Author Topic: EEVblog #586 - Open Source Hardware uARM 4-Axis Desktop Robotic Arm Kickstarter  (Read 24666 times)
Offline EEVblogTopic starter
Dave looks at the open source hardware UFactory uARM 4-axis desktop robotic arm kit project available on kickstarter:
https://www.kickstarter.com/projects/ufactory/uarm-put-a-miniature-industrial-robot-arm-on-your
http://www.ufactory.cc/
This is the first unit produced, and comes with the suction cup head and Arduino Uno board and shield controller.
Online NiHaoMike
    • Facebook Page
A good use might be mass importing CDs or other disks onto a PC. Or conversely, automating a low volume "production" of CDs and such, probably most useful for independent artists.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
Sorry Dave, I think being a Kickstarter backer on this item has got in the way of your objective judgement. The only value I can see is in it being a construction kit, not as a built arm.
Offline pickle9000
Could you not rig it up as a simple camera rig?
Daves quadcopter probably has outputs that could connect to the servos directly. Could be a fun experiment.
You could also connect it up to to this with practically no effort.
http://www.paintballsentrygun.com/
How about Daves Robot sidekick.
It looks like a really fun toy.
Offline hikariuk
I find myself a little underwhelmed.  Also missing playing with real ones.
I write software.  I'd far rather be doing something else.
Offline GiskardReventlov
  • How many pseudonyms do you have?
Here's my proposal, you use this robotic arm to test out the cat ratings for the multimeters. The robotic arm will do the plug in for each cat rating stated for each meter.  It needs a good name too. I propose "Electrocutioner".
If the meter dies we'll probably know it by watching but in any case the Electrocutioner will need to be programmed to give a "Thumbs Up" or a "Thumbs Down".
I also propose that a nice cloth cover be made for the Electroctioner so you can unveil it each time. It will look like an executioner's hood but maybe with a electric bolt on it.
...Dave's reviewed all other aspects to be reviewed and then he says:
"And now it's time .... for ..... the .... (with his hand on the shroud) .... Electrocutioner .... (off comes the shroud and a crack of lightning dubbed in)
« Last Edit: March 04, 2014, 07:42:39 pm by GiskardReventlov »
Offline electronics man
just seems like a gimmick.
follow me on twitter @get_your_byte
Offline robrenz
  • Real Machinist, Wannabe EE
I'm sure if you replace all the pivot joints with proper bearings with proper fitting axis rods through the bearings you could eliminate most of the backlash/slop you have there. Then all you'd need to sort is the servo slop.
That is only one of the many weak points of its design. There is a reason real robots are not made from acrylic. ;D
Offline pickle9000
Other uses
- Multimeter shootout, have it knock meters off the bench. Sagan can push the button.
- Mount a hammer on it and have smash something. A bad component from a troubleshooting vid.
- Mix up some pudding.
- Robot arm multimeter bowling.
I said it's a toy, that's all it is. If you want a toy OSHW robot arm to play with I think it's perfectly fine.
I doubt it would have the strength to plug in banana plugs.
Maybe a low-force switch? I looked on digi-key, wow, for a 1000V it's $$$.
Offline kizzap
Dave: If you removed the suction head, and possibly screwed it down to a bench somehow, would it be able to support the weight of a small webcam? Let users on the internet control it and look around the lab.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline mdszy
  • somehow has an ee degree
    • szy.io
Twitch Plays Dave's Lab?
somehow allowed to be a Pixie Wrangler in Training
eBay Store | My site | Hackaday.io Projects | my mastodon.technology profile
I have a webcam that pans/tilts already, so no point.
Offline pickle9000
Dave, by chance have you ever owned an Armatron?
I had both.
Offline indigoid
Dave,
Since you waffled endlessly about the serial commands being undocumented... ;)
This would be a great opportunity to do a video on a practical application of UART functionality of the Bus Pirate - namely sniffing all the serial chatter. Connect the UART pins on the Bus Pirate to pins 0 and 1 on the Arduino in the robot.
I used mine similarly to troubleshoot a AVR-based MIDI controller I was building recently. Bloody excellent little tool, the Bus Pirate. It's not particularly brilliant at any one thing, but it has so many applications where it is often "good enough" that for $30 it's a no-brainer.
No point, they'll probably release it in few days when the campaign ends.
Offline BMac
Dave, Had to laugh I've used hundreds of the Fanuc 410iB, Check this out.
http://pdf.directindustry.com/pdf/fanuc-europe-corporation/m-410ib/32007-381949.html
BMac
Offline Smokey
  • Not An Expert
Offline BMac
Yeah thats the old 410 with the big balancer on the side the new ones dont have that.
BMac
Offline ndim
The obvious idea:
  • remove suction head
  • add uCurrent test jig
  • put uCurrent panel to test under it
The banana plugs might just be self centering enough for the uArm tolerances to not matter.
Online NiHaoMike
    • Facebook Page
The obvious idea:
That won't be much (if at all) quicker than just manually testing. What might work is if it could pick up boards to be tested so you can just give it a stack and it would automatically test and sort them.
Offline denelec
How much will this robotic arm cost?  Didn't see the price.
This robotic arm seems a bit better.
http://www.robotshop.com/en/lynxmotion-al5d-robot-arm-combo-kit-4dof.html
I think this could be done on the oscilloscope. If so it would be more interesting.
