Wow, this seems to be picking up again...
I need to look into this. I was planning on doing another run by the end of the year, but that's not going to happen . I am too busy.
I have secured a supply of the transistors though. I have a few thousand of em now. All new old stock made by signetics. They avalanche nicely.
I will place an order for a batch of boards.
I am assuming everybody can easily get standard passive smd parts in his/ her country
I would do the kit as follows
Pcb
The linear boost chip
The switch
The diodes and high voltage caps
The battery clip
Two of the transistors , so you have a spare
The angled sma connector
The 50 ohm output resistor (we need a non inductive here)
The case
Essentially the parts that may be hard to get locally.
Then again.. The remainder is 4 resistors and 2 caps...
Or i could simply do pcb,transistor,case.
The problem is always the cost of international shipping. Flatrate boxes have gotten expensive,
That turns some people down... And the customs paperwork and other blabla...
I need to find a better way.
