Author Topic: EEVblog #1160 - Weller Responds  (Read 188009 times)
Offline Wolfgang
    • Electronic Projects for Fun
Re: EEVblog #1160 - Weller Responds
« Reply #700 on: January 04, 2019, 09:33:53 pm »
Dave, dont worry. Darwinism will take good care of these people.  >:D
Don't hold your breath.  ;)
Dont worry. Darwinism has worked well over at least a few 100 million years ...  >:D. It wont fail just here, I am sure.
I am asking myself if all the ardent Weller defenders here are either dealers, stockholders or otherwise affiliated with Weller -
then they did a terrible job on regaining customer confidence in Wellers products and company image - OR -
they are associated with some of Wellers fiercest competitors trying to discredit the company - then they were really brilliant.  :) :) :-DD
The following users thanked this post: Electro Detective
Offline fsr
  • Country: ar
« Reply #701 on: January 04, 2019, 09:36:35 pm »
expensive models include a well-known safety device: a fuse.
Once again, safety of the iron. Short memory?
What do you mean?
The fuse is protecting the soldering station. We've been over this.
But it doesn't have a mains fuse. That's what this is all about.
Offline Mr. Scram
  • Display aficionado
« Reply #702 on: January 04, 2019, 09:45:49 pm »
"These people don't agree with me. They must have financial motives!"
What a shameful suggestion. Maybe it's the lack of relevant evidence?
The following users thanked this post: timelessbeing, jancumps, drussell
Offline Mr. Scram
« Reply #703 on: January 04, 2019, 09:49:46 pm »
Please refer to the last time you brought this up. It appears you're being wilfully obtuse for the sake of arguing.
https://www.eevblog.com/forum/blog/eevblog-1160-weller-responds/msg2068060/#msg2068060
Offline Wolfgang
« Reply #704 on: January 04, 2019, 09:55:15 pm »
Fully agree. It *is* shameful to cut corners at a penny safety device that would have prevented what happened to Dave. And this for a self-proclaimed premium brand with all the Chinese doing better.
Offline Mr. Scram
« Reply #705 on: January 04, 2019, 09:58:31 pm »
There's a good way of finding out whether that actually would have prevented what happened to Dave. How much are you donating to the testing funds? $50?
Offline Wolfgang
« Reply #706 on: January 04, 2019, 10:03:02 pm »
Why not ? The only thing I dont like about it that we are collecting money to *buy* stuff from Weller. If they supply the soldering stations for free, I would donate to the other costs of the test.
Offline coppercone2
« Reply #707 on: January 04, 2019, 10:03:50 pm »
i wanna know how many people defending this shit burn tires in their living room fireplace
also don't buy shit they sell. just seriously bad engineering practice. if you support that then there is probably a laundry list of stuff behind the crap you produce. you can build a good product or you can run a company like a auto balancing bridge that is on the precipice of being legal to sell. if it was something extraordinary close to engineering limits then i can see that regulation is difficult to meet. but this is not. its a little rod that gets hot, its not a fucking cold fusion reactor trying to meet emi compliance and safety regulations. there should be common sense offset.
« Last Edit: January 04, 2019, 10:11:20 pm by coppercone2 »
Offline Mr. Scram
« Reply #708 on: January 04, 2019, 10:15:36 pm »
Consider that a well set up and documented test which turns out to be unfavourable for Weller is likely to cost them significantly more than that. If there really are problems, Weller won't profit. If it doesn't turn out to be an issue, it's not really an issue the units are bought. Are you in?
We're still looking for tests which test the necessity of a primary fuse when normal voltages are applied. Right now we only have two gross overloading tests. Suggestions are welcome.
Offline drussell
  • Hardcore Geek
« Reply #709 on: January 04, 2019, 10:23:07 pm »
I can't even imagine how much fun some of you guys were having trying to impugn all the old-school manufacturers back-in-the-day when we had current-production things like live chassis TVs and radios that were perfectly cromulent design choices at the time....   :)
I suppose, in here, there will probably now be a lobby for imbedded smoke-detectors on all new transformer-operated devices to cut the current to the supply in the case of a failure, unlike those old-fangled, transformer-based, death-trap wall-warts...  You know, instead we must all now use those ultra-safe, super-reliable chinese SMPS thingies that everything seems to come with.    :palm:
"But they have a fusible resistor in them!"
Fusible resistor, indeed....   :palm:
Offline floobydust
« Reply #710 on: January 04, 2019, 10:23:49 pm »
Do you have any evidence that there have been any failures that resulted in any property damage due to, for example, one of these units bursting into flames and burning down someone's house, lab, place of business, etc?  Has anyone been zapped into a permanent coma by such device?  These are the things that the standards, regulations, etc. are meant to influence...
It all relies on people reporting incidents to the manufacturer and consumer product safety authorities. How many of us check our gear for safety advisories or recalls?
https://www.cpsc.gov/Recalls/2011/Stained-Glass-Soldering-Irons-Recalled-By-Cooper-Tools-Due-to-Burn-Hazard/
"The electrical cord attached to the iron can detach from the flex point at the base of the handle. If the electrical cord fails while the product is in use and the cord is touching the user's skin, it could produce an electrical arc that could cause a burn.
There have been three reported injuries, all of which were superficial burns to the hand, none requiring medical attention. Two of the reported injuries occurred in the United States of America and one in Canada."
https://www.cpsc.gov/Recalls/2005/cpsc-cooper-hand-tools-announce-recall-of-weller-heating-element-used-in-soldering
"Hazard: The housing of the heating element can unexpectedly leak hot metal, posing a serious risk of a burn injury to the user.
Incidents/Injuries: Cooper has received four reports of the housing of the heating element leaking hot metal. No injuries have been reported."
If nothing is reported, then the stations must be fine. Right?
The following users thanked this post: TheDane
Offline Wolfgang
« Reply #711 on: January 04, 2019, 10:32:58 pm »
IMHO, The tests should comprise the following:
- Line voltage transients (some standardized procedure. I dont know what the US rules ask for)
- permanent overvoltage (as happened to Dave)
then, it should be decided what a pass and a fail is and after what time this needs to be determined. Candidates:
- An open fire is a fail (I think that is clear)
- Too much smoke so that smoke detectors go off is a fail too.
The tests should be done in a certified (fireproof) lab.
I think the communication policy of Weller is a desaster anyway, but they dont care so much. They could repair their image by supplying the units.
Daves video has been seen by a few thousand people by now, and it is plausible that not all of them will buy a Weller next time  :)
Offline Mr. Scram
« Reply #712 on: January 04, 2019, 10:47:28 pm »
Your pass or fail requirements seem reasonable enough. You could argue that a smoke detector going off isn't an actual danger, but it would represent an inconvenience. I'm afraid that requiring certified labs and such will put it beyond the attainable. It should be very doable to come up with a few representative tests which can be set up without too much hassle. It seems most important to properly monitor what's going on. Obviously a regular camera, voltage and current going in would be good to monitor and maybe a thermal camera. I'm not sure how to quantify the smoke production. Maybe build a box with some kind of smoke detector in it? Can those do quantitative measurements or would that call for more specialised kit?
Offline fsr
  • Country: ar
« Reply #713 on: January 04, 2019, 11:00:11 pm »
That didn't proved anything to me.
If the smoking, fuseless transformer looks like it's safe to you, well, you're free to think whatever you like. But don't expect that most people will think the same.
And as i said, you cannot guarantee the safety of a transformer that was smoking it's enamel. A fuse would have blown before that happens.
So, why not to include a fuse, when it's very cheap, everyone else uses it, and would improve the safety of the device? Nobody designs mains connected equipment without a mains fuse, because when shit goes wrong with mains, it goes really wrong. Too much power there. Would you remove the fuse just because your found some certification that won't require one? I wouldn't expect a simple 40 watts soldering iron to be fused, because, well, there's no much space to even put a fuse in there, and it has just a heating element inside, and that's it. Neither would i leave it connected and go away for any significant amount of time. But a soldering station? Is there even another fuseless soldering station out there?
Maybe to weller this falls under the ridiculous reasoning of "this may cost $1 per unit, but in 1,000,000 units, that's $1,000,000 we could save". But then, why not just charge $1 more, and be done with it?
Maybe it's a design issue or manufacturing error? But then, it's crazy if they don't fix it, as they could get sued. At least go the "xbox way", and provide an external safety.
And even more important: if they have a good reason for the fuse to not be there, just share that information with the electronics community!!
« Last Edit: January 04, 2019, 11:03:08 pm by fsr »
Offline Mr. Scram
« Reply #714 on: January 04, 2019, 11:09:11 pm »
Luckily we can test whether a fuse would have blown before that happens. We just need some funds to do so. What are you willing to contribute to the testing funds? Maybe $50?
Offline drussell
  • Hardcore Geek
« Reply #715 on: January 04, 2019, 11:10:06 pm »
I'm curious as to whether people here would be as outraged if it were a standard $6 120-volt wall-wart that was connected to 240 volts instead of a soldering station?
If I stick 240 volts at 50 Hz across pretty much any device intended for 120 volts 60 Hz, I would expect fireworks unless something is specifically designed for a wider voltage range.  :)
Offline drussell
  • Hardcore Geek
« Reply #716 on: January 04, 2019, 11:15:38 pm »
The ultimate combination of severe user error, electrical naivety and distressingly cheap design:
 :palm:
The following users thanked this post: Andrew McNamara
Offline Electro Detective
« Reply #717 on: January 04, 2019, 11:19:03 pm »
With regard to the car analogy ... drivers and passengers walk away generally alive
Quote from timelessbeing:
analogy fail
A) There are probably hundreds of thousands of accidents per day
REPLY: There are 'probably' many accidents related to car design issues, either not addressed ($ $ $-RECALL-$ $ $) or swept under the doormat
and or just payed out when necessary, to nagging victims via 'no win-no fee' attorneys
B) You can't control other bad drivers. You CAN control what you plug your iron into.
REPLY: You can't control what others plug their iron or your borrowed iron into,
best to have a properly rated fuse in the sucker = less thinking about who's plugging what into where,
and just get on with the soldering thing..
C) From what I can tell, Dave walked away alive. In fact his life wasn't in danger.
REPLY: His lab was in danger of going up in smoke (and not in an Option B: Cheech and Chong fashion) if he left it unattended, as he's not imprisoned there afaik.
and his wallet was in danger too, on a Fire Brigade call out fee, lab mop up, gear replacement, paint job, a carton of Glen 20,
and slab of beer and pizzas for mates rocking up to assist...
Offline thm_w
  • Non-expert
« Reply #718 on: January 04, 2019, 11:21:56 pm »
No one is talking about an old-school manufacture or design, we are talking about a modern product which was recently designed.
We've established that proper transformer based wall-warts have an embedded thermal fuse. Maybe not all.
Most of the smoke detectors that show up on google have a fuse or similar. I did see one CO detector below that appears to have no input fuse, date is 2003.
https://www.allaboutcircuits.com/news/teardown-tuesday-leeo-wifi-smart-alert-carbon-monoxide-smoke-alarm/
https://fccid.io/SAK9000165/Internal-Photos/Internal-Photos-509186
https://photos.vec.com/Blog/2011-10/Carbon-Monoxide-Detector/ (no fuse)
Yes cheap crap SMPSs are also a hazard and are dangerous, if they are not certified. No one is arguing this.
A fusible resistor may be enough to pass certifications if they are using a proper part: https://www.powerelectronics.com/passive-components/fail-safe-wirewound-resistors-robust-applications
But to me it doesn't seem as good as a fuse, when they just quote "Fusing time within 60 seconds at 25 times of rated power" without much more info. http://www.yageo.com/NewPortal/yageodocoutput?fileName=/pdf/throughhole/Yageo_LR_FKN_2013.pdf
And yet, a fusible resistor is still better than nothing, Weller is using nothing.
Offline Mr. Scram
« Reply #719 on: January 04, 2019, 11:34:20 pm »
analogy fail
We'll test whether the lab was in danger and try to assess the amount of smoke produced. We just need some funds for buying a few stations to test. $50?
Offline drussell
  • Hardcore Geek
« Reply #720 on: January 04, 2019, 11:39:53 pm »
Oops...  I forgot to include bigclive's appropriate response to the 120->240V mishap video above:
Classic Clive...  :)
Offline timelessbeing
« Reply #721 on: January 04, 2019, 11:40:13 pm »
Is there a point here?
best to have a properly rated fuse in the sucker = less thinking about who's plugging what into where ...
 His lab was in danger of going up in smoke ...and his wallet was in danger too
I see. Well If you are person with a habbit of plugging things into random places, then YOU better buy devices with fuses.
« Reply #722 on: January 04, 2019, 11:43:20 pm »
If it's UL listed, hasn't it already been tested for this?
Why do we have to do this again? Dave conducted this test. And it failed, exactly as it should have.
« Reply #723 on: January 04, 2019, 11:45:51 pm »
Why not?
Offline Mr. Scram
« Reply #724 on: January 04, 2019, 11:53:25 pm »
I'd like to test gross overvoltage to see how the unit fails when not unplugged. A second test can show whether a fuse would actually save it without harm. Either case would be user error, but it'd put an end to that part of the discussion.
Whether the unit is safe without fuse under normal conditions is a bit harder to assess.
« Last Edit: January 04, 2019, 11:55:25 pm by Mr. Scram »
