Author Topic: EEVBlog #1116 - The Capacitance Multiplier  (Read 9491 times)
Offline floobydust
Re: EEVBlog #1116 - The Capacitance Multiplier
« Reply #25 on: August 30, 2018, 02:16:13 am »
A Sziklai pair doesn't work here at all :rant:
You don't want ripple at the emitter- that's the opposite of how a capacitance multiplier works.
edit: added url
« Last Edit: August 30, 2018, 04:03:30 am by floobydust »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #26 on: August 30, 2018, 02:52:03 am »
If you are asking why does C422 not go to ground, but rather to the output of the transistor, my own little research suggests that this is a bit more than a simple RC filter. It looks to me like the topology of a Sellen-Key filter like this: https://en.wikipedia.org/wiki/Sallen–Key_topology
Do I have it right? I can't explain exactly how it works though. Need to study this.
Quite right, it doesn't have the unity gain of an op-amp so the stop-band attenuation won't be perfect, but the transition band can be peaked for whatever filter characteristic you need, and the asymptotic slope can be -40dB/dec (until leakage takes over).
Note the feed-forward path through the first resistor and capacitor, so that at frequencies where the transistor gain is dropping off, this path dominates, limiting stop-band attenuation.  Admittedly, this is still a higher roll-off than for a typical op-amp, so it might not be too bad.
Here's an example I made, with vacuum tubes for audio cred:
The 6V6 model is actually pretty close (when the model's bugs have been avoided..) to what was actually used, a 5702 submini pentode.  The simulated response:
You can see it's much sharper and tighter than anything you can do with resistors and capacitors alone, and smaller than most things you'd do with inductors (I know, you can get pretty small ~1H chokes, though the Q is pretty bad).  Plus you'd still need the buffer to drive an LC filter, so might as well do it in one. :)
I don't have a picture of the actual filter, but it went on this radio, just after the detector.  The construction is similar, just imagine it with another submini and more capacitors and resistors around. :P
Also, incidentally, I finished up that radio by powering it with two SMPSs, in a hybrid configuration.  One AC to 12V 2A supply (Meanwell) just to get things going, then a discrete 12 to 6.3 and 100V supply (a slight variant of this) for the tubes.  I added shielding around, and an extra stage of LC filtering outside the discrete module, and that was all that was needed to keep the thing dead quiet on the 20m (~14MHz) band.
« Last Edit: August 30, 2018, 02:59:09 am by T3sl4co1l »
Seven Transistor Labs, LLC
The following users thanked this post: AviZiv
« Reply #27 on: August 30, 2018, 03:18:05 am »
Not being a native speaker of English, one thing I would appreciate very much is if you would wrote down some of the more unusual or not as easy to understand terminology. For instance, it took me a bit of googling until I found out that the one configuration you mentioned was spelled "Sziklai pair".
Yep, noted, I'll write down such thing in the future.
Having watched, with occasional amusement, your regular mailbag frustrations and wrestling with mittel-europa place names may I offer a little pronunciation help here. Sziklai is a Hungarian name and like all Hungarian words with 'sz' or 'cz' phonemes is unpronounceable by anybody who isn't a native Hungarian. The nearest I've managed to get transliterates as 'shik-laii' with the 'sh' sound being something between the English 'sh' and 'z' sounds - shape your mouth to say 'z' but instead say 'sh'. I got this pronunciation years ago from a Hungarian descended German colleague.
Offline floobydust
« Reply #28 on: August 30, 2018, 04:08:53 am »
Thanks, here I thought it was a Japanese name  :-[  Let's get our Sidney Darlington and George Clifford Sziklai right.
But Sziklai pair still won't work in a capacitance multiplier.
Offline ggchab
« Reply #29 on: August 30, 2018, 09:03:45 pm »
Thank you for this very interesting video  :-+
Offline IanMacdonald
    • IWR Consultancy
« Reply #30 on: August 30, 2018, 09:10:14 pm »
BS. PNP series pass, NPN driver.
Though, I wonder if we could achieve time travel this way with less flux.
Incidentally, the way this circuit works is that the cap will try to charge to Vin, and thanks to the light loading of the emitter follower it will mostly succeed. However, when Vout gets too close to Vin the transistor becomes unable to draw collector current because the difference is too small, and the transistor then effectively becomes a diode between the cap and Vout. In which case the cap voltage is rapidly dragged down until the collector can draw current again. Hence Vout tends to stabilise at the lowest instantaneous ripple voltage.
« Last Edit: August 30, 2018, 09:29:06 pm by IanMacdonald »
Offline floobydust
« Reply #31 on: August 31, 2018, 04:13:06 am »
With all due respect, you are mistaken. Unless you have a sketch to clear up misunderstanding on how the NPN driver works at multiplying capacitance.
Once you have high ripple on either transistor's emitter, you are modulating conduction at the E-B junction.
This breaks the basic principle of the an emitter follower here in the capacitance multiplier that relies on pure DC at the base and the resulting near constant collector current (in both transistors) to filter ripple.
People arbitrarily change from Darlington to Sziklai, NPN/PNP etc. and let's not be sloppy.
Offline T3sl4co1l
« Reply #32 on: August 31, 2018, 04:27:24 am »
I'd be interested to see a simulation illustrating this.
Offline floobydust
« Reply #33 on: August 31, 2018, 06:21:35 am »
With Szikilai the pass transistor appears to not be contributing, its (emitter) in-phase with the ripple so the result is slightly worse? Only the driver is doing the work.
For discussion I did a basic run in LtSpice and also in Paul Falstad's Circuit Simulator of the capacitance multiplier using a Darlington and Szikilai.
It's kind of a nothing burger circuit because it wastes a fair bit of voltage as heat, and adding a zener turns it into a voltage regulator anyhow.
I've rarely encountered capacitance multipliers. Only seen in esoteric audio gear.
Offline JS
  • Country: ar
« Reply #34 on: August 31, 2018, 04:43:03 pm »
Thanx for coming back to fundamental, bummer it wasn't a friday :D
Someone please run a SIM on the shizaki pair and end our missery, that and a darlington to compare. My money is lower ripple for the darlington, lower drop out for the other.
JS
If I don't know how it works, I prefer not to turn it on.
Offline JPortici
« Reply #35 on: August 31, 2018, 06:19:50 pm »
I just saw this that seems kinda related :)
MIC94305
500mA Switch with Ripple Blocker Technology
http://ww1.microchip.com/downloads/en/DeviceDoc/MIC94305-500mA-Switch-with-Ripple-Blocker-Technology-DS20006029A.pdf
Offline EEVblog
« Reply #36 on: August 31, 2018, 06:43:30 pm »
I think a better name for this circuit topology would be resistance multiplier instead of capacitance multiplier.
I tend to agree, but capacitance multiplier is the industry term like it or not.
Offline radioactive
« Reply #37 on: August 31, 2018, 10:43:09 pm »
I ran a couple more Qucs simulations comparing Darlington vs. Sziklai.  Sziklai ended up being lower voltage drop as well as slightly better ripple rejection.
The following users thanked this post: thm_w, T3sl4co1l
Offline Fungus
« Reply #38 on: August 31, 2018, 11:50:50 pm »
I just noticed that "InfiniVision" is spelled InfiniiVision.  :popcorn:
Offline JS
  • Country: ar
« Reply #39 on: September 01, 2018, 02:32:59 am »
@radioactive: thanks, I guessed one and missed the other...
JS
Offline radioactive
« Reply #40 on: September 01, 2018, 02:48:17 am »
I ran it again with just a single frequency (vs swept frequencies) and just a pure sine wave of 1KHz for ripple noise.  The output for both look nearly identical except for the difference in voltage drop.  These plots might be easier to look at.  Let me know if you want me to run with a different configuration.
The following users thanked this post: T3sl4co1l
Offline JS
  • Country: ar
« Reply #41 on: September 01, 2018, 03:21:57 am »
Looks like Sziklai wins this time. Same rejection but with lower dropout. One thing that might worth checking is high freq to see how it will work in a SMPS.
Excelent you are running this! Thanks so much, shacky days here or I would running them myself...
JS
Offline radioactive
« Reply #42 on: September 01, 2018, 03:54:52 am »
Good suggestion.  I changed to 10khz sine and got some interesting results.  I was going to try 280khz, but the transient sim was going to take forever.  Looks like sziklai is the clear winner here ( at least in a simulation with these component models ).
Offline radioactive
« Reply #43 on: September 02, 2018, 01:17:41 am »
I forgot to post a reference to the data sheet for the transistors used in the simulation for comparing Darlington to Sziklai configurations.
2N3055 /2955 complementary power transistors:   https://www.mouser.com/ds/2/68/2n3055-1108522.pdf
Offline T3sl4co1l
« Reply #44 on: September 02, 2018, 04:33:58 am »
Datasheet not very useful -- you're assuming the datasheet is even descriptive enough (it's not), or that the models are anything like an average part (who knows). :-//
What's the library entry look like for those parts, anyway?
Offline radioactive
« Reply #45 on: September 02, 2018, 05:50:47 am »
I'm not assuming anything.  I was just providing more info about the simulation and the fact that they are supposed to be complementary.   I'll attach the parameters from the Qucs models that were used for reference as well.  I agree that it is just a simulation.  Let me know if anyone is interested in trying a different configuration.
Offline floobydust
« Reply #46 on: September 02, 2018, 06:14:21 am »
I tried your simulation in LTSpice, much different than what I'd drummed up.
2N3055 Bf=73 with 1.5A load and 10kHz input ripple compared to my 2N3904 Bf=300 with 42mA load and 120Hz input ripple.
I could not get the same results in favour of the Sziklai for ripple reduction.
In LTSpice, I noticed the 2N3055 Darlington has a higher voltage drop, I'm getting 8.5V out, compared to your 10.4955V so the base current is way different. 0.85mA across the 5.4k
Offline radioactive
« Reply #47 on: September 02, 2018, 07:16:16 am »
I downloaded your LTSpice simulation and noticed a few differences from the Qucs simulation
1khz vs 10khz
1uF cap vs 4.7uF cap
The PNP model in LTSpice is not 2N2955, but D45H11
Bf was significantly different.  70 vs 360.
I adjusted the Bf/Rf in Qucs transistor models to match the LTSpice as well as the Cap value and input sine frequency.  I still get same results in Qucs (same difference in output ripple) , but with an expected higher voltage drop.  The voltage drops are still significantly different between LTSpice and Qucs.   I may dig into it some more later, but the models definitely don't agree even on the Darlington where they are both supposedly 2N3055 models.  After looking at some other datasheets for these transistors, I suspect that the Qucs models are incorrect (at least the forward beta parameter).  I apologize for not doing more to verify the models before posting on here.
Offline David Hess
  • DavidH
« Reply #48 on: September 02, 2018, 09:24:34 am »
The difference in performance between the Darlington and Sziklai pair comes up in audio power amplifier design so there might be something to learn there.  Local feedback designs with a third transistor are much better than either.
Another thing to learn from audio power amplifier design is Ft and hfe droop at high currents which are going to be present in a high current capacitance multiplier.  There will be considerable advantage to using RETs (ring emitter transistors) or equivalent like the D44/D45 series instead of common power transistors.
I myself have only used capacitance multipliers like this at 10s to 100s of milliamps for sort of super power supply decoupling and surge protection.
Offline T3sl4co1l
« Reply #49 on: September 02, 2018, 10:17:29 am »
Wow, are all the parameters identical for those models, except for type (NPN/PNP)? Whose idea was that? :-DD
