Author Topic: EEVblog #291 – USB Power Supply Part 2 – The Housing  (Read 26504 times)
Offline EEVblog
Re: EEVblog #291 – USB Power Supply Part 2 – The Housing
« Reply #75 on: June 21, 2012, 03:39:32 am »
Some of the Hammond 1593 series have nearly symmetrical halves (again, one half has countersunk holes) but, crucially, the halves are  flat.
Almost perfect. But unfortunately not high enough, only 11mm pillar which is likely not adequate for the binding post.
Dave.
Offline neal.sprouse
« Reply #76 on: June 27, 2012, 03:21:45 am »
Possible custom case.
http://www.clickfoldplastics.com/
I know there is a setup fee, not sure of pricing. Might give you a break if you show them you site.
Offline george graves
« Reply #77 on: June 27, 2012, 08:17:17 am »
Sounds like Dave needs a laser cutter.  Here's a great example of what's posiable:
