Author Topic: EEVBlog #1116 - The Capacitance Multiplier  (Read 9566 times)
Offline VanitarNordic
Re: EEVBlog #1116 - The Capacitance Multiplier
« Reply #75 on: January 25, 2019, 05:36:24 am »
Just turn the Zener around and use a PNP transistor.
Actually, I used NPN and the results were identical with when I used an PNP in this circuit!
Besides, if I just connect something at the output (output of the multiplier), a resistor (as a load) or even a 100nF capacitor or similar, then the noise appears again!
« Last Edit: January 25, 2019, 06:31:13 am by VanitarNordic »
