Author Topic: EEVblog #508 - Can You Test Battery Charge By Dropping It?  (Read 21724 times)
Online EEVblog
« on: August 15, 2013, 07:15:55 pm »
Can you determine the charge of an alkaline battery by simply dropping it and see how high it bounces?
A followup to the KipKay video
Offline ddavidebor
    • Fermium LABS website
« Reply #1 on: August 15, 2013, 07:36:59 pm »
Mmh morning video niceeee
Davide Bortolami,
Fermium LABS srl
Offline adam1213
Re: EEVblog #508 - Can You Test Battery Charge By Dropping It?
« Reply #2 on: August 15, 2013, 08:47:15 pm »
The result you get might be correct. However I am not convinced by the testing method. Dave - thanks for doing a video about battery bounce vs charge.
Areas that could be done better:
  • Do a blind test where you have a group of batteries of unknown charges, drop batteries, rate the charge based on the drops then compare it with a multimeter / see if you can rank the charge based on the how they bounce, record it then compare it with the actual result.
  • Drop the batteries in the same way from the same height. e.g. use a line to drop the batteries from. Preferably make a device do the dropping. In the video
  • Show that a given battery normally bounces in a certain way.
« Last Edit: August 15, 2013, 08:50:36 pm by adam1213 »
Citizen
  • Guest
« Reply #3 on: August 15, 2013, 08:56:06 pm »
OMG it is not  rocket science...
 |O
Charged batteries have more electrons=> more weight,
Empty battery=>less electrons=>less weight.
You can also spin batteries to check if they are charged:
If it is full with electrons, then the battery will not wobble, since the mass is distributed equally through he whole? battery.
In case it is discharged, then it will wobble, because the electrons will shift the mass center...
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: August 15, 2013, 09:01:14 pm »
Why would anyone think this is about weight? Weight changes would not change the bounce.
It's clearly a damping effect due to the change in physical properties affecting the mobility of the stuff inside, which change how much mechanical energy it absorbs.
I bet if you opened them up you'd find the bouncy one less goopy than the other
Day Job: Mostly LEDs
Online EEVblog
« Reply #5 on: August 15, 2013, 09:03:52 pm »
I said it was deliberately a very quick unscientific test, just as a go/no-go to show if it's true or not, or marginal.
From the result it is almost certainly true. I was expecting it to be marginal, but it's a fairly big difference in bounce.
I dropped some other fully charged ones and it appears consistent, as you'd expect.
« Last Edit: August 15, 2013, 09:12:12 pm by EEVblog »
Online dr.diesel
« Reply #6 on: August 15, 2013, 09:05:53 pm »
Perhaps some of the same reason dead batteries are prone to leaking as well.
Online EEVblog
« Reply #7 on: August 15, 2013, 09:08:53 pm »
 |O
To quote Doc Brown - "weight has nothing to do with this"
It is not the weight, it is a change in the dampening effect of the changed chemical reaction and hence composition in the battery, as I mentioned in the video.
Offline tinhead
« Reply #8 on: August 15, 2013, 09:14:05 pm »
right, it is not weight directly. An discharged batt have (actually you cant "have" dark matter, you can only "bind" it) less dark matter (which is due changed potential and/or amount of electrons), so the influence of dark energy (on the gravitrons) is bit higher and the batt can bounce more/higher.
Online EEVblog
« Reply #9 on: August 15, 2013, 09:16:27 pm »
Using a multimeter to determine a batteries charge level is a very poor way to do it.
I will do that, but I need some bits and more time.
I can confirm fully charged batteries bounce to roughly the same height.
Citizen
  • Guest
« Reply #10 on: August 15, 2013, 09:17:55 pm »
Lol. i was joking:))
BTW a charged battery has as much electrons in it as a discharged one;)
Online EEVblog
« Reply #11 on: August 15, 2013, 09:24:09 pm »
KipKay's video is a complete ripoff of this one done a month ago:
Offline Wytnucls
« Reply #12 on: August 15, 2013, 09:32:16 pm »
You could also carefully recharge the depleted battery and see if it stops bouncing.
Offline Psi
« Reply #13 on: August 15, 2013, 09:56:30 pm »
It's probably to do with the reflected shockwave being somewhat absorbed vs propagated throughout the battery chemicals.
A better question is, if you do it repeatedly will the absorption/propagation rob a full battery of charge or recharge a flat battery.
« Last Edit: August 15, 2013, 09:58:46 pm by Psi »
Offline ddavidebor
« Reply #14 on: August 15, 2013, 11:05:01 pm »
No
Davide Bortolami,
Fermium LABS srl
Offline Wytnucls
« Reply #15 on: August 16, 2013, 12:00:58 am »
When the battery discharges, hydrogen gas is formed, increasing the internal pressure in the battery. The spongy KOH electrolyte then acts as a spring at impact, with a higher recoil than in a charged battery.
With the aid of a micrometer, one may be able to measure a slight difference in battery overall length depending on charge condition.
Offline lewis
  • Nullius in verba
« Reply #16 on: August 16, 2013, 01:35:04 am »
Is it April 1st already?
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline LaurenceW
    • It's Time, Jim, but not as we know it
« Reply #17 on: August 16, 2013, 02:29:45 am »
My dad dropped the car battery from our old Austin Marina on his foot, once. That was flat, but I don't think it bounced that much. I did learn a new Anglo-Saxon expletive, however.
If you don't measure, you don't get.
Offline KedasProbe
« Reply #18 on: August 16, 2013, 04:25:33 am »
Maybe you can drill into one at the top to let the gas out.
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
Offline hammy
« Reply #19 on: August 16, 2013, 06:36:47 am »
... as I mentioned in the video.
Before the video you bounced the batteries and then you discharged the two who bounces better. Then you marked them black and made the video.
No need to fake the video. You sorted the batteries before.  :=\
Offline Legit-Design
« Reply #20 on: August 16, 2013, 06:39:01 am »
For next video, someone needs to go to the store and get fresh pack of batteries and film it all on one go. From buying to testing to conclusions. Please get James Randi as your audience so there is no trickery. After that someone will determine that the people at the store were actors and it was all faked.
« Last Edit: August 16, 2013, 06:40:59 am by Legit-Design »
Online IanB
« Reply #21 on: August 16, 2013, 06:51:14 am »
So is nobody going to mention that dropping batteries onto a hard surface is a really bad idea?
With NiMH you can certainly damage the internal construction and cause a permanent loss of capacity.
With alkaline batteries there is a danger you could weaken the seal and make the battery more prone to leakage.
With carbon-zinc batteries you could snap the positive carbon electrode and kill the battery.
A good rule for all batteries is to treat them gently and do not subject them to mechanical shocks.
Offline firewalker
  • Country: gr
« Reply #22 on: August 16, 2013, 07:46:49 am »
Take two metal cylinders. Fill them with water. Freeze the one. Drop them.
Alexander.
Offline Psi
« Reply #23 on: August 16, 2013, 08:06:57 am »
No
You can't say that unless you've actually tested it.
« Last Edit: August 16, 2013, 08:08:35 am by Psi »
Online EEVblog
« Reply #24 on: August 16, 2013, 09:14:09 am »
I assume you are kidding, right?
