Author Topic: EEVblog #384 - Agilent 4000X Oscilloscope Teardown  (Read 6440 times)
Offline nitro2k01
« on: November 14, 2012, 05:51:50 am »
It's subtle, but I noticed you kept the video speed-up going through the boot process. And it still feels like it's taking forever. :-DD
Re: EEVblog #384 - Agilent 4000X Oscilloscope Teardown
« Reply #1 on: November 14, 2012, 06:37:47 am »
4 channel USB hub with one connected to the touchscreen.
Offline kg4arn
« Reply #2 on: November 14, 2012, 09:58:11 am »
What's the switch for (S3400) @ 8:03?
OOPS  I see it now on the back panel of the scope.
« Last Edit: November 14, 2012, 10:36:47 am by kg4arn »
Offline JackOfVA
« Reply #3 on: November 15, 2012, 05:40:37 am »
Is the reason for a higher quality time base to improve the jitter, not overall frequency accuracy? The worse the clock jitter the more trace to trace dispersion - maybe not important at 1 MHz but at 300 MHz a cycle is 3.3ns, so a jitter of 33 ps would cause 1% trace to trace shift.
Or is there some magic software inside the DSPs that averages out or compensates in some other fashion for time base jitter?
Jack
Offline ejeffrey
« Reply #4 on: November 15, 2012, 06:47:21 pm »
Maybe they decided that since they were adding the 10 MHz out it would be embarrassing if a $20k scope had a really crappy reference output :)
Offline wrieken
« Reply #5 on: February 14, 2019, 03:59:31 am »
Does anyone here know what probes are good (non-Keysight) for the Keysight MSOX4054A 500Mhz version?
Thanks,
William
