Author Topic: EEVblog #1083 - Pocket Mutimeter Shootout  (Read 22119 times)
Offline EEVblogTopic starter
« on: May 14, 2018, 01:02:34 am »
14 pocket multimeters from $8 to $65 are torn down and compared for feature set and build quality.
Ranging in price from $8 to $65, which one is the best in each price category?
Timestamps:
6:07 XB866 Wun Hung Lo
9:42 ANENG AN8203
15:47 $10 Shootout Summary
16:14 Uni-T UT10A
19:12 Uni-T UT120B/120C
22:41 UNI-T Shootout Summary
23:05 Jaycar QM1544
26:42 $20 Shootout Summary
27:06 Sanwa PM3
31:06 Brymen BM22 / Amprobe PM51
37:31 Kyoritsu KEW1018
42:01 Hioki 3244-50 CARD Tester
45:47 Amprobe DM78C
50:25 DER EE DE-19S
56:27 SANWA PM300
1:02:36 Conclusion
Use coupon code "pocket" for a big discount on the PM300:
https://www.eevblog.com/product/pm300/
Part 2:
« Last Edit: May 15, 2018, 02:44:42 am by EEVblog »
The following users thanked this post: voltlog, Electro Detective
Offline Electro Detective
Re: EEVblog #1083 - Pocket Mutimeter Shootout
« Reply #1 on: May 14, 2018, 02:27:26 am »
One hour of 'Pocket Mutimeter Shootout' heaven for the viewers  :clap:
How many hours spent to produce it?
Would welcome a quickie Part 11 specs shootout
FWIW, Sanwa PM300 looks like it will survive drops better from 'shirt height' which is bound to happen,
bent/sat on in the jeans pocket, weather extremes, rain etc when closed,
and probably live through some cat and dog chomping too   :scared:
« Reply #2 on: May 14, 2018, 02:42:24 am »
Part 2 shot this morning with some basic testing. I was able to kill the ANENG  ;D
« Reply #3 on: May 14, 2018, 02:42:46 am »
« Reply #4 on: May 14, 2018, 02:44:09 am »
Not that long, maybe 3 hours to shoot, and 2 hours to edit.
Yes, the rubber case would be the best in that regard.
« Reply #5 on: May 14, 2018, 04:29:48 am »
My UT120C shows 10.17nF so it is a feature not a bug.
Perhaps they realised it couldn't read low values accurately (or at all) and whacked in a 10nF in parallel and rely on the delta function to read lower?
Offline daveshah
  • Country: at
    • Projects
« Reply #6 on: May 14, 2018, 06:57:11 am »
I've noticed the 10.17nF thing too on my UT60x (can't remember the last letter). From memory the manual even told you to use the delta function for small capacitors.
Offline Cnoob
« Reply #7 on: May 14, 2018, 10:17:53 am »
I googled DER EE  http://www.hktdc.com/suppliers-products/Pocket-Multimeter/en/1X00III0/1960503/
They sell a DER EE  pocket multimeter model DE-19A which comes with a current probe and I am guessing that extra
compartment at the back is for that.
On PCB build quality, layout and no after thought looking components I like the Hioki the best.
But as a pocket multimeter I like the Sanwa PM300
Offline Cnoob
« Reply #8 on: May 14, 2018, 10:59:22 am »
Offline Cnoob
« Reply #10 on: May 14, 2018, 12:09:17 pm »
not sure if it is a rebadged one buttons are a different shape and dial different grip pattern.
Online Fungus
« Reply #11 on: May 14, 2018, 12:41:05 pm »
Need one that measures current safely?
PS: Am I the only person in the world that's noticed that you can EASILY close the case on those cheapie slotted-case meters when the switch is in the wrong position?
(...and that it's almost impossible to open them again afterwards?  :scared: )
« Last Edit: May 14, 2018, 01:28:24 pm by Fungus »
Online Fungus
« Reply #12 on: May 14, 2018, 01:08:20 pm »
What's the thing circled in red on the DER? Why is there a gap in the case there?
Maybe the space at the back is for a different model with an expansion module or something.
It looks like there's enough lead inside that you could wiggle out a few mm to make the wrapping+storage a bit looser. It should definitely be a bit looser by default though.
Edit: Aha! Mystery solved! They make a version with a current probe that attaches there. The extra space at the back is to store the probe:
« Last Edit: May 14, 2018, 01:21:40 pm by Fungus »
Online BillyO
« Reply #13 on: May 14, 2018, 04:00:37 pm »
For what it's worth, the Aneng AN8203 does indeed have a tripod stand.  In fact, it's one of the best and most sable I have ever used.  Just don't throw out the little strap it comes with.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline Neilm
« Reply #14 on: May 14, 2018, 06:13:11 pm »
Interesting how many of these are both CE marked and rated CATII. To be CE marked (properly), it would have to meet IEC61010 and the section on multimeters explicitly states that anything rated for connection to mains must be CATIII as a minimum.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #15 on: May 15, 2018, 01:04:53 am »
But a CE mark can be self certifying, it does not have to be independently EMC or safety tested. Hence the majority of multimeters sold that are not independently UL/ETL etc tested for safety.
Offline Cnoob
« Reply #16 on: May 15, 2018, 08:06:20 am »
would it be a good idea to compare the best 3 pocket meters to a small Brymen (BM253) to see how they perform against it.
I bought a fluke 101 recently and it's slow and vague compared to my other meters. (measuring resistances is painful.)
I'm thinking of getting a keysight U1242C when I have the funds.
Offline nixfu
« Reply #17 on: May 15, 2018, 03:02:45 pm »
Interesting to note that the AN8203 was bang on until you killed it.
DAVE, you should open the AN8203 and at least see if it was anything easily fixable.
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
Voltlog #162 - Pocket Multimeter 1KV Testing and CAT Ratings
« Reply #18 on: May 15, 2018, 03:19:32 pm »
In this video I am testing the pocket multimeters by applying transient voltages to their inputs (generated with a Brymen 887 Insulation meter) and we’re also going to talk a bit about CAT ratings and what they mean.
VoltLog
https://www.youtube.com/channel/UCdXHgsCiql_78oT5ydXWvzA
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Online Fungus
« Reply #19 on: May 15, 2018, 03:34:54 pm »
If the display went blank then it's probably the main chip.
Does nobody else hate the wallet cases? They put the probes right in the 'hinge' so they never close properly. Always flapping around and opening.  :scared:
Also: How long before the bits of velcro come unstuck from the probe straps? Don't tell me you never saw that happen.
(Maybe Sanwa have some magic velcro glue but I'll wait for the long term report  :-// )
« Last Edit: May 15, 2018, 06:40:56 pm by Fungus »
Offline Cliff Matthews
    • General Repair and Support
« Reply #20 on: May 15, 2018, 03:42:30 pm »
Maybe Dave's AN8203 sample was defective. Here: https://youtu.be/pnv5qJoWIak?t=693 he's uses an even higher voltage but for less time and didn't kill it. The ohms short seemed to show the PTC cooling off I think.
I still prefer that loud continuity beeper over the Uni-T, and IMHO that little Sanwa would be a welcome addition to the store.
Offline WN1X
« Reply #21 on: May 15, 2018, 03:50:10 pm »
Of course you killed it, Dave. The Aneng case says "auto power off" and it did lol :-DD
- Jim
Online Fungus
« Reply #22 on: May 15, 2018, 07:23:55 pm »
Maybe it's luck, or maybe a slight variation on what's inside. Those meters are like DT830s, there's dozens of variants with completely different internals.
Mine definitely has a loud beeper. Out of the three pocket meter I own it's the one that feels most like a "real" meter, I just hate the case and it doesn't do amps (which I want - I don't ever go poking at mains AC with mine).
Offline voltlog
    • VoltLog
« Reply #23 on: May 15, 2018, 07:25:44 pm »
In my video on the ohms range, it can be seen in the video, the insulation tester I used could no keep up with the low impedance of the target and the voltage dropped close to 0 so that test does not help at all. However it's worth noting that on AC/DC voltage the meters had no problem with 1KV applied. I wonder what did Dave use when he applied that AC voltage on the ohms range, was it AC from a wall socket (high energy)? or something generated by one of his power supplies?
« Reply #24 on: May 15, 2018, 09:19:02 pm »
Doesn't he have a piece of Keithley gear for that? a vintage unit, with big decade knobs etc..?
