Author Topic: EEVblog #56 – Agilent U1253A OLED Multimeter Review  (Read 23968 times)
Offline chemicaloliver
    • Chemicaloliver.net
« on: January 24, 2010, 10:35:17 pm »
I've been waiting for this review as when you mentioned you were about to review an Agilent meter I was just about to buy one, initially I planned to wait till after you reviewed it but got fed of of waiting and picked up the model at the other end of the range, the UT1241A and I'd just like to add a few comments.
The U1241A seems to not have some of the issues that the U1253A has, firstly it uses 4 AAA alkaline batteries which seem to give a much longer life, it also has slots for high voltage protection.
The probes supplied with the U1241A seem to be better than the ones you had, they consist of a banana plug lead which plugs into a socket on the end of the probe. It also came with two sets of probes, one sharp one blunter.
It does share the same issues with continuity speed which I was disappointed with as even my old UNI-T meter is much faster.  I've now had two U1241A's (I returned the first) as the stand is crooked when laid flat, and it been the same in both that I've had which is a bit annoying.
Despite the shortcomings I think that these are very good value meters especially at the lower end of the range as accuracy wise it gives something nearer to the fluke 87 for nearer the price of the fluke 179. Maybe some of the issues I mentioned being different will have changed in the new version.
Offline Ferroto
Re: EEVblog #56 – Agilent U1253A OLED Multimeter Review
« Reply #1 on: January 25, 2010, 02:26:58 am »
I wouldn't have given that product a thumbs up. I can excuse the placement of the fuses, the display only working indoors, the annoying music, the rechargeable 9v battery But the cold solder joint you showed us isn't consistent with something I'd be willing to pay up to $400 for. I'm quite shocked that Agilent would field this product as it is hopefully the next model isn't this bad.
Offline cybergibbons
« Reply #2 on: January 25, 2010, 10:44:41 am »
I was looking at getting one of this range, but the review has really turned me off the meter. Main reason being the slow autoranging and slow continuity beep. These are the kind of thing that would wind me up day after day. Maybe they'll fix it in the next revision.
Also, there's niggling things. The poor solder joint should have been caught by QC on a product this expensive. I wouldn't really trust a meter to hold accuracy if it was like this. Why make the fuses so hard to access? Why not make a bit more of the dot-matrix display?
Offline dc100GHz
« Reply #3 on: January 25, 2010, 04:52:42 pm »
Cold solder is a deal breaker. I'd expect a better QC for a $400 multimeter.
If HP were still around they would design a multimeter that could compete with Fluke. But ever since Agilent took over, they killed the HP way, and outsourced production and design.
Offline Zero999
  • Hero999
« Reply #4 on: January 26, 2010, 01:15:23 am »
Yes, it's probably made in China as everything is. It doesn't seem like we have a choice nowadays when even so-called high-end stuff is still poor quality.
Offline EEVblog
« Reply #5 on: January 26, 2010, 08:54:48 am »
Well, it looks like I've created a furore with my "thumbs up" rating in this blog!
So many emails, comments, and even a video response.
There might have to be a follow-up video on this!
Dave.
Offline qno
« Reply #6 on: January 28, 2010, 07:13:40 am »
Hi Dave,
Congratulations on your review.
I have a bit mixed feelings. I wanted the Agilent to be good and at least in the Gossen class equipment.
I have used HP equipment for many years and they earned my respect.
However some aspects of this meter are a bit disappointing.
I have a feeling that different design principles have been used at Agilent than when it was HP.
The NEC processor is a tell tale sign where the design came from.
I hear the same about the oscilloscopes I have evaluated a 3000 series and was not really impresses with the UI.
Lets hope they fix some of the issues in the B version and have the top model also with an LCD.
Why spend money I don't have on things I don't need to impress people I don't like?
Offline EEVblog
« Reply #7 on: January 28, 2010, 08:00:55 am »
Hi Dave,
The 3000 series Agilent oscilloscope is just a rebadged Rigol. The 6000 series and up on the other hand is Agilent design, and that really shows, that's one of my favorite scopes.
Yes, I agree the Agilent is disappointing in a few areas, they need to work on it. It is a not suitable as a mainstream everyday use multimeter.
Dave.
Online jahonen
« Reply #8 on: January 28, 2010, 11:28:46 pm »
I believe Agilent has been relatively recently expanding their low-end product range. When they were part of HP, they primarily made their products for those customers who weren't interested of the price tag (or if you must ask the price, then it is too expensive for you).
They are probably focusing their in-house designs at high-end market where they can be competitive, and outsourcing the rest.
Regards,
Janne
Offline EEVblog
« Reply #9 on: January 29, 2010, 08:16:45 am »
Yes, they bought Escort, so that's the group that is producing a lot of Agilents low end handheld stuff now I believe.
Offline Veramacor
« Reply #10 on: January 29, 2010, 09:45:14 am »
Let's see,
The main page clearly states the following in the first sentence...
"The EEVblog is an off-the-cuff video blog and Podcast of interest to anyone involved in electronics design."
Off-the-cuff.    The definitions for 'Off the cuff' that best describe what Dave is doing are:
"an impromptu speech"
"a few unrehearsed comments"
After watching Dave and his podcasts, does anyone really think that he planned and rehearsed to say things like:
"It was like I was being mooned!" (on opening the Agilent and seeing the back side of board first)
"Someone at Agilent should be shot!" (on Agilent's short battery life)
Dave is speaking to a camera in an impromptu manner.  Whatever comes to his mind about the subject at hand is obvious.
You can't get put off by the negative comments Dave makes about the reviewed products.  They are extremely helpful in deciding if its the product for you.  If the positive outweighs the negative for YOUR needs,  then the product "is the shit!".  If it's the other way around, then "its a piece of shit!".
If you want polished reviews of products, go to Consumer Reports.  If you want NO BULLSHIT points of view and opinion,  Watch Dave.
Come on now!  I bought the reviewed Rigol Oscilloscope Dave reviewed:
* without ever seeing one in person
* without being able to touch one in person
* relying it would get here in one piece from China
$400, that's how much I spent.  Never would have sent my money to China if it were not for Dave's invaluable reviews.  I was  >   <  close to buying a PC USB digital o-scope.  Cheaper by far than the real thing.  But Dave's review on PC DSO's changed my mind.  I made the right decision.
One thing about blogs,  doesn't matter the subject,  There is always a pissing match eventually.
EEVBLOG = VALUE.    nuff said.
« Last Edit: January 29, 2010, 09:52:19 am by Veramacor »
Offline EEVblog
« Reply #11 on: January 29, 2010, 01:05:38 pm »
Ain't that the truth!
If there is one thing I've learned with this blog (and all my forum stuff over the years) is that you can't even please a minority, so it ain't worth trying.
Publish and be damned!
Normally I ignore the trolls, but this time a few regulars (whose comments I take seriously) had concerns so that's why I thought I'd try and clear it up.
And I think it's great when someone like Stormbytes has the guts to produce a video response, rather than just pissing in the wind with anonymous comments. That alone deserved a response.
Dave.
Offline shawn01
« Reply #12 on: January 30, 2010, 07:11:48 pm »
I noticed on the agilent website …
An 8 hour battery life for the u1251b……. What if this meter has to serve 3 shifts of employees round the clock… apparently it was designed for the hobbyist. It appears there is no power supply for the meter that will provide the user with power in the event of a battery shortage
One solution for someone who has their sights set on the u1252 is to buy the meter for the 50000 count/.accuracy, and solder an external supply in to the battery compartment.
Although This is being cheap and relationships with data acquisition tools that start out that way are normally hell bent on disaster, this could be a good workaround if you already have one..
Or you could get a 50000 count bench meter between 4x and 5x more $ that can be  plugged into the wall.
Andrew
  • Guest
« Reply #13 on: January 30, 2010, 07:48:05 pm »
I don't know for whom Agilent designed the meter, apparently not for me. I wouldn't buy it, and that would be the end of the story for me. No need to get excited or agitated. Thousands of companies produce products every day that are simply not my cup of tea.
I would recommend against "fixing" the meter by soldering an external supply to the battery compartment. This breaks the isolation and you can forget about the 600 V or 1000 V CAT safety rating. In my book breaking safety is fare more worse than ridiculous battery lifetime, and in the particular case perverts the idea of "buying brand", aka paying for safety as kind of a life insurance.
No, even an brand bench meter like one from Agilent ;) would just set you back 450 USD (U3401A). More 1x times the price of the U1252A, than 4x times the price. A *cough* Mastech MS8050 *couch* would set you back $250 (don't take this as a recommendation).
« Last Edit: January 30, 2010, 08:42:13 pm by Andrew »
Offline EEVblog
« Reply #14 on: January 31, 2010, 08:53:38 am »
The U1251A is 72 hours battery life, not 8, I believe the B model is the same.
The U1253A was not designed for the hobbyist, it was designed for professionals who need an accurate 50000 count meter with bright OLED display.
The U1252A is the exact same thing for those who want an LCD display and longer battery life
The U1251A is slightly lower spec with double the battery life again.
No point arguing silly "what if" scenario's, you buy the appropriate meter for the job at hand. IMO none of these meters would be suitable for 3 shift round the clock use.
Dave.
Online jahonen
« Reply #15 on: January 31, 2010, 09:07:55 pm »
Not all Flukes are much better either on the battery life, my Fluke 89IV has 72 hours of battery life (according to the manual), and it uses 4 AA's! Well, at least it does not rattle and the fuses are easily accessible in the battery compartment :)
Regards,
Janne
Offline EEVblog
« Reply #16 on: January 31, 2010, 10:42:02 pm »
Yes, the equivalent precision high end Fluke's have roughly equivalent power consumption to the Agilents (when you take into account display and battery type), they just sensibly use a lot of AA's instead of a silly 9V battery.
Dave.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #17 on: February 03, 2010, 05:12:54 am »
I can see the thumbs up side for this meter it certainly look like a stunny peice of kit precision wise the sort of thing you would keep in the lab as the god of all meters and "the one" when it comes to ultimate accuracy, but it should be pointed out that this is about the only use this meter may ever have. I'd certainly not want to be carrying it around with me.
I think that on the protective holder they kind of missed the point, yes I hate those holders but hey they wouldsave the meter if dropped out on a hard surface, even my cheapo crap chinese meter has a well fitting and decent looking holster, in fact better than flukes, Agilent kind of missed the point with those "bits" yes it looks sleekeer but for something with that accuracy I'd want more protection unless ? I'm going to frame the damn thing and never touch it.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline TopherTheME
« Reply #18 on: July 28, 2010, 11:55:31 am »
Hello. Long time viewer, first time poster. I know this is an old thread but I just picked up one of Agilents newer B models, the u1242B. Not the equivalent of the u1253B but with all the controversy over the u1253A, I thought I would post some a mini review of it anyway to show some of the improvements Agilent has made.
Here's a quick overview of the features that I think make this meter special:
-300h battery life with 4 AAA batts
-Harmonic ratio measurement
-Manual and automatic data logging (to the meter ONLY)
-Dual temperature probe measurement
-Switch counter
-Comes with two sets of probes and one set of test leads (very high quality)
-$220 price tag (I got mine for $200 w/coupon)
So of course, before I even turned the thing on I had to take it apart.
The case is held together using four machine screws that thread into metal inserts. (thumbs up!) First things I noticed was the isolated input PCB and the IR LEDs. The higher up model DMMs that Agilent offers (u125XB) offers the ability of PC communication using a IR USB cable while the u124XB series supposedly does not. Why it has IR LEDs in it, I don't know. Maybe for calibration or something. Anyway, almost all components are SMT except for a few through hole parts including a large sized 2.4576M crystal. Everything looks to be very high quality and fairly well laid out. The back panel is almost entirely shielded and includes a separate compartment for the batteries but not the fuses.
The input plugs are soldered directly onto their own PCB and connect to the main PCB via small aluminum (I think?) standoffs. The 10A input port has a small 2-pin header connected to which plugs into the main PCB as well. I'm guessing its for lead detection. The banana jacks have o-rings around them for sealing. One thing to note is that the case itself does not contain any o-rings or seals.
A pic with the input PCB removed.
Heres the other side of the board where you can now see all the input protection components and stupid fuse placement. Notice the shiny looking shunt resistor for 10A current measurement.
Heres a pic of the bottom side with the screen taken off showing the main uC. The die reads "Samsung C011, 38825AXZZ-TW8A, K4X890. Yeah, I had no idea Samsung did uCs like this either. I'm guessing its an ASIC of some sort.
And the last pic is of the window for the two IR communication LEDs. If the meter contains two IR LEDs I really don't understand why Agilent would not allow the use of connecting these things to a PC. Seems kind of stupid to me.
In summary my opinion of the u1242B in a single paragraph:
From first impressions, it looks to be a really nice meter. It obviously doesn't have any of the major pitfalls of the u1253A like short battery life (300h w/4 AAAs) or a display you can't see outside. The display is very clear and easy to read and the orange backlight makes it very easy to read even at high angles. There are still a few quarks that carry over from the A series such as the slow response continuity check but voltage, resistance, and capacitance readings are all fairly quick. The case does leave a little bit to be desired as its obviously not as rugged as a Fluke 87 but I work (and play) in a lab setting so thats not a big deal for me. The main selling points for me were that I wanted a good accurate meter that I could rely on which also had the ability to log data in the field (I do a lot of fuel cell, solar, and battery stuff) and do dual temperature measurement. With the exception of the chinese pieces of crap that claim a BS accuracy, this is the meter I liked best given my $200 budget.
« Last Edit: July 28, 2010, 12:21:32 pm by TopherTheME »
Don't blame me. I'm the mechanical engineer.
Offline TopherTheME
« Reply #19 on: July 28, 2010, 12:16:49 pm »
Forgot to add that Agilent included these multimeter skins that you can stick onto these things. I chose the gogreen one to match my hippie personality.
Offline EEVblog
« Reply #20 on: July 28, 2010, 02:50:45 pm »
Awesome work, thanks for the pics and breakdown.
Looks like a really great meter, shame about the still slow continuity buzzer.
Layout looks pretty good apart form the underside fuse which is just plan silly.
Looks like awesome value for $200.
Did it come with a cal certificate?
Dave.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #21 on: July 28, 2010, 08:24:10 pm »
Great job, and thanks for posting pics. :D
Best Wishes,
 Saturation
Offline TopherTheME
« Reply #22 on: July 28, 2010, 10:19:38 pm »
Yes. It comes with a signed certificate of calibration from Agilent which includes the data and readings from the calibration process. I think for about $50 more you can get a cal certificate from NIST.
« Last Edit: July 28, 2010, 10:24:52 pm by TopherTheME »
Offline EEVblog
« Reply #23 on: July 28, 2010, 10:31:16 pm »
Is there any reason they put the 11A fuse on the bottom?
Can it be desoldered and moved to the top?  ;D
Dave.
Offline safarir
« Reply #24 on: July 29, 2010, 09:37:32 am »
Hey guys,
I just receive my u1252B after 3 month of wait. The big suprise: Every board (3) have a u1251 silkcreen on it.
Maybe the u1251B can be hack to the u1252B...
The bad new: The windows as a big bubble in the center  >:( and now that I take it appart, the rotary switch don't fell as good as when it was new.
« Last Edit: July 29, 2010, 09:48:46 am by safarir »
