EEVblog => EEVblog Specific => Topic started by: EEVblog on October 14, 2018, 09:23:30 pm
Mailbag Monday, teardown bonanza!
https://www.youtube.com/watch?v=udvPyB7XcQ8 (https://www.youtube.com/watch?v=udvPyB7XcQ8)
SPOILERS:
- West German Geiger Counter Teardown
- 6:35 Leo Bodnar Oscilloscope 40ps Pulse Generator for oscilloscope bandwidth measurement.
https://www.leobodnar.com (https://www.leobodnar.com)
- 11:32 Pocket Sprite Keyring Gameboy Teardown
https://pocketsprite.com/ (https://pocketsprite.com/)
- 14:31 Defibrillator Simulator Teardown
- 21:23 - Philips CD Discman Teardown
Hello McFly it's still Sunday in the United States ! 8) 8) 8)
NOTHINGTOSEEHERE...
13:54 - Priceless... :-DD
More Mailbags than I can poke a probe at. I think I like the new format!
For those interested here is the ESP32 based gameboy emu:
https://www.espressif.com/en/media_overview/news/pocketsprite-esp32-based-gaming-device (https://www.espressif.com/en/media_overview/news/pocketsprite-esp32-based-gaming-device)
seems very simmilar to this pre existing one.
https://www.hardkernel.com/main/products/prdt_info.php?g_code=G152875062626 (https://www.hardkernel.com/main/products/prdt_info.php?g_code=G152875062626)
all of which pale in comparison to https://github.com/jkirsons/doom-espidf (https://github.com/jkirsons/doom-espidf)
Great to see that you put the coin into circulation ;D
-Proper knife? That's a toothpick, Dave. :-DD
Here's a proper knife...
https://www.youtube.com/watch?v=UbSrnjNGBdA (https://www.youtube.com/watch?v=UbSrnjNGBdA)
To disassemble the Geiger counter, you first have to remove the knob and axle of the rotating drum, then the drum itself, and then tilt the double PCB up from the rotary contacts side. (I already desoldered lots of thin wires from the analog meter movement)
The aperture is supposed to open all the way but the clutch that engages the knob (yes the knob, not the axle) got bent because it's not visible from the outside that it's even there.
NOTHING TO SEE HERE.
I CAN TELL YOU THIS THING IS WAY MORE INTERESTING WITH THE DISPLAY THAN WITHOUT.
Heh, good one
Someone should make some DAC ICs called the DACedydoodah.
