Author Topic: Please allow .jpeg attachment in forum  (Read 2511 times)
Offline spthTopic starter
« on: February 28, 2019, 10:39:34 am »
.jpeg is a common extension for JPEG files. having to rename them to .jpg for use in this forum (since the forum software currently only allows .jpg, not .jpeg) in annoying.
Online Psi
Re: Please allow .jpeg attachment in forum
« Reply #1 on: February 28, 2019, 11:01:19 am »
.docx and .rar are also missing.
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: February 28, 2019, 01:11:40 pm »
Those I can understand. They are easy to exploit with malicious code. If you want to share documents with the internet, see Google Docs.
But jpeg should be added. Maybe also HEIF, HEIC and .HEICS should be added for innovative support?
https://www.eevblog.com/forum/chat/forum-admin-add-jpeg-file-extension-for-upload-pls/25/
Offline EEVblog
« Reply #3 on: February 28, 2019, 02:05:36 pm »
done
The following users thanked this post: rhodges, spth
Offline drussell
  • Hardcore Geek
« Reply #4 on: February 28, 2019, 03:30:46 pm »
 :o
Seriously?   :palm:
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5 on: February 28, 2019, 08:36:36 pm »
 :o
Seriously?   :palm:
Uhm. Yes?
It's perfect for sharing and collaborating on documents on the internet.
If you want to share finished documents, use pdf.
done
For archive purposes, today supported:
doc, gif, jpg, jpeg, pdf, png, txt, zip, tar, c, h, hex, bas, xls, odt, asm, wav, aiff, wma, mp3, flac, asc, ods, xlsx, py
« Reply #6 on: February 28, 2019, 10:30:33 pm »
done
Can I suggest that if it is not already done you block or at least require moderation approval for posters with with low post counts (sub 1 - sub 5?) adding attachments if you are going to allow this expanded range of files. Much as everyone should use common sense with downloads not everyone has that  :o
Also odf and docx would be the other two to complete the set.  :)
 :o
Seriously?   :palm:
Good reasons to use Google docs occasionally for forum sharing due to the file size limit. I did this last week for a fat PDF for one of the members.
