Author Topic: EEVblog #211 IET Wide Range Resistance Box  (Read 3210 times)
Offline Conrad HoffmanTopic starter
    • The Messy Basement
« on: October 28, 2011, 07:56:18 pm »
FWIW, if you look at an old Julie Research 1 ppm Kelvin Varley divider, they used the same trick to get within tolerance- add a small piece of resistance wire to the lead of a resistor. My guess is that's what IET did on that one odd connection, though I have to agree, the entire construction isn't up to a really professional standard.
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: EEVblog #211 IET Wide Range Resistance Box
« Reply #1 on: October 29, 2011, 01:40:32 am »
Im somewhat suprised at cost & construction detail on such expensive decade, it looks like mine altrough much cheaper is better.
Oh, the joy of sending various electronics to silicon heaven
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #2 on: October 29, 2011, 10:40:58 am »
It is possible to build such a decade box with only 4 resistors per decade, using commercially available thumbweel switches,   like those made by Crameda (I fear that they are expensive, being Swiss made...)
The catalog is here http://www.crameda.com/pdf_files/eng/multiswitch/MS-U-E-060915.pdf
You need the version 632 (page 4) but beware that there is an error in the schematic : the 4 resistors' values should be  3R, 4R 1R and 1R, and not 3R, 4R, 2R and 1R as indicated.
EDIT: the values shown on the data sheet do not result in the correct values when the switches are set according to the truth table,  or at least this is what I get after filling two A4 pages with schematics.. If another member wants to show me where I'm in error, he's welcome.
You need  the values 3R, 4R, 2R and 1R if you want to have a total resistance value from 0 to 10, as shown at the end of Dave's episode #212, but a decade starts form 0 and ends at 9, value 10 is the second first one of next decade.. (and this requires a different switch arrangement)
We used a similar construction for the thumbweel set-point selector of temperature controllers, but it was many years ago, when electromechanical components were cheaper..
Weeks ago I've seen one of them at a customer's plant: the controller is still working after more than 20 years, the only problem is the dim HP LED display...
« Last Edit: October 30, 2011, 01:56:01 pm by ciccio »
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Bored@Work
« Reply #3 on: October 29, 2011, 12:28:29 pm »
They have an online shop. Depending on configuration they quote in the range of 23 to 35 Euro per Series U, 632-type switch, excl. VAT (they might bill in CHF, I didn't check, and since they aren't in the EU, you might have to pay some import tax).
What I find great about their offerings are the dummy switches - if you need some non-functional switches for "aesthetical reasons". Almost 12 Euro per U-series dummy.
« Last Edit: October 29, 2011, 12:30:40 pm by BoredAtWork »
