Author Topic: EEVblog #1114 - NEW TS80 USB Soldering Iron Review  (Read 38268 times)
Offline EEVblogTopic starter
« on: August 11, 2018, 04:21:44 am »
Review of the new 18W USB-C TS80 temperature controlled portable soldering iron.
http://s.click.aliexpress.com/e/bDjVklFw
TLDR; Highly recommended, money well spent if you need a portable iron solution, but you need a QC3 battery pack.
« Last Edit: October 03, 2018, 08:23:42 am by EEVblog »
Offline nugglix
Re: EEVblog #1114 - NEW TS80 USB Soldering Iron Review
« Reply #1 on: August 11, 2018, 09:53:37 am »
Video is not visible on the YT channel.
Desired?
The following users thanked this post: dirtcooker
Offline 5n44p
« Reply #2 on: August 11, 2018, 10:04:01 am »
Maybe a community firmware will make it work also with 5V regular power banks?
EDIT: the previous model was open source in firmware and hardware. http://www.minidso.com/forum.php?mod=viewthread&tid=868&extra=page%3D1
This is not, for now. At least i couldn't find any schematic or firmare. I guess that it is a bit more unlikely to get a community made firmare for this version
« Last Edit: August 11, 2018, 10:11:40 am by 5n44p »
Offline steve30
    • Stephen Coates' Homepage
« Reply #3 on: August 12, 2018, 12:43:21 am »
Looks good.
It would be interesting to see Dave's opinion on the included 'deathdaptor'.
Offline ChristopherN
    • app22 UG (haftungsbeschränkt)
« Reply #4 on: August 12, 2018, 07:05:34 am »
Has anyone tried to use it with Apple USB C power supplies for the current MacBook lineup? That would be a great combination.
Offline tsman
« Reply #5 on: August 12, 2018, 08:59:43 am »
That one has a genuine UL certificate. I didn't find the safety test report, but there's a QC3.0 compliance test certificate from UL Taiwan.
Nah. Not the USB PSU. He means the cheap plug converter with exposed contacts.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #6 on: August 12, 2018, 10:26:01 am »
Dave uploaded a short follow up video on the second channel about an hour ago, apparently some people were complaining that the unit lacked portability due to its power requirements.
« Last Edit: August 12, 2018, 12:38:33 pm by Muttley Snickers »
Offline oh2hyt
  • I lurk mainly
« Reply #7 on: August 12, 2018, 10:45:49 pm »
Interesting bits from TS80 manual with help of babelfishgoogle translate:
  • It won't work with USB PD. Only QC3.0 9V 2A. (my note: maybe QC2.0?)
  • "Power 18" setting (16-24W, default 18W) must not exceed used power supply output capability or supply AND TS80 may be damaged.
  • "OffVolt 10.0" setting sets maximum allowed input voltage. Above it heating is stopped.
  • "8.75V 26°C" setting: Calibrate the current used tip  :-+  :clap:
    • Press button A (closer to tip) to start process.
    • After calibration the displayed temperature (in settings menu?) should be close to room temperature.
    • Before calibrating a tip, please insert the tip into the TS80 and let it stand for 10 minutes to ensure that the temperature of the TS80 and the tip are same as room temperature.
    • “Completed” will be displayed after the calibration is completed, and “Retry later” will be displayed if the calibration conditions are not met.
  • Should warm in 22 seconds from 30°C to 300°C with 9V 18W input.
  • Not moved in set 180 seconds -> Idle at set (200°C) temperature. Another set 180 seconds not moved -> Stand by at room temperature.
  • Should work as usb disk when connected to computer. There is samekind config file, start up screen logo file and firmware update procedure as with TS100.
Someone could look pcb if usb-c input connector has CC1&2 pins connected to mcu? If those are, then hacks have posibility get USB PD to work. Maybe in future a laptop could then be used as power supply for soldering.
Dave, what are dimensions of the edge of the TS-D25 tip? Specs tell only length.
Manual is here http://www.minidso.com/forum.php?mod=viewthread&tid=3202&extra=page%3D1. I can't upload 1.09MB file.
Offline oh2hyt
  • I lurk mainly
« Reply #8 on: August 12, 2018, 10:53:17 pm »
I rechecked main channel video and settings showed "--°C". So the tip wasn't calibrated in the video. Seems user should do this at first use.
Edit 30.1.2019:
I guess that "--°C" was because the tip was hot in the video.
« Last Edit: January 30, 2019, 01:22:58 am by oh2hyt »
Offline 5n44p
« Reply #9 on: August 13, 2018, 12:22:38 am »
It only supports QC. QC can be emulated with MCU using DAC or resistors+GPIOs. QC is a "stupid" protocol without sophisticated timing and encoding mechanisms, not even CRC.
Is there an open specification for QC?
Offline DooMMasteR
« Reply #10 on: August 13, 2018, 06:33:22 am »
I hop they will release the schematics soon.
Would be nice to have USB-PD capabilities, but then again, it might be missing the USB-Vcc-PHY to communicate USB-PD-Request to the supply.
However USB-C to USB-C PD might stipp be possible via the CC1 and CC2 Pins on the connector.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #11 on: August 13, 2018, 09:12:22 am »
In the video Dave does not like the supplied free stand..
There is a dedicated (for TS-100) mini stand, available from Bangood (and others). Is is very nice and very small.
It could easily find a place int the supplied pouch.
See attached photo. It is not cheap (about 10 Euros).
Best regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline screwbreaker
Offline artag
« Reply #13 on: August 13, 2018, 01:08:18 pm »
There are tips on sale for the TS100 with that same conical heatshield. Are they shorter than the standard TS100 tips ?
« Reply #14 on: August 13, 2018, 01:10:22 pm »
I wonder how much it last with a power bank.
Some time ago I've got a battery powered soldering iron, the weller BP865CEU.
And I really hate it. The batteries don't last nothing, and they was always discharged when I need it. And I can't use rechargeable batteries, not only because it's not recommended, but because they don't fit inside the battery holder.
This is the main problem with battery powered devices, you have to rely in batteries, which are not so good to store energy for long time.
In my opinion for who need to use a portable soldering iron form time to time, the best option are the butane one.
Butane never discharge, once you have the tank filled, you can keep it on the shelf for months, even years, and it still ready to use.
Even the refill tank don't loose his "charge" over time.
Fuels still the best option for store energy for long time.
Offline Bud
« Reply #15 on: August 13, 2018, 01:19:50 pm »
This iron could make a great promotional item. It is technological,  cute and has a real use , unlike most of promotional gadgets. I'd seriously considered it were i running a big company. in mass quantities it should be not that expensive to make.
Offline nixfu
« Reply #16 on: August 13, 2018, 05:52:58 pm »
So what is the difference between the TS80 and the TS100 I have seen so many other people like Louis Rossmann recommend?
Offline MacMeter
« Reply #17 on: August 13, 2018, 06:29:19 pm »
If you carry any cordless tools, you may already have a 18-20 volt DC power supply for your TS100!
Offline thm_w
  • Non-expert
« Reply #18 on: August 13, 2018, 07:27:52 pm »
TS100 is 65W vs 24W on TS80
Barrel jack vs USB C with burnproof cable
Longer grip to tip on TS100
Most of the differences are covered in the video.
Offline Bud
« Reply #19 on: August 13, 2018, 09:57:09 pm »
I do not think you need a soldering tool at a construction site unless you are a plumber, but then this puppy is not for the job  >:D
Offline MacMeter
« Reply #20 on: August 13, 2018, 11:35:55 pm »
Plumbers are not the only ones that carry and use cordless tools, and obviously this is not the tool they would be using so I’m missing your point.  :-//
Offline chickenHeadKnob
« Reply #21 on: August 13, 2018, 11:53:27 pm »
An issue that is under-emphasized in Dave's video(s) is that the tips are not compatible and the selection of tips for the ts-100 are far greater. Over time expect to spend more on tips than the iron. The Haako clone tips and units win here. You can turn a  T-12 clone into a portable. Of course it  has more weight and bulk than the TS80 but that is the direction I am going. I have  a TS100 and a homebuilt T-12 clone.
Offline SparkyFX
« Reply #22 on: August 14, 2018, 09:25:03 am »
Cool little thing  :-+ and i was completely uninformed of quick charge specs for USB as well, so thanks for showing.
It´s probably quite versatile for use in vehicles or outdoor in general. In cars most cable connections should be crimped instead of soldered, but anyway... if you need to fix something and know what you are doing this thing might perform quite well.
I do have a propane/butane heated soldering iron, where temperature can only be guessed and it does blow out the hot gas next to the tip, therefore can not be used in tight spaces. So I guess a good temperature control might be important not to get over the melting point of several plastics or parts.
So i am one cigarette lighter adapter away from getting one.
Support your local planet.
Offline TheAmmoniacal
  • Country: no
« Reply #23 on: August 16, 2018, 07:08:46 am »
Can you test if the TS80 is ESD "safe" without the strap? Any mains leakage to earth through the tip?
Pretty sure I've killed some components with the TS100 because of it.
Offline newbadboy
« Reply #24 on: August 16, 2018, 01:07:51 pm »
U guys mention the QC protocoll. Is it really needed with communication for this iron? What i can see in the video Dave only connects it to a bench power supply and it powers up without any communication?
Have i missed something.
Any way I have ordered one without power supply. Thinking of connecting it to a smaller LIPO pack with apropriate boost controller.
I know there are ones to buy but i already have some LIPO packs laying around.
