Author Topic: How to reduce leakage current by design for medical grade toroidal transformer  (Read 2754 times)
Offline yoganandTopic starter
Hi all,
I need to design low leakage current for medical grade transformer. If anybody in the loop pls help me.
Transformer specification : Primary 120V/60Hz, Secondary 120V/1000VA....leakage current < 50µA...Advance thanks for your help.
Offline tom66
Low leakage here presumably means SAFETY FIRST.
So why are you asking on a public forum where any idiot, such as myself, can give you a silly answer?
Offline peter.mitchell
In the wrong section, with only one post?
Because the primary and secondary are the same voltage I assume it's an isolation transformer..
*googles 1000va isolation transformer*
First result:
SXKK3535 - ISOLATING TRANSFORMERS - RPG
[url=http://www.radioparts.com.au/ProdView.aspx?...1000VA+ISOLATI]www.radioparts.com.au/ProdView.aspx?...1000VA+ISOLATI[/url]...
1000VA ISOLATION TRANSFORMER, MEDICALLY APPROVED, SINGLE ...
Specifically designed toroidal transformers to meet themedical requirements of IEC ...
wut.
