Author Topic: Deletion/Editing Testing 1, 2, 3, Testing 1, 2  (Read 5125 times)
Offline Bored@WorkTopic starter
« on: December 31, 2013, 07:54:27 am »
This first post can't be deleted/remove, only edited.
An Error Has Occurred!
You cannot delete your own topics in this board. Check to make sure this topic wasn't just moved to another board.
« Last Edit: December 31, 2013, 08:51:04 am by Bored@Work »
Re: Deletion/editing Testing 1, 2, 3, Testing 1, 2
« Reply #1 on: December 31, 2013, 07:54:53 am »
This is Nbr 2.
Nbr. 3 below was deleted.
« Last Edit: December 31, 2013, 08:52:58 am by Bored@Work »
Offline GeoffS
Re: Deletion/Editing Testing 1, 2, 3, Testing 1, 2
« Reply #2 on: December 31, 2013, 08:32:17 am »
Your deleted post is in the recycle centre and can be restored.
« Reply #3 on: December 31, 2013, 08:37:05 am »
Test?
Was recycled
« Last Edit: December 31, 2013, 08:39:17 am by GeoffS »
« Reply #4 on: December 31, 2013, 08:38:08 am »
Can delete, should be in the round file analog in SMF.
Testing modify, does it work?
Mod again - YES!
Offline GeoffS
« Reply #5 on: December 31, 2013, 08:50:47 am »
Looks like deleted  posts get restored in the right order too and not just tacked on the end of the thread,
Online EEVblog
« Reply #6 on: December 31, 2013, 09:27:11 am »
Nice!
Offline Psi
« Reply #7 on: December 31, 2013, 10:36:16 am »
Test
EDIT:
Yay, "Modify" button is back in the screen location i'm used to.
I kept quoting myself accidentally when trying to modify because everything had moved over by 1.
hehe, removing the delete option made me need it more.
Deleted and restored!
« Last Edit: December 31, 2013, 10:47:23 am by GeoffS »
« Reply #8 on: December 31, 2013, 04:37:56 pm »
Thanks, seems the storm in a teacup is over for the moment.
