Author Topic: EEVblog #508 - Can You Test Battery Charge By Dropping It?  (Read 33004 times)
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
Re: EEVblog #508 - Can You Test Battery Charge By Dropping It?
« Reply #50 on: August 19, 2013, 07:26:49 pm »
Well, I'm really astonished: tested more than 40 dead or very discharged batteries (all VARTA INDUSTRIAL) against 10 new, charges batteries: it works. Dead cells bumps and fall down, charged cell stand up.
It's time to find the free time to investigate.
Best regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Dread
« Reply #51 on: August 20, 2013, 02:51:34 am »
Reply 31 and 42 have the right answers.
While I find the bounce test to be impractical I do know of one practical application for a similar kind of testing.
For a long time myself and several other engineers at work noticed that 9V batteries could easily be tested to see how good they are by squeezing the flat side of the battery between our fingers.  A fresh fully charged battery feels solid but a dead battery feels squishy, we could actually see the sides squeeze inward between our fingers.  One day we decided to cut one open and what we found was that the material inside had contracted away from the sides as it dried out leaving about .5mm of space going around the battery.  It would stand to reason that the same thing happens with the AA battery and the contracted material allows the end cap to flex inward and create a greater bounce.   It's funny how stuff that a few engineers played around with 20 years ago comes back up again.
The Optimist says the glass is half full, the Pessimist says its half empty, an engineer only see's a glass that’s twice as big as it needs to be!
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #52 on: August 21, 2013, 06:17:18 pm »
Why would anyone think this is about weight? Weight changes would not change the bounce.
+1. Although there is a small change in mass given the decrease in energy (nice explanation here).
I wonder if this is still valid if the 9V battery is comprised of six LR61 cells (or AAAA)... (wikipedia reference)
Offline PA4TIM
« Reply #53 on: August 26, 2013, 01:33:31 pm »
Funny, I'm gonna try this.
But about a tear ago I did some testing on batteries. Nicad, nimh, lead batteries and normal akaline. I found out full batteries have an impedance that is  Real Ohms with a small inductive imaginair part. Empty but still good rechargable batteries have a higher (AC, 1 kHz ) Rs as full ones but still an imaginairy part close to pure Ohms. A bad battery however has a much bigger negative imaginair impedance part. It is capacitive. I tested this with a lot cells and the measurement is done with a GR1650 and a HP decade to zero the bridge. And checked measurement (not from all tested cells because it takes a lot of time) with a VNA
I made a page about it on my site.  The reason I did this test was because I was experimenting with a desulfator. That test is not done yet. The dead battery is still connected to a loader and desulfator (so over a year) and I plan to do some tests again on it if I find the time.
http://www.pa4tim.nl/?p=3550
Offline dexters_lab
« Reply #54 on: August 26, 2013, 08:40:59 pm »
yes but would the gas not be within pockets? i'm not sure if the gas would be distributed around the inside of the battery case ready to be released by drilling a hole.
Offline EvilGeniusSkis
« Reply #55 on: June 04, 2015, 02:42:54 am »
Found this article on the bouncing batteries
http://www.princeton.edu/main/news/archive/S42/72/95S25/index.xml?section=topstories
turns out none of us got it right; @robrenz was the only one on the right track.
Online HighVoltage
« Reply #56 on: June 04, 2015, 06:54:38 pm »
Very interesting article.
Thank you very much !
« Reply #57 on: June 04, 2015, 09:55:21 pm »
Your Welcome, I read the article and the immediately thought of putting it on here for everyone else to read.
Maybe Dave should add a link in the video.
Offline ornea
« Reply #58 on: August 21, 2015, 12:05:00 pm »
OMG it is not  rocket science...
 |O
Charged batteries have more electrons=> more weight,
Empty battery=>less electrons=>less weight.
You can also spin batteries to check if they are charged:
If it is full with electrons, then the battery will not wobble, since the mass is distributed equally through he whole? battery.
In case it is discharged, then it will wobble, because the electrons will shift the mass center...
I dont think electrons are lost.  The same net electrons flowing out the neg (pos) equal the net electrons flowing into the pos(neg).  The battery does work to push them around.
Offline eilize
« Reply #59 on: August 23, 2015, 07:37:45 am »
nice try  ^^
a corpse   in free fall gain a speed
that speed....don't depend of the weight
it depend of gravity (ok it change from heigh...you need a lot of difference to see something :p)
a cannonball and a  feather fall at the same speed in vacuum
so, it depend of  air resistance (no luck a empty and a full battery have the same form or there is not enough difference)
IF you see difference when you let fall 2 battery ,it's because you don't blet fall at the same moment or the don't let fall from the same angle
Offline tree
« Reply #60 on: August 28, 2015, 11:48:34 pm »
Question is...If I slip on the batteriser, will the battery bounce higher or lower?
Offline amyk
« Reply #61 on: August 29, 2015, 03:00:23 pm »
Probably not at all, thus it can increase the charge in the battery and make it last longer. :-DD
Offline Godzil
    • My own blog
« Reply #62 on: September 01, 2015, 10:29:15 pm »
Don't do that! With the 800x more energy in your battery you may create a blackhole! That's what batteriser is, accumulating more energy in a small area, like a blackhole does!
When you make hardware without taking into account the needs of the eventual software developers, you end up with bloated hardware full of pointless excess. From the outset one must consider design from both a hardware and software perspective.
-- Yokoi Gunpei
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #63 on: September 02, 2015, 07:48:58 am »
Funfact:
If you try the bounce-test with a button cell, the bouncing effect is extreme.
If you use a small button cell out of an hearing aid, it bounce nearly to the same high if it hit a hard surface when its emty.
Offline ez24
  • L.D.A.
« Reply #64 on: September 10, 2015, 08:20:14 pm »
Who would have guessed that bouncing batteries gets to this level:
Support for the project was provided in part by the National Science Foundation, the U.S. Department of Energy and Brookhaven National Laboratory.
Offline apis
  • Hobbyist
« Reply #65 on: September 10, 2015, 10:29:14 pm »
Nice picture:
« Last Edit: December 02, 2018, 05:15:09 pm by apis »
Offline vinicius.jlantunes
  • Country: br
« Reply #66 on: September 11, 2015, 01:20:55 pm »
Thanks ez24 for that link, very interesting!
Offline ez24
  • L.D.A.
« Reply #67 on: September 11, 2015, 07:52:17 pm »
Thanks but it was not my link -- it came from EvilGeniusSkis
So I also say thanks to EvilGeniusSkis  :-+
  • Country: br
« Reply #68 on: September 11, 2015, 08:08:06 pm »
ooops, right, thank you both!  :-+
« Reply #69 on: September 28, 2015, 03:24:10 am »
Your welcome
Offline BrianHG
« Reply #70 on: December 02, 2018, 01:20:13 am »
Here is a really good side-by-side comparison of full and empty batteries, and why they bounce higher when they are empty:
