Author Topic: EEVblog #266 - Mailbag  (Read 8807 times)
Offline madwormTopic starter
« on: April 06, 2012, 08:46:14 pm »
Hi Dave,
I hope you will enjoy building the board(s).
And as it seems my handwriting hasn't improved since primary school at all, let me briefly 'translate' then essence of what was written down on the sheets (A4 of course) ;-)
thanks for promoting / testing KiCad
And (another and...) unfortunately I don't have a ZIF socket for TQFP-32 chips, these are prohibitively expensive.
If you should ever want/need to reprogram that device, I suggest flashing a different bootloader than what is currently on there. The internal RC oscillator really isn't good enough for 115200 (sigh). Code and installation information orbiting around the 'Arduino' security-blanket can be found here.
« Last Edit: April 06, 2012, 08:50:04 pm by madworm »
Offline Short Circuit
Offline T4P
  • Country: sg
    • T4P
Re: EEVblog #266 - Mailbag
« Reply #3 on: April 07, 2012, 02:22:47 am »
50$ - that's a lot more tolerable than what I've seen elsewhere.
But since I don't have to deal with hundreds of these chips, it's currently not worth getting it. For Dave's specimen I used an otherwise useless circuit board, some adhesive tape and my thumb. Not all too pleasant to align, but it works. I've been thinking about making a silicone mold for this package + a matching PCB for quite some time. Never got around doing it though. Something like that would be good enough for a couple of chips once in a while.
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: April 07, 2012, 02:37:57 am »
Yep , a local store was selling $200 ... OH THE HORROR .
Offline chrome
« Reply #5 on: April 07, 2012, 10:09:06 am »
Well for $50 i can another UT61E  :)
You're talking as if that's even a good meter...
Offline T4P
  • Country: sg
    • T4P
« Reply #6 on: April 07, 2012, 01:20:46 pm »
Well for $50 , not that good but hey , 22000 counts and fast autoranging . (not the D , the D sucks) And ! TrueRMS !
Offline T4P
  • Country: sg
    • T4P
« Reply #7 on: April 07, 2012, 01:20:58 pm »
http://www.dealextreme.com/p/ic-socket-plcc20-plcc24-plcc28-plcc32-plcc40-with-plcc-extractor-tool-117717
« Reply #8 on: April 07, 2012, 01:21:06 pm »
True.
Or 7 coronas at the pub.
Equally useless if you're after a device socket for a qfp...
Offline SILK
« Reply #9 on: April 07, 2012, 03:15:19 pm »
About the Tiny Gecko STK...
It seems like it's just the Tiny Gecko STK that doesn't have a gecko on the board. My EFM32 Gecko STK has a capacitive touch button that is shaped like a gecko. Pretty neat.
The EFM32G microcontrollers are great. It takes some effort getting used to it (I've only used AVR before). Especially because you have to activate the clocks for everything you are going to use manually (to have full control over the power usage). For some peripherals you even have to specify which pins you want to use, since some peripherals can be assigned to several pin configurations. It took me about 8 hours of swearing before i figured out that I had to specify which pins I wanted to use for the LEUART. Missed one registry when I read the reference manual. But now that I know that, it's a breeze to use.
If you don't want to spend a lot of money on the IAR Embedded Workbench, I recommend setting up the eclipse toolchain (see application notes in simplicity studio).
The documentation for the microcontrollers is absolutely fantastic!
Offline BobC
« Reply #10 on: April 09, 2012, 03:17:06 am »
The truly great thing about the Gecko family isn't the low-power ARM M0 core: Everyone is making chips with that core these days.
What's great is how the on-board peripherals are tightly integrated into the power reduction and management schemes.  You can do a tremendous amount of processing using only the peripherals without any CPU involvement, waking the CPU only for things like DMA buffer exhaustion.  The configurable switching matrix interconnecting the peripherals permits several peripherals to operate in parallel, all without CPU attention.  Truly amazing.
Using various members of the EFM32 family, you can have nanowatt embedded systems that are continuously active, and can wake the CPU when needed to provide tremendous computing power.
I'm a particular fan of the tiny gecko, and have the same evaluation board at home.  I can't wait to use that processor in future projects at work.
The Segger J-Link is a fully functional Segger debugger that can be used as a separate tool using the debug connector, without using the on-board EFM32.  There is a Segger coprocessor on the board, hidden under the LCD.
The coin battery holder is no joke:  The board can operate for prolonged periods doing substantial I/O powered only by the coin battery, so long as you carefully manage the CPU wake time and clock rates.
If you don't want to pay the full price for the board, the various Energy Micro distributors often host half-day seminars where they either give the board away for free, or for less than half-price.  I highly recommend attending the seminar (which is how I got my board): Learning to program multiple interconnected peripherals to work while the CPU is off, and to wake the CPU when needed takes some careful planning,and the demos are invaluable.
Offline T4P
  • Country: sg
    • T4P
« Reply #11 on: April 09, 2012, 12:09:24 pm »
Sounds fantastic .   ;)
I've heard of people trying to get the STM32F4 to go into quite a low power  :o
Clearly that's a high performance M4 chip that in normal operation you can feel it warming up slightly ... while at idle it draws 5V@110mA  :o
Offline SILK
« Reply #12 on: April 09, 2012, 12:50:20 pm »
The EFM32G comes with a program called energyAware Profiler that you can use to monitor the current consumption in real time. You see what functions in your software that use the most current etc. In that way you can optimise your software for low current consumption.
In my latest project, I saw that the microcontroller used about 5 mA when in idle. I could see that the Low Energy UART was the sinner, so I tried to deactivate the TX-pin when not in use. BOOM! 72 uA idle current.
Offline 6502nop
  • $EA
« Reply #13 on: April 09, 2012, 02:27:16 pm »
To answer the most pressing question from the vid...
The quote is from "Evil Dead (3?): Army of Darkness".
If they run out of room on the PCB, they can just shorten it to "Boomstick".
nop
Offline sacherjj
« Reply #14 on: April 09, 2012, 08:11:26 pm »
nop
Engineer Smart.  Engineer S-Mart.
