Author Topic: EEVblog #365 - ESR Meter Bad Cap Monitor Repair  (Read 45006 times)
Offline Slobodan
  • Banned!
  • Country: cs
« on: October 06, 2012, 08:01:56 pm »
What is the purpose of those parallel solder lines on the ground plane?
Offline EEVblog
Re: EEVblog #365 - ESR Meter Bad Cap Monitor Repair
« Reply #1 on: October 06, 2012, 08:05:12 pm »
To lower the trace resistance. I have done several videos on this.
Dave.
Offline midasgossye
    • Bike2Charge
« Reply #2 on: October 06, 2012, 08:28:26 pm »
How expensive are ESR meters and are there specs you have to watch out for?
Offline Slobodan
  • Banned!
  • Country: cs
« Reply #3 on: October 06, 2012, 08:31:26 pm »
Dave.
Ah, yes. I have seen those videos, but I don't understand why they don't just "flood" the whole ground plane with solder instead of making those parallel lines.
Online firewalker
  • Country: gr
« Reply #4 on: October 06, 2012, 08:36:56 pm »
EEVblog #365 !!! "One year" of EEVblog videos.
Alexander.
Offline notsob
« Reply #5 on: October 06, 2012, 09:24:26 pm »
"later model" bob parker design ESR meter link
http://www.anatekcorp.com/blueesr.htm
and the older model
http://clientes.netvisao.pt/greenpal/evb1.htm
Offline tom66
  • Electronic Engineer & Hobbyist
« Reply #6 on: October 06, 2012, 10:52:44 pm »
Ugh - Samwha. Samwha caps are in no way to be considered good. They had a consistent 1-2 year manufacturing defect with their WB, WL and  MK series capacitors. This killed loads of Samsung and LG TVs. They are still dying - just a couple of months ago I picked up a 40" Samsung LCD TV with three bulging Samwha.
« Reply #7 on: October 06, 2012, 11:10:36 pm »
Just stripped a 1997 made Samsung 24' CRT monitor - died from LOPT failure after 15 years of use. Uses a lot of Samwha caps inside, they are all still good, or at least are not bulging.
Offline SteveyG
« Reply #8 on: October 06, 2012, 11:33:51 pm »
LG stands for Lucky Goldstar. 'Life's Good' is their slogan. Get it right!  :-\
Offline tom66
« Reply #9 on: October 06, 2012, 11:42:41 pm »
I think it's mostly their newer ones - beforehand they were owned by Samsung then got spun off - maybe lost some key talent or just a consistent manufacturing defect.
Offline DL8RI
« Reply #10 on: October 06, 2012, 11:51:19 pm »
Hi Dave,
I saw your videos on repairing these Monitors and I have done this several times... and I've a little question...
This tool you use to crack the clips open... how is it called? (seems to be some chisel for medical use?!)
I was always fighting with those stupid cases not to ruin the clips and the plastic-case itself. This tool seems to be quite handy (more than a knife, screwdriver, whatever ;) ).
73 and thanks,
Martin
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
« Reply #11 on: October 07, 2012, 12:01:30 am »
I'm just wondering - you are measuring ESR of caps in circuit, caps frequently are in parallel together - it should affect ESR readings somehow, shouldn't it?
Offline nitro2k01
« Reply #12 on: October 07, 2012, 12:16:18 am »
My guess is that it is because you want a segment of solder to solidify roughly simultaneously over the whole segment when wave soldering. If you have a big solid area of exposed copper, one end might soldify while the other end is still being sprayed with solder.
Offline madires
  • A qualified hobbyist ;)
« Reply #13 on: October 07, 2012, 12:18:00 am »
Like resistors in parallel.
Online mariush
« Reply #14 on: October 07, 2012, 12:19:59 am »
Yes, that's an important thing that wasn't mentioned at all in the video and it's important.
If capacitors are in parallel, when testing a capacitor the ESR value reported will be much lower, it can fool you into thinking a capacitor is still "good enough" to leave it there, and a few weeks later your monitor is broken again.
I'm otherwise really disappointed.
Dave, considering so many people watch your videos, and you know they're gonna recommend them to others, it's really not a good idea to keep using crap no-name capacitors and excuse yourself saying that's all you have. Also, considering a few capacitors in that area have failed, there's really no excuse for leaving those other capacitors on the board, even though they still measured good, you can never know how long they're going to remain good.  A name brand capacitor is half a dollar, even less, no reason to be cheap with that.
You should be more responsible about this, you're just encouraging people to make poor quality fixes.
Offline KD0CAC John
« Reply #15 on: October 07, 2012, 12:22:02 am »
The tool looked to me like a butter knife with the end cut off and I would think a bevel ground on end ?
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
« Reply #16 on: October 07, 2012, 12:24:00 am »
... This tool you use to crack the clips open... how is it called? (seems to be some chisel for medical use?!) ...
It's a "spudger."  Commonly included in laptop and iPad, iPod repair toolkits.  Very cheap on eBay.
« Last Edit: October 07, 2012, 12:27:55 am by ModemHead »
Offline madires
« Reply #17 on: October 07, 2012, 12:28:16 am »
AFAIK, it's called spudge tool or spudger.
I'm using spatulas (width of 2-3 cm) from the DIY shop. They distribute the torque quite nicely across the width without damaging the case too much.
Offline Slobodan
  • Banned!
  • Country: cs
« Reply #18 on: October 07, 2012, 12:40:49 am »
Thanks.
Offline DL8RI
« Reply #19 on: October 07, 2012, 12:41:25 am »
Hi!
a "Spudger", never heared of... would have never found it... thanks :)
Just ordered two via eBay... will be tested on the next "broken" TFT after my bench is usable again.
73,
Martin
Offline Slobodan
  • Banned!
  • Country: cs
« Reply #20 on: October 07, 2012, 12:56:56 am »
About the spudger, is this one OK?
http://www.ebay.com/itm/Metal-Spudger-Scraper-Knife-for-Ipod-touch-4-Iphone-4-Ipad-2-Repair-Open-Tool-/330744063490?pt=Other_Tablet_eReader_Accessories&hash=item4d01e1e602
Or should I buy some other one?
And about caps, are Fujicon (TN and TM series) any good?
« Last Edit: October 07, 2012, 01:16:52 am by Slobodan »
Offline Wytnucls
« Reply #21 on: October 07, 2012, 01:00:59 am »
Wikipedia says it is possible to measure ESR with a square wave generator and oscilloscope. Does anybody know how?
http://en.wikipedia.org/wiki/ESR_meter
« Last Edit: October 07, 2012, 01:02:52 am by Wytnucls »
Online Monkeh
Offline ModemHead
    • Mr. ModemHead
« Reply #23 on: October 07, 2012, 03:20:46 am »
About the spudger, is this one OK? ...
Looks just like the one I have. It came in a kit with various other plastic implements of destruction. The only one of which I've found useful is the "black stick".  Really.  Just search "black stick spudger" on eBay.
Offline tom66
« Reply #24 on: October 07, 2012, 03:25:43 am »
This is a very good point. A lot of people re-cap things with capacitors from RadioShack or Fry's or Maplins. About a month to a year or so later, the device dies - and they wonder why. A lot of it ends up in the trash, and is harder to repair because those caps were "close enough", but not the same.
