Author Topic: EEVblog #1095 #1096 - ANENG Q1 Multimeter  (Read 4534 times)
Offline EEVblog
« on: June 14, 2018, 08:24:03 am »
A review and teardown of the new low cost $38 ANENG Q1 Multimeter
How dos it compare with the $25 AN8008?
Offline joeqsmith
Re: EEVblog #1095 #1096 - ANENG Q1 Multimeter
« Reply #1 on: June 14, 2018, 08:53:03 am »
I wonder if the relay behaves like the Gossen.  If it changes stated from an external source does the meter let you know?  The Gossen does not have feedback to detect it so in the voltage mode, if it changes you have no idea.  The meter could have several hundred volts across it and you would have no idea.   A really poor design IMO.   Maybe this cheap meter does something right.
How electrically robust is your meter?? http://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline joeqsmith
« Reply #2 on: June 14, 2018, 09:06:24 am »
Offline joeqsmith
« Reply #3 on: June 14, 2018, 09:09:57 am »
Of course that POS couldn't even hang with the cheap meters in the chamber.   Damn these marketing people.....
https://youtu.be/wYuzFtoHMqg?list=PLZSS2ajxhiQBTCU8Mq_i9jidT024A0dV6&t=837
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: June 14, 2018, 11:04:03 am »
The 4K teardown looks great. Definitely much better than upscaling 1080p. (To be fair, the upscaling shader code is tuned for upscaling images of models, not PCBs!)
As for the meter, I have had plenty of problems with the rotary switch on meters used in the field. A bit of dust gets inside and the switch becomes intermittent until the meter is disassembled and cleaned. A pushbutton control or even a slide/rocker switch can be more robust with less to go wrong. Or even a dedicated low voltage socket like what the Mooshimeter has.
The display is a nice idea with a big flaw. I have seen a LCD that was black on white with ambient light but white on black with backlight. Any reason they couldn't have used that?
Aside from the display, if they add power measurement and Bluetooth, it can very well become a contender for top pick of the budget meters.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #5 on: June 14, 2018, 01:16:34 pm »
That's why reviews like yours are important. I was about to get an Gossen Ultra, but then this potentially dangerous bug made me gave up this idea. I ended up keeping with traditional brands handheld DMMs plus a real 6.5-dgt bench DMM.
Offline EEVblog
« Reply #6 on: June 14, 2018, 01:50:02 pm »
No, the relay is not mu metal shielded.
Offline Muttley Snickers
« Reply #7 on: June 14, 2018, 02:10:42 pm »
I wonder if this meter will still work properly when powered at 3.6 volt to simulate using lithium batteries, I remember the Brymen BM235 didn't like the higher voltage lithium batteries and perhaps these are similar, certainly another thing to test.
One smart cookie, better make that two for good measure.
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #8 on: June 14, 2018, 05:11:40 pm »
Is this Meter the first legit use for Batteriser?   :-DD
Offline woox2k
  • Country: ee
« Reply #9 on: June 14, 2018, 07:06:26 pm »
Came here to say this too. Batteroo sponsored this meter perhaps? :D Like this is the perfect example where batterizer would be actually useful.
Offline McBryce
« Reply #10 on: June 14, 2018, 07:23:10 pm »
@Dave: You zoomed right in on the voltage reference and still didn't notice/comment on how ridiculously bad the soldering was on that part?
McBryce.
Online Fungus
« Reply #11 on: June 14, 2018, 07:34:39 pm »
Is it as dangerous as the Gossen?
a) The ANENG seems to reset the relay state more often, and
b) The ANENG relay doesn't have any effect on the main voltage ranges, ie. It's not going to read 23V instead of 230V (or whatever it was the Gossen read when the relay was out of sync).
« Last Edit: June 14, 2018, 07:43:53 pm by Fungus »
Online Fungus
« Reply #12 on: June 14, 2018, 07:35:47 pm »
For those who missed it, there's already been some discussion of these videos here:
http://www.eevblog.com/forum/testgear/new-aneng-q1-9999-counts/msg1605820/#msg1605820
« Last Edit: June 14, 2018, 07:42:10 pm by Fungus »
Online GeorgeOfTheJungle
« Reply #13 on: June 14, 2018, 08:33:20 pm »
Dave you can fix that thingy: flip the polarizer and disconnect the backlight led.
The following users thanked this post: sorin
Offline joeqsmith
« Reply #14 on: June 14, 2018, 08:34:46 pm »
I ended up using Netic on the Ultra.   Of course, the Gossen was certified to be safe.  In this case, I think the standards are lacking.
I don't think it's as dangerous as the Gossen. The ANENG seems to set the relay state more often and the ANENG relay doesn't have any effect on the main voltage ranges, ie. It's not going to read 23V instead of 230V (or whatever it was the Gossen read when the relay was out of sync).
There you are, reading your 600V 100Amp power supply... all is well.. The meter comes too close to the magnetic hanger.  What's this 600V CAT III marked meter do?  It's not like you rotated a switch.   This meter may give you some sort of visual that the relay changed state, making it safer.
The free Harbor Freight meters are now derated to 250V.   At least they were smart enough not to share the current input with the voltage input this time.  Still, it does need to handle 1000V plus margins across the open contacts.  Easy enough to try.
Offline EEVblog
« Reply #15 on: June 14, 2018, 09:09:03 pm »
Nope, it's all embedded.
Offline EEVblog
« Reply #16 on: June 14, 2018, 09:11:21 pm »
There is basically no effect on electrical safety of the meter itself under normal use.
The lack of correct display would be another issue.
Offline EEVblog
« Reply #17 on: June 14, 2018, 09:13:56 pm »
For probably the 10th time now I've had to comment on this:
This is common for hand soldered through hole parts, the solder didn't flow through from the bottom. It's not generally a problem, just inconsistency in the hand soldering. The bottom was soldered fine.
« Reply #18 on: June 14, 2018, 09:17:08 pm »
I can send you some good quality adhesive polarizing film if you have none. Can't you peel off the one on the display?
« Last Edit: June 15, 2018, 04:07:47 am by GeorgeOfTheJungle »
Offline LapTop006
« Reply #19 on: June 14, 2018, 09:21:23 pm »
Put a lipo pack in, and perhaps a Qi charge coil (likely easier than any other safe option) and you might actually have a really nice combo. Although that said, the only meter I've had with rechargeables was one of the Agilent ones where they tried to use a rechargeable 9v NIMH, it was always dead when I wanted it, even after only a week or two sitting unused after charging so I swapped in a primary cell.
Offline NiHaoMike
    • Facebook Page
« Reply #20 on: June 15, 2018, 03:20:41 am »
A one cell lithium is actually 4.2V at full charge, might be too much if it runs a 3.3V microcontroller directly from the batteries. LiFePO4 would be near perfect with a voltage range that pretty much exactly coincides with that of 3.3V logic.
I remember doing that to impress my friends in middle school...
The following users thanked this post: GeorgeOfTheJungle
Offline NANDBlog
« Reply #21 on: June 15, 2018, 03:39:49 am »
Seriously, if your meter uses 16mA, just place a boost converter on the input. I like using Eneloops, and hate 9V batteries. But this one is just stupid, it wouldn't even turn on with those.
The VA display could mean Vertical Aligment.
But I still think the UT210e is a better second meter.
Online Fungus
« Reply #22 on: June 15, 2018, 04:02:13 am »
Do you have any Batteroos with contacts still attached to them? How about a real-life test?
Maybe two wrongs can make a right?  :popcorn:
« Last Edit: June 15, 2018, 04:24:24 am by Fungus »
Offline Towger
  • Country: ie
« Reply #23 on: June 15, 2018, 05:05:07 am »
Sush...  He is still in denial that he needs glasses.
Offline bitwelder
« Reply #24 on: June 15, 2018, 05:17:41 am »
Mod the meter by adding a Joule thief?
