Author Topic: EEVblog #168 - How To Set Up An Electronics Lab  (Read 60426 times)
Offline tecman
Re: EEVblog #168 - How To Set Up An Electronics Lab
« Reply #25 on: April 30, 2011, 06:07:06 pm »
One more observation.  If you are planning to do critical audio work, the function generator may not be the first choice.  You would want a generator with very low distortion.  Usually what is typically called an audio generator is desired.  Sine only, sometimes with square as well, but you can get them with 0.001% harmonic distortion.  Older HPs and some Tek TM500's are available on eBay for a reasonable price.
paul
Offline Ernie Milko
« Reply #26 on: April 30, 2011, 06:23:06 pm »
A very good video, I thought.
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #27 on: April 30, 2011, 06:26:39 pm »
"Is it worth a buy?" skimmed through again, and this time with details and deep thought, put your illusion aside. you've been foolish to read what you dont want to read. btw, who's been off topic?
You seem set on taking my lighthearted comments the wrong way!
Chet
Paid Electron Wrestler
Offline squeezee
« Reply #28 on: April 30, 2011, 08:11:15 pm »
What type of tweezers do people recommend for handling/positioning surface mount components. Just had a look on Farnells site and there are a confusing selection. I need a basic set that can handle 1206 chip caps/resistors and small SOIC IC's. Also does anyone sell stainless toothpicks for positioning parts under a microscope?
Thanks.
David.
You can use a cheap set of dental picks. Distributors sell them as well (eg. digikey), check in the "Scribers & Probes" category on farnell.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #29 on: April 30, 2011, 11:33:15 pm »
paul
A PC soundcard or external USB audio interface may well  give you better quality audio-band waveforms than a function generator.
Day Job: Mostly LEDs
Offline johnmx
  • Country: pt
« Reply #30 on: April 30, 2011, 11:57:23 pm »
I would like to show you how I organize the spare parts. I have an updated list of all components (IC’s, diodes and transistors) and keep them in small boxes which are labeled (see attached image).
This list (excel file) has several pages, one for each part type: uC, opamp, regulators, etc.
Each line corresponds to a single part and has all the information needed: exact model number, quantity, SMD or through-hole indication, small description with the most important features, link to data sheet and finally the box number where it is stored.
This list is very useful when developing a new project. In this way I always know what components I have or not and the respective packages in case I’m designing the PCB.
Best regards,
johnmx
Offline AdShea
« Reply #31 on: May 01, 2011, 12:01:12 am »
I'd suggest putting a bit more into tweezers (only 12USD) and get a really nice pair.  I've got some of these http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=243-1096-ND&x=0&y=0 and the big blue grip is totally worth it.  By not making me grip so close I've found I can even do 0603 without magnification now.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #32 on: May 01, 2011, 07:08:13 am »
i'm sorry if its misinterpreted (maybe just my illusion). but be carefull with your statement, there's people with not so lighthearted here. and you simple joke of "mech is a god->off topic" might not work with others, esp me.
anyway just want to add to the collection... i have this in my lab (workroom)...
« Last Edit: May 01, 2011, 07:16:26 am by Mechatrommer »
Offline FreeThinker
  • Truth through Thought
« Reply #33 on: May 01, 2011, 10:32:46 am »
Can't believe anyone has not mentioned one of these before... absolutely essential http://www.joke-archives.com/oddsends/achtung.html
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Offline Cj1corbystarlet
« Reply #34 on: May 01, 2011, 10:51:08 am »
A good nudie calender on the wall never goes astray.   :P
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #35 on: May 01, 2011, 12:00:07 pm »
Do not mix the standard tools of Electricians,
with the those for Electronics Lab  ;D
They have an nudie calender with the Arduino on it.
« Last Edit: May 01, 2011, 12:04:16 pm by Kiriakos-GR »
Offline tecman
« Reply #36 on: May 01, 2011, 04:47:06 pm »
I hate to disagree with a fellow countryman (sort of, I am second generation greek-american), but many projects eventually require electricians tools for striping, crimping, cutting and wiring things.  Although most electrician's tools do not sit on my bench, they are in the toolbox 6 feet away.
paul
Offline dengorius
« Reply #37 on: May 01, 2011, 05:43:13 pm »
In case anybody is interested, this is the power supply kit from Silicon Chip that Dave mentions in the video
Article: http://www.siliconchip.com.au/cms/A_30603/article.html
Front/Rear panel: http://us1.webpublications.com.au/static/downloads/articles/30603_quad_power_supply_panels_fr.pdf
Front PCB: http://us1.webpublications.com.au/static/downloads/articles/30603_quadpowersupply_front_pcb.pdf
Main PCB: http://us1.webpublications.com.au/static/downloads/articles/30603_quad_power_supply_main_pcb.pdf
Unfortunately if you want all the details you have to purchase the article from the first link
Cya :)
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #38 on: May 01, 2011, 06:05:50 pm »
Hello Paul , I was exclusively refer to the wall calendar post .  ( that was an smart made joke )  :)
Regards
Kiriakos
Offline kcs
« Reply #39 on: May 01, 2011, 08:20:31 pm »
Which soldering wire out of these three should I pick? In the video Dave told to choose 60/40 one but then he agreed with someone on youteube, that 63/37 is better choice, but I cannot find such one.
One more question - why is the last one in the list so expensive?
Offline SnakeBiteTopic starter
  • Country: il
  • OBSESSED MODDER
« Reply #40 on: May 01, 2011, 08:33:16 pm »
60/40 was a standart solder for many years it included tin and lead and today it more comon to use 63/37 solder because it has lower melting temperature and it has lightly greater mechanical
strength.
you can read the rest here
http://www.edaboard.co.uk/60-40-vs-63-37-solder-t469133.html
Ido Aricha , Israel.
Offline david77
« Reply #41 on: May 01, 2011, 08:34:55 pm »
The last one has a bit of silver in it, that bumps the price up a bit.
However, I do find all of those three rather expensive. Why not pick a 0,5mm for half the price?
Like this one: http://uk.farnell.com/multicore-solder/3096525-m/solder-wire-60-40-0-5mm-250g/dp/5090787
Offline tecman
« Reply #42 on: May 01, 2011, 10:06:40 pm »
You should try to get 63/37.  It is known as eutectic solder.  This means that it is an allow that has only solid and liquid states (other than vapor at high temps).  All other alloys have a third "shush" state.  If you do a lot of soldering with 50/50 or 60/40 you will remember the slush state.  This means that 63/37 is a bit easier to work with, and has the same basic properties of 60/40.
paul
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #43 on: May 02, 2011, 12:07:42 am »
Well I will add too an suggestion about a tool  ;)
I got it for heatshrink tubes, but now I use it for many more tasks.
Drying out washed PCB , softening plastics , testing K probes,  and many more applications..
https://www.eevblog.com/forum/index.php?topic=1093.0
Uncle Vernon
  • Guest
« Reply #44 on: May 02, 2011, 01:15:34 am »
The secret to that immaculate Kiriakos blow wave is finally out.   ;D
Offline amigo
  • Professional Wannabe
« Reply #45 on: May 02, 2011, 01:56:20 am »
I thought I read that reason we should use 63/37 solder is because the melting points of the compounds are close to/identical, as opposed to 60/40 whereas one would melt sooner than the other and make a mess of the soldering work.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #46 on: May 02, 2011, 04:33:53 am »
I have an small difficulty to translate the text 100% , but it looks that it says goods things for me ..  :D
Long live the Uncle Vernon   ;)
Offline johnwa
    • loopgain.net - a few of my projects
« Reply #47 on: May 02, 2011, 10:11:56 am »
One useful category of items is resistance/capacitance substitution boxes. Even a 100k pot with some croc clip leads attached can be quite useful. If you don't know what you're doing when designing something, just substitute the pot for a fixed resistor, adjust until your circuit works best, measure the pot, and now you know what value resistor to use :) Put a 1k in series with the wiper, so you don't blow stuff up when you turn it all one way.
I agree with the suggestion of croc clip jumper leads - they are good for prototyping circuits that exceed the power handling capabilities of a breadboard.
You will probably be building things with mains power supplies eventually, so an isolation transformer and insulation tester are a good idea.
Offline kcs
« Reply #48 on: May 02, 2011, 10:54:32 am »
paul
So I should pick this one - 62/36/2 Sn/Pb/Ag?
Offline tecman
« Reply #49 on: May 02, 2011, 02:21:21 pm »
Here is a brief explanation:  http://www.ami.ac.uk/courses/topics/0244_tsm/index.html
Paul
