. Did Rossman performed failure analysis for either the base stations or tips? Guess not because cheap was everything he was able to see.
Offline madires
« Reply #108 on: March 16, 2018, 02:41:33 am »
Another point missed in the old tech vs. new tech discussion is that there are old tech soldering stations playing in the same professional league like the new tech ones, e.g. the ERSA i-CON with the i-Tool iron. Sadly they are ignored in most comparisons/shootouts.
« Reply #109 on: March 16, 2018, 04:39:43 am »
nonsense ... the statement "jbc was first with heaters in tips in the 2000's" is blatantly false. Weller had that with their microtouch stations long before that ! i had my first microtouch in 1992 ...
Offline Monkeh
« Reply #110 on: March 16, 2018, 04:55:22 am »
Don't forget Metcal in the 80s and early 90s..
Offline ebastler
« Reply #111 on: March 16, 2018, 05:38:00 am »
Could someone please remind Louis Rossmann that it is entirely acceptable to cut a video?!  :palm:
I lasted through nearly 5 minutes of him switching windows, scrolling around the screen, wagging his mouse pointer, and trying to drag up other videos while I stared at a black screen. But this thing goes on for 30 minutes total! Unwatchable, and an imposition on the viewer.
Louis, if you read this: You can do better than that! (And you should, really.)
Offline Monkeh
« Reply #112 on: March 16, 2018, 05:38:36 am »
It was a livestream.
Offline ebastler
« Reply #113 on: March 16, 2018, 05:46:39 am »
And it is painful to watch.
I am sure it was just as painful when it was streamed live. :P
I just can't be bothered wasting my time on this -- especially given the total lack of interesting, new information in that video. Come on, the only "data" he shows in 30 minutes are from a JBC ad? (And he acknowledges that there is probably some marketing spin on that one, and then continues to treat it as gospel?!) Thanks, but no thanks.
« Reply #114 on: March 16, 2018, 10:16:33 am »
Same here. I don't have hours to spare to watch his videos.
Offline rrinker
« Reply #115 on: March 17, 2018, 04:29:15 am »
 While it's rather obvious the 'modern' style will recover faster, I've had no complaints with my 'old style' Xytronic, which I originally purchased for my other hobby, not just electronics. That being, model railroading - for soldering rail and building my own turnouts (switches). If nickel silver rail isn't a huge heat sink I don't know what is, and I've never had any issues with the temp holding up to make repeated joints, sometimes soldering two rails together, sometimes soldering rails to cut pieces of copper clad board used as ties.
 As Dave said, it may make sense for more of a production environment, but for hobbyist use, even on things relatively heavy like the model train rail, I don't see any issues. And of course I've used it for electronics as well, no problems assembling any number of boards or doing point to point circuits. The model I have is only rated at 45 watts, too.
 My only regret is not buying one of these things 30 years ago. I used to have an array of traditional irons, from 15 watt to 60 watt, to handle a range of jobs. This one replaced them all, except the heavy duty gun (and torch for plumbing). Despite the basic equipment I used back in the day, I never fried a component - of course I always socketed any IC.
Offline Cliff Matthews
    • General Repair and Support
« Reply #116 on: March 22, 2018, 12:10:06 pm »
Tossing in a monkey-wrench: Funny German reworks 245w JBC mega-tip to fit the TS-100 (gifted to him by Frankie no less..)
The following users thanked this post: labjr
Online KL27x
« Reply #117 on: March 26, 2018, 04:56:39 pm »
Rossman's advice is very short-sighted and only makes sense to hobbycist and mom/pop shops like his... You quickly realise that you do not want additional problems generated by your shitty tools and to have no manufacturers support. Did Rossman performed failure analysis for either the base stations or tips? Guess not because cheap was everything he was able to see.
A lot of members are also on T12 clone fans, so I don't think his opinion is terribly unpopular. But...
For a guy claiming "I'll 100% go for the cheap rip-off of a better/newer technology"
1. He uses genuine Hakko 951. This is not a knockoff
2. The iron he used before the 951, IIRC, was a cheap knockoff of 936.
His experience would appear to be comparing the genuine Hakko 951 as representative of the "newer technology" vs a $30.00 Chinese import to represent the "old school" ceramic heater irons. This is exactly the opposite of what he advocates. Maybe he assumes some performance differences as being attributable to the "new technology" where they may really be due to Hakko quality. And similarly, you can't use a random Chinese 936 clone and expect it to be representative to a Hakko 888. They are not the same product. This is perhaps an even bigger assumption. The performance of a ceramic heater 936 style of iron depends heavily on the construction and materials in the handpiece.
3. When he "reviewed" a 951 knockoff... And this was way back when TS100 and T12 clones weren't everywhere and I was actually interested in hearing about hands-on impression and performance comparisons... Well.. the short takeaway I recall was he attempted to solder a large SMD connector with the knockoff using a fine point tip (which even he said while doing it, it was the wrong tip for the job); then the genuine station he used an appropriate 3mm bevel tip, which aside from the spatula is essentially the biggest, baddest tip you can put in a 951. No surprise, the proper tip worked way better. Then he found a penis-shaped soldering joint in the clone and proclaimed it was a POS. This was very disappointing and a total waste of time. I'm still angry I watched/skipped through pretty much all of that video looking for actual performance data and some kind of pertinent if not objective opinion.
« Last Edit: March 26, 2018, 05:59:42 pm by KL27x »
  • Country: no
Re: EEVblog #1063 - Weller WE1010 vs Hakko FX888D Soldering Station
« Reply #118 on: March 26, 2018, 06:27:18 pm »
Louis Rossmann's opinion is based on his review of a fake FX-951:
He would pick this over any new "old technology" for what he is doing.
MTBF ~ 700.000 h
Online KL27x
« Reply #119 on: March 26, 2018, 06:51:52 pm »
^ Are you defending him?
This IS the "review/comparison" I was talking about.
If you can provide a timestamp which suggests he did anything but compare markings/housings, critique the quality of solder joints, do a single comparison with polar opposite tip types, and repeatedly call this knockoff crap with nothing to back that up, I will be glad to have it. I remember scouring through this vid in disbelief that this was the entirety of the substance. In addition to the lack of information in the video, I also did not get the impression that he tried it out or kicked the tires beyond what was shown here. You could easily show why it's crap if it is so. Maybe scope the power output waveform. Show the problems with response algorithm. Maybe put a thermocouple on it. Check that the psu has enough output relative to the genuine. Or... use it for awhile?
And his experience with any of this "new old technology" is what, exactly? I watched several of his early vids, and I'm pretty sure he used a cheap 936 knockoff before upgrading to the 951. Perhaps he is over-generalizing his experience with this cheap Chinese knockoff to the top hakko, weller, ersa, and pace irons which use passive tips? In this vid, he does nothing but bash the knockoff with no objective reasoning other than penis-shaped soldering joints and a connector that doesn't snap-fit as nicely. And now he says this POS he has hardly used is obviously better than an Ersa Pico or 888 or Weller 1010 which he has maybe never used?
« Last Edit: March 26, 2018, 07:24:59 pm by KL27x »
Offline ebastler
« Reply #120 on: March 26, 2018, 07:02:33 pm »
I find that the signal/noise ratio of Rossman's live streams is generally extremely poor. I don't think he is doing himself a favor with these -- it is a rapid way to generate "content", but also a great way to damage his reputation.
Personally, I don't watch his stuff any more, because I feel it is a waste of time.
Online Nusa
« Reply #121 on: March 27, 2018, 04:47:18 am »
I'm not going to rewatch to hunt down timestamps for you, but you're overdoing the rant for something you actually admit you only skimmed through rather than watched.
a) So what about whatever history he has with 936 type irons? Most of us have that kind of history. They STILL work well enough for hobbyists, but virtually everyone who's tried the better technology prefers it. What's your point?
b) Yes, the tip he used initially was the wrong tip for the job, and he said as much. Later, he used one of his genuine tips in the knockoff iron and deemed the iron reasonably powerful and the performance acceptable.
c) He spent some time ripping Hakko when talking about the genuine irons user interface. They deserved that, in my opinion.
d) There were differences in the knockoff. Most obviously, the auto-cooldown feature was missing entirely, which means it's an always on iron. The handle design was also different, not even close enough to be called a knockoff. The cradle was crappy with a sponge instead of brass wire.
e) He did a teardown at the end. The soldering quality of the pcb construction really did suck. Besides that penis-blob, he knocked off some solderballs. And as the title picture shows, the LED leads were left unclipped, which is somewhat less than professional.
f) How much have you donated to Louis for making videos? I suspect you got more value than you paid, no matter how much you hated it.
Online KL27x
« Reply #122 on: March 27, 2018, 05:28:53 am »
Scoured more than skimmed. Like after watching it, in it's entirety, I had to go back to make sure I didn't miss whatever it was that led him to act like the iron could solder for shit. Don't need timestamps for any of that. I remember all that fluff.
None of that stuff should make one believe the iron can't solder for shit given the use of the same, genuine tips. Yet that is the impression he throws off throughout the video.
Rant? Unclipped leads are why an expert knows the thing can't solder for shit before he even tests it objectively. Got it.
"Reasonably" powerful and "acceptable." What a waste of breath. If it is less powerful or less responsive than the genuine, as this clearly implies, it should be easy to demonstrate. I expected a half hour video to show each station doing the same job using the same genuine tips for at least a few seconds of that ghastly video, maybe? Even better, he could have soldered a wire to the plus and minus traces of each station and scoped the output while touching (the same tip, duh, and set and verified to be set to the same temp) to a wet sponge or something. 3 minutes of that would be worth more than his entire video "comparison." (If you call what I do a rant, you can't even call this a comparison or review; this video is the rant). He doesn't even deserve to offer an opinion on relative soldering performance based on anything he did in this entire video.
This isn't the problem. He used the shitty tip on the knockoff and the polar opposite tip on the genuine in his only side-by-side comparison test.* |O |O |O |O |O |O Can someone really be oblivious enough to do this on accident and not take 10 minutes to redo this test? Maybe he is so smart he knows his core audience wants to see a beat down and rant. Maybe his core audience is really that... uh... there for this entertainment vs insight. And his own acknowledgement of the tip difference didn't stop him from implying the knockoff couldn't solder for shit.
But now this station that can't solder for shit is amazing. Compared to $100+ dollar stations. Because it has knockoff elf technology. Comparing this cartridge thing to outdated BS technology that is in use in high end business everywhere, we don't need to test how it works. We don't care about unclipped leads or sleep or other features. But when comparing the real 951 to the knockoff, somehow all these little nitpicks means the knockoff can't solder for shit.
*This elf technology is so much better, you can just stick a BR tip on there and drag solder big connectors, right? That's the point? He didn't even attempt it with the genuine station; he put the biggest tip on it.
« Last Edit: March 27, 2018, 06:22:10 am by KL27x »
« Reply #123 on: March 27, 2018, 06:43:40 am »
FWIW, Pace posted some solder tip info in manufacturing. Handy facts one wouldn't think of.. (some sponges contain sulfur?)
The following users thanked this post: MacMeter
Offline LektroiD
  • If it didn't explode, I'm happy.
    • Music here
« Reply #124 on: June 08, 2018, 09:08:40 pm »
I just bought the Weller WE1010, but I think I have a faulty unit, as the backlight shown on all their marketing ads is not working, and I can't find a way to switch it on. I've sent the following message to Weller about the issue... I'll post up any further correspondence from them...
Hi, I just purchased a Weller WE1010, but I can't seem to activate the backlight shown in all your marketing ads. Without the backlight working, it's really hard to see the display from most angles at my bench. I cannot find how to activate the backlight in the manual. Please advise how to switch it on? or have I got a faulty unit?
Online Nusa
« Reply #125 on: June 08, 2018, 11:12:00 pm »
I don't think there is a backlight, nor have I seen any actual photographs/videos/audio/text that claim there's a backlight. However, most of Wellers ads and box art are clearly rendered graphics, not actual images/videos. I agree that might be a bit misleading.
Offline labjr
« Reply #126 on: June 09, 2018, 12:35:23 am »
Looks like the price went up too. You can get a Pace for $100 more.
Offline David Hess
  • DavidH
« Reply #127 on: June 09, 2018, 06:49:09 am »
Fluke and others base the temperature rating of those thermocouples on the insulation.  The ones with Teflon insulation work for soldering iron tip measurements but the lower temperature ones work fine also even though their insulation near the tip eventually scorches.
I really like the old Weller Magnastat irons.  They have a good selection of inexpensive tips and old stations can be refurbished inexpensively.
The Weller WES51, WESD51, and WE1010 all use the Weller ET series tips which is nice since they are readily available and inexpensive.  I wish Weller had an ET series vacuum desoldering tool though.
Online EEVblog
« Reply #128 on: December 05, 2018, 11:11:59 pm »
The magic smoke escaped!
Offline David Hess
  • DavidH
« Reply #129 on: December 06, 2018, 02:22:29 am »
Doh!
Many years ago I lent my nice and expensive Weller Magnastat 120 volt AC pencil iron to a friend who did contracting work whose soldering iron had failed.  He returned it a couple of days later saying it did not work either.  It ends up what had happened was that the new 120 volt AC wall plug he was using at the contracting site was wired incorrectly to 240 volts AC which is what burned out his soldering iron also.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #130 on: December 08, 2018, 06:53:19 am »
Weller does not use primary fuses in none of their station, and I believe they never did. I've never seen one.
I don't understand this design choice, but I must admit that I've never seen a damaged transformer in none ot the tenths of Weller stations I've worked with or that were in the benches near mine.
The mains wiring of Dave's station in not compliant with safety regulations and good workmanship standards: the three female terminals are un-insulated and the three wires are not tied toghether, as is considered a good practice. If one of the them is detached by accident, it can touch one of the others, with safety risks: ground terminal can touch live, resulting in a live soldering tip, or short live and neutral....
The transformer's lamination are welded together to save money and assembly time, and are not intercrossed (I don't know the ecorrect english term)  as in good EI transformers.
This results in a non serviceable transformer.
This soldering station is EXPENSIVE, for what you get.. it should made to a more professional standard.
Best regards
Ciccio
Strenua Nos Exercet Inertia
Offline cdev
« Reply #131 on: December 08, 2018, 07:18:48 am »
Dave, I just wanted to let you know that my FX-888D came with a nice (approx) 2mm chisel tip.
I don't know if this is standard now but mine did.
I don't remember exactly when I got it, probably around the same time as this video came out.
I bought it from Frys when it went on sale for $90.
